01-10-2018, 01:31 AM | #287 |
Rep 57
I'm about to pull the trigger on a set of HRE RW 101's. They will have a custom fitting to the car, but I have a question about the sizes.
HRE suggests 245 front and 285 rear (no spacers required), but informed me that a 245 front and 265 rear is also possible. I will fit them with MP4S tyres without camber plates, as I only track my car a couple of times a year at a beginners level. Any thoughts on which size to go with? |
01-10-2018, 03:16 AM | #288 | |
Rep 2,577
Lemania 2320
01-10-2018, 06:27 PM | #290 |
Rep 3,695
01-10-2018, 11:33 PM | #291 |
Rep 2,560
Drives: Rapidly from A to B
245 front and 285 rear will induce a little more understeer than stock. From a tire setup I'd prefer 245 and 265 but not knowing what size wheels you are ordering I can't say whether they will look stretched or too wide for the wheel.
01-11-2018, 02:56 AM | #292 | |
Rep 4,515
Has anyone tried 265/285 F&R on OEM wheels and if so how is/was it ??
Current '22 X3M LCI.. |
01-11-2018, 07:56 AM | #293 | |
Rep 3,695
01-11-2018, 08:36 AM | #294 | |
Rep 3,695
265 on the 9” OEM wheels looks slightly too big and I may try 255/285 for my street setup to see if the balance changes that much. The grip is good, tho. My 265/285 4S setup is less than a second slower on track than my 265 square RE-71R setup, which is surprising. |
Bee Pee1777.00 |
01-11-2018, 10:33 AM | #295 | |
Rep 4,515
Thanks for this - I'm switching from OE 19" 437m to OE 18" 513m. Got 18" MPSS 245/40 & 265/40 to start with. Later may try 18" MPSC2 255/40 & 275/40 or maybe 265/35 & 285/35..... Cheers BP
01-13-2018, 11:21 PM | #297 |
Rep 328
M3/M4 Competition Package Wheels/Tires bolt right on with zero issues. M2, M3, M4 all use exactly the same width and offset wheels, only the diameter is different. Suspension and brake packages are identical on all 3 models. 265/30-20 F, 285/30-20 R
01-14-2018, 05:16 PM | #299 |
Rep 2,560
Hey, started a new thread to capture the specs on your wheels and tire combinations so we can track what fits and under what conditions. Drop your wheel, tire, and suspension specs on there and I'll try and capture them on the master spreadsheet.
Thread: http://f87.bimmerpost.com/forums/sho....php?t=1456261 Master spreadsheet: https://docs.google.com/spreadsheets...PeI/edit#gid=0 |
01-14-2018, 10:35 PM | #300 |
Rep 328
01-18-2018, 06:24 PM | #302 |
Rep 1,835
Drives: 2020 X4M CS
I run 255 35 19 front et 22 ( 10mm spacers)
275 35 19 REAR ET 35 (NO SPACERS) Lowered 1" front .8" rear, no rubbing N as balanced as stock but better all around...any understeer a little ease of throttle ends that real fast... 9.5" an 10.5" rims nitto nto5s
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 |
01-20-2018, 03:19 AM | #303 | |
Rep 69
01-20-2018, 11:15 PM | #304 | |
Rep 1,835
Drives: 2020 X4M CS
But In Person the fronts just about match the rear...They actually have a much lower off set but bc the inch narrower wheel...But I like that look too, if you go back through my mod journal youll see Before they had the 9.5"s in a 22ET (or before I knew of them) I had much less agressive offsets they were almost flat actually, looked horrible...
01-22-2018, 01:09 AM | #305 | |
Rep 1,835
Drives: 2020 X4M CS
And better pics of current look....
01-22-2018, 12:14 PM | #306 |
Rep 69
thanks for the info! the new set up looks amazing!
01-22-2018, 02:38 PM | #307 |
Rep 1,835
Drives: 2020 X4M CS
NP. Although I must strongly advise against these if you live where there are rough roads or use the M2 as a DD...Ive lterally went through more rims than tires lol
02-05-2018, 06:40 AM | #308 |
Old Guy
25
Rep 89
Drives: 2018 M2 LCI, 2019 X3
Z-Performance
Z-Performance ZP 2.1 purchased used from another forum member (Thanks kkurtz2647).
Stock suspension, no rubbing. Front 9.5X20 et20 P245/30 Michelin P4S Rear 11X20 et40 P295/25 Michelin PSS |
