12-12-2017, 12:12 PM | #1 |
Rep 37
HRE P101 wheels on M2
Hey guys,
Will HRE P101 front 19x9 Rear 19x11 fit the M2 with the stock tires? If not what are the recommended sizes Thank you M
2013 Mercedes Benz G500 Mineral Gray
2015 Mercedes Benz AMG G63 Matte Silver 2015 Porsche Turbo S <Sold> Red 2014 BMW M5 Matte Space Gray <Sold> 2016 BMW M3 F80 matte Mineral Grey Last edited by mo_albaker; 12-12-2017 at 07:39 PM.. |
12-12-2017, 07:40 PM | #3 |
Rep 37
Really!
Obviously I was referring to 19x9!!!
2015 Mercedes Benz AMG G63 Matte Silver 2015 Porsche Turbo S <Sold> Red 2014 BMW M5 Matte Space Gray <Sold> 2016 BMW M3 F80 matte Mineral Grey |
12-12-2017, 10:37 PM | #4 | |
Rep 105
Rear: sell some people in the US seem to have mounted 11s on the rear, I can tell you that the ideal tire size for a 11“ wheel is 285-295. so if the offset is ok it could fit although i would not recommend it as there is way more grip on the rear having 245 in front and 295 rear, it could lead to having way more understate which is something you don’t want on the M2 as it is so nice balanced with stock dimensions. 265 on 11“ wheels won‘t be ok i am afraid... |
12-13-2017, 12:22 AM | #5 | |
Rep 37
Thank you for your time, how about if I added 275/35/19 at the back? Will it be ok and balanced ? Thank you M
12-13-2017, 04:01 AM | #6 | |
Rep 105
http://www.reifenrechner.at Last edited by Egress; 12-13-2017 at 04:48 AM.. |
12-13-2017, 07:42 AM | #7 | |
Rep 1,835
Drives: 2020 X4M CS
IMO being lowered a bit helps at it cambers the wheels slightlu=ry ot it seems theyd hit the fenders...Id run 10.5"w a 275mm drag Radial...almost 100% grip even with dtc off... Pic for reference I cant see an.5" wider whel and 1/2" wider tire without damaging outer fender... my car was stock height id have major rubbing. other option is 11" wheel w stretched 275 but ur wheels willrup here and there and launches ,may geta bit better.
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 Last edited by DKX4///M; 12-13-2017 at 07:50 AM.. |
12-14-2017, 02:11 PM | #8 |
Rep 379
Yes, 275/35 is fine on an OEM rear wheel. In fact, 285/35 is perfect, and pretty much the largest you should go. I have seen up to a 305/30 on a rear OEM wheel, which I would not recommend.
12-14-2017, 03:28 PM | #9 | |
Rep 37
I’ll do 245/35/19 front 275 or 285/35/19 back
12-19-2017, 09:28 AM | #10 |
Rep 379
