01-18-2018, 01:24 AM | #1 |
Rep 844
Clicking sound when turning wheel
I had previously lowered car with eibach springs and turner spacers. The shop who did it for me over torqued my wheels and said it was fine even after I insisted the books says 101 pounds. He was a former BMW master tech so I trusted his opinion.
Today my wheels were taken off to be cleaned at a car wash and were torqued back to proper specs. Now when I turn my wheel it has clicking sounds. I'm wondering if it is because now I would have to over torque them back to once what they were prior? Also the lug nuts seems fine when it was removed. |
01-18-2018, 01:31 AM | #2 |
Disrupter
1566
Rep 2,484
There is a squirrel who got into one of your wheels when they were taken off; this can be hard to deal with, but squirrels really like peanut butter, which can be used to attract them out in most cases. Good luck!
Disappointing People for Two Centuries; 3 Pedal Fanatic
01-18-2018, 03:41 AM | #3 | |
Rep 4,203
01-18-2018, 04:24 AM | #4 |
Rep 960
Yeah it’s nothing to do with your wheels... worst thing that could have happen is you strip the threads on the lug nut and need it retapped.
If it is a clicking noise when turning, it typically is a cv joint. But I can’t imagine you have excessive miles yet to have that go bad. But since you said you lowered the car on springs, I would double check the End links and strut bearings. |
01-18-2018, 06:20 AM | #5 | |
Rep 105
the sound was like an annoying creak/rattle/clicking noise anytime you went over a slight bump or applied the breaks but especially when turning the wheel. It was fixed by loosening the bolt which holds in the lower side of the strut (we tried everything else before this) and was coming from both front wheels only The bolt is towars the bottom of the strut. You cant miss it - houses the frame that holds the break lines. This bolt was over torqued and we reduced the toruqwe level until it stopped |
01-18-2018, 07:28 AM | #6 | |
Rep 960
Is it this? https://www.ecstuning.com/b-genuine-...iABEgLwgPD_BwE This is what ties to the body of the strut. It’s the end link. |
01-18-2018, 12:02 PM | #7 |
Rep 844
It was over torqued to maybe 140 or 160 lbs...when it should of been 101 lbs. Now I'm speculating that the reason they did this was to get rid of the clicking noise.
01-18-2018, 12:22 PM | #8 |
Rep 3,402
It takes a ton of over torquing to cause any issue and a click while steering would not be a symptom, a stretched and eventually failed wheel bolt is what would occur. When you lower a car you are likely to create issues like this because it is running at a lower ride height than the car was designed for and it can take some time for the springs to settle. My guess is when the car was raised to retorque the wheels the springs settled into a proper position resulting in the change. Of all of the things going on the wheel torque is the least relevant. The good thing is you noise is gone. It is important to remember whenever you do a mod, regardless of how simple they seem they can introduce all kinds of unintended consequences.
01-18-2018, 12:27 PM | #9 | |
Rep 844
01-18-2018, 01:31 PM | #10 |
Rep 3,402
I suspect you have change the geometry a bit too much for the linkages, if you can get the car on jack stands or a lift and turn the wheels you might get an indication of where it is coming from, most likely without weight on the wheels you won't get an indication though. As long as the car is tracking straight, tires are wearing properly and the noise is limited to turning to the limit of its ability its probably not something you have to worry about much.
01-18-2018, 02:00 PM | #11 | ||
Rep 229
18 M2 lbb manual exec (Euro Delivery) and PDC
11 e92 335i xdrive BSM/PE (Sold) 09 335i xdrive Monaco Blue (Traded) 02 330xi (Sold) |
01-18-2018, 05:17 PM | #12 |
Rep 960
I think a few people are telling u to check the end links
https://www.yourmechanic.com/article...izer-bar-links |
01-19-2018, 12:46 AM | #13 |
Rep 505
This happened when I had my M235i. Called my dealer and took it in for service. They basically had to take the wheel off and clean everything inside. Problem was then resolved and sound was gone. No charge for the service, as it is a common issue with BMW.
01-19-2018, 01:34 PM | #14 | |
Rep 450
'74 2002tii, Sienna Braun Metallic, Manual, Sold; '84 e28 533i, Burgundrot Metallic, Manual, Sold; '95 e36 M3, Avus Blau Metallic, Manual, Sold; '06 e60 M5, Silver Grau Metallic, SMG, Sold; '09 e82 135i MSport, LeMans Blue, Manual, Sold
