08-31-2021, 06:12 AM | #243 | |
Rep 4,521
Numbers of shims is personal choice. I tried 3 then 1 and finally opted for 2 shims on my e46 and ran 2 shims on my e91. As stated before this works even better with CDV delete.
Current '22 X3M LCI.. |
01-07-2022, 12:05 AM | #244 |
Rep 15
If you change your mind and try to remove it, it will be really challenging. I spent hours and had to brake apart.
I took it out because I felt that it's avoiding me fully disengage the clutch with 3 shims. I will probably go for 1 or 2 shims to test. |
chris7197342.50 |
01-09-2022, 06:11 PM | #245 |
Rep 613
Drives: F87 M2 CS
Well shoot. My clutch stop arrived today but after reading this thread, I’m quite hesitant to install it.
I had the BMS clutch stop installed (w/3 shims) on my previous F80 M3. While I did like that it removed the dead space, I do recall having a harder time with smooth shifts and occasional grinding while shifting. This time around, I planned on installing it with 2 shims on my M2C. However, it seems there’s still a decent amount of uncertainty around long term damage/wear caused by this mod. Some seem to report that their issues with gear grinding and such persisted after removing the clutch stop, eliminating the stop as the culprit. However, I’m still concerned the clutch stop may have been the culprit and the damage it caused now persists, even after it’s been uninstalled. I suppose it comes down to the amount of risk tolerance you’re comfortable with. Admittedly, my tolerance is pretty low. So I now fear this is mod will remain in its packaging inside my tool bin. Last edited by DadVibes; 01-09-2022 at 06:18 PM.. |
03-03-2022, 11:28 AM | #246 |
Rep 4
Just ordered one. I'm a new M2 owner and the clutch is such a different feel and distance from an STI, didn't expect it to be so light and deep when fully depressed.
03-03-2022, 11:39 AM | #247 |
Rep 922
Drives: '21 F87 M2C 6MT
Garage List 2015 MINI Hatch 5-door [0.00]
2021 BMW M2 Competi ... [9.67] 2023 BMW X5 xDrive40i [0.00] 2017 BMW X3 xDrive28i [0.00] |
i've had BMS clutch stop installed in my M2C for about 6 months now...but only a couple hundred miles of actual driving due to winter time in the DC area...however, i've had no issues with the clutch stop interfering with my shifting. i DO like the shorter travel with it installed.
my garage: '23 G05 xDrive40i m-sport; '21 F87 M2C, 6MT; '17 F25 x-drive28i SAV; '15 F55 mini hatch 5-door retired: '87 E30 MT 'vert; '92 E36 sedan; '99 E36 MT 'vert; '06 E90 x-drive sedan; '07 E83 x-drive30 SAV; '09 E91 x-drive wagon; '12 E89 Z4 MT M-sport; '15 F22 sport line |
07-21-2022, 03:38 PM | #249 |
Rep 307
I had the BMS clutch stop installed, absolutely loved it at first, but eventually started having shifting issues. I started out with 3 shims, then 2, then finally 1.
I was consistently having a hard time getting into 2nd during WOT, even with 1 shim. Felt as if 2nd was locked out. So, I got rid of the clutch stop completely and haven't had an issue getting into 2nd since. Luckily, my shifting issues didn't persist after removal, albeit slightly notchy, but I think that's normal. Of course this is all anecdotal evidence, YMMV. |
07-22-2022, 02:04 AM | #250 |
New BMW owner
326
Rep 844
So assuming you're correct, that means we have to step on the clutch all the way back for the shifting to be as smooth as possible? Is it possible that the split second you've spent going all the way back is what's causing that improved result? Bec for me if I'm shifting fast, it's less cooperative then when I'm taking my time.
05-23-2023, 03:13 PM | #252 |
Rep 10
05-23-2023, 03:20 PM | #253 | |
Rep 1,968
According to the late Ron Stygar: http://www.unofficialbmw.com/all/dri...djustment.html, he got the tip from a 1977 book "Turner & Miles Winning Autocross Solo II Competition" and conjectures he first installed a clutch stop in his 1979 320is. But like anything YMMV. |
05-25-2023, 01:43 AM | #254 |
New BMW owner
326
Rep 844
I wonder why we can't get a clear definite answer w/ regards to this. Did the BMW engineers really meant for their clutches to be THAT deep? It's been like this for yeeeears, and they haven't made any changes. Rumors before that the F87 would be the last MT (well now we know it isn't)... but MTs are almost out and they still BMW have not done anything. They could have included a bump stop themselves. I wonder if that new one is still like that? I just can't imagine that a clutch would need to be that deep in order to change gears.
06-20-2023, 09:34 AM | #255 | |
The Seeker
13915
Rep 3,336
07-03-2023, 10:00 PM | #256 | |
Rep 81
I have an E30, E36, E46, E90, and F22 M235i. The M235i, by far, has the longest clutch pedal travel of any of them. Driving it back to back with the E90 it's almost comical, and those cars were built a few years apart from each other. They're all about the same, except for the F22. Anyways...Personally, I don't really trust clutch stops, so I've reluctantly left my pedal travel stock. But I'll happily complain about it on the internet. |
