M2 Technical Topics > Suspension | Brakes | Chassis > Camber plates
      09-09-2020, 04:49 AM   #111
MagnusT
MagnusT's Avatar
Sweden
538
Always take a full printout from your alignment shop 😊
So you know they did everything right.
PLF693766.00
      09-09-2020, 04:54 PM   #112
kart driver
Drives: M & GT
Just an update.
The shop checked the toe and corrected their mistake yesterday.
As a result:
- the lap times were good again today
- the car felt balanced again, no oversteer as I experienced last time when the toe was not right
I also kept the pressure 2.2 BAR as per advise above and it looks like in combination with better negative camber due to camber plates the front tires are showing even wear.
Megator517.50
      09-09-2020, 05:04 PM   #113
MagnusT
MagnusT's Avatar
Sweden
538
Good to hear!!!
Get more camber :-)
And get a printout next time. I'm surprised what a sloppy shop not knowing what they are doing. Toe is a fine tune thing even more than the camber setting. IMO.
For track use, camber is like "crank it up" until you get a trackday car that is tramlining undriveable (and wears out the tires) on the street at 4+ degrees in the front :-D
Toe is fine tuning the cars reactions to suit your driving style and preferences. Both front and rear. A bit out in the front? Or just so slightly in? Minimize toe in at the rear to get a more rotateable (and a bit more nervous) car? And so on.
      09-09-2020, 05:31 PM   #114
kart driver
Drives: M & GT
Originally Posted by MagnusT View Post
Good to hear!!!
Get more camber :-)
Look, that is Ukraine. They have no clue when it comes to auto racing.
We have just one racetrack in the capital of the entire contry built many many years ago, and which is now in a terrible condition.
So no wonder the shop has no idea how to do the fine tuning of the car’s reactions.
      09-10-2020, 01:27 AM   #115
MagnusT
MagnusT's Avatar
Sweden
538
Hehe, yeah, I understand. Here in Sweden most places don't know anything other than setting everything to stock settings. And when you ask for something outside these like more camber they get very confused and reluctant. But at the same time we DO have a number of places who have good knowledge and race themselves
What I meant was that toe is a lot about personal preference (and very sensitive to small changes) and adding camber is pretty coarse and mainly about more grip on track vs less usability on the street.
      09-10-2020, 05:28 AM   #116
kart driver
Drives: M & GT
This is what they did for the first time when the balance became totally ruined.
      09-10-2020, 05:57 AM   #117
MagnusT
MagnusT's Avatar
Sweden
538
Bit of a problem with the language
      09-10-2020, 06:41 AM   #118
Megator
Megator's Avatar
518
Drives: M2 Competition
Just want to point out that alignment shops make mistakes in measuring. I dont mean in setup but in how they apply the reflectors for measuring.
I had my alignment redone as the steering wheel was not straight after the 1st time. I swapped from my track wheels and tires to the road wheels and tires (OEM 788s).
The 1st time my front camber was wrong and out of spec (on a stock car with no camber plates), 2nd time front camber was in spec!
I put it down to the fat some what bulging track tires vs the stretched oem tires. I think the track tire pushed on the reflectors or didnt let them sit right leading to the error. They sat well enough on the OEM wheels that the scratched them
      09-10-2020, 09:30 AM   #119
Bewstd
Drives: BMW M2, RAM 2500
Have a track weekend in early october and the millway street are on backorder, guess i'm grabbing the track version or ground control
2018 M2- Alpine White 6spd
some two wheeled fun and a tow rig
      09-10-2020, 11:30 AM   #120
kart driver
Drives: M & GT
That is all I have )))
      09-11-2020, 09:09 AM   #121
Bewstd
they had the street plates in stock so I went with them
      09-28-2020, 09:21 PM   #122
echoshotz
echoshotz's Avatar
207
Drives: M2 Comp
Anyone running camber plates on their M-performance coilovers? Trying to find out the max camber allowance with the bigger progressive springs. Don't care to add them if I can't get close to 3 degrees.
      09-29-2020, 02:29 PM   #123
2020M2Competition
2020M2Competition's Avatar
429
Drives: Yes
You should be able to get close to -3 degrees
Most likely somewhere in the mid to high -2.X range
Also, the M Performance coilovers supposedly use linear springs
Lots of good info in this thread
https://f87.bimmerpost.com/forums/sh...ighlight=shock
echoshotz207.00
      10-07-2020, 04:59 PM   #124
blitzyo
Drives: 19' M2C
I just got millway street on my mperf coilovers installed. There's no noises from it, but it does pass on a lot of tire resonance to the cabin at highway speed. I'm using a new set of oem paper gaskets on it.
My shop advised me I shouldn't run -3 up front for tire reasons, this is a daily car. I've got -2.4 front and -2 rear, stock toe settings.
      10-07-2020, 05:11 PM   #125
MagnusT
MagnusT's Avatar
Sweden
538
What are "oem paper gaskets"?
      10-07-2020, 05:23 PM   #126
Caduceus
342
Drives: 2008 135 (sold), 2017 M2
It's quite literally a piece of paper that sits between the front upper shock mount and the body of the car. Item 4 in the diagram at the link below.
https://www.realoem.com/bmw/enUS/sho...diagId=31_1331
Being paper, it offers no sound or impact cushioning. I imagine the only reason it is there is to prevent paint sticking to the shock mount if/when it is removed for servicing or possibly to prevent galvanic corrosion between the dissimilar metals.
      10-07-2020, 05:46 PM   #127
MagnusT
MagnusT's Avatar
Sweden
538
Ah, yeah seen that one come to think of it. Thanks
      10-05-2022, 03:18 PM   #128
M2RAW
M2RAW's Avatar
121
Drives: BMW F87 M2 BASE
So which camber plates is more likely NOT gonna give you any noises lol tryna pair it with my bilstein b16
      10-06-2022, 01:47 AM   #129
David.m
Drives: M2 LCI 6MT BSM
I've had my Millway Street plates in for 50K km (with Ohlins R&T) and no noise still, do a lot of spirited country/mountain driving & around 24 track days in that (I change camber between -2 street & -3 track). Have the F80/M2C tops as I've fitted the F80 strut bracing on my LCI.
