12-27-2017, 08:15 PM | #1 |
Rep 1,922
Drives: 2011 e91
Rebuilding wheels
Anyone ever rebuild 3 piece wheels to refinish? Anything I need to worry about?
2011 E91
2016 M2 - Sold 2014 X1 - Sold 2002 Land Rover Discovery II - 3" lift & 33s |
12-28-2017, 08:45 PM | #2 |
Rep 960
I’ve done 3 piece wheels as well as a 2 piece wheelto 3 piece conversion.
http://forums.vwvortex.com/showthrea...-BBS-Style-5-s Lots of stuff to worry about but torque around bolts is most important... |
01-09-2018, 12:32 AM | #3 |
Rep 6,659
01-21-2018, 08:46 PM | #6 |
Rep 1,922
Drives: 2011 e91
I'm lost on whether to try and strip the paint and polish, and how I'm going to strip the clear off the outer barrels without etching the shit out of the aluminum.
I still haven't seen anywhere that says whether or not the anodized outers can be polished or not. The assembly will be the easy part.
2011 E91
01-22-2018, 05:01 AM | #7 | |
Rep 960
Taking clear off is easy... I think some people use oven cleaner to strip the anodize off. Btw what are you trying to do... Last edited by Bt12; 01-22-2018 at 05:23 AM.. |
01-22-2018, 09:40 AM | #8 |
Rep 1,922
Drives: 2011 e91
Just trying to clean up my old wheels to sell them. The clear coat on the anodized barrels has peeled in some spots and its starting to oxidize a bit. I want to pull the centres out so I can polis both inner and outer barrels, reassemble and then sell.
Sorry for the crappy cell phone pic, but here's one of the wheels
2011 E91
01-22-2018, 09:51 AM | #9 | |
Rep 960
Much easier and faster than doing it by hand. What size are whose wheels? |
01-22-2018, 01:30 PM | #10 |
Rep 1,922
Drives: 2011 e91
They're 19s. 18" centres with a step lip. 19x10 et 34 and 19x8.5 et 27. They worked on my X1, won't work on the M2 without spacers in the front.
I don't think they quite work with the M2, maybe a black or MG car, but with LBB it looks weird. I also thought about powder coating the outer lips in a glossy bronze or something too, not sure that would look any better. May as well clean them up and sell them off to a better home.
2011 E91
01-22-2018, 04:51 PM | #11 | |
Rep 960
Also what are the size of lips and barrel in front and rear? |
01-22-2018, 06:46 PM | #12 |
Rep 1,922
Drives: 2011 e91
I'd need a 5mm spacer just to clear. I could order a new inner barrel 1/2" wider and run a 12mm or bigger spacer. Lips are 2.5 and 3.5 I believe
2011 E91
