M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Rattles?
      01-18-2018, 04:21 PM   #111
MagnusT
MagnusT's Avatar
Sweden
538
Originally Posted by Skwinglos View Post
Any follow up on this?
Not yet from me, it was postponed a few weeks.
      01-19-2018, 03:10 PM   #112
Skwinglos
Drives: MG M2; HD 2500
Thanks for the heads up
      02-06-2018, 05:02 PM   #113
Skwinglos
Bumping again.
Any updates?
      02-06-2018, 06:48 PM   #114
PackPride85
Anyone else's driver seat creak like crazy? It's the crappy plastic on the back of the seat shifting.
      02-06-2018, 06:52 PM   #115
bmwv
Drives: 325i Manual, M2 LBB DCT
2017 BMW M2  [0.00]
2006 BMW 325i  [0.00]
No but my passenger door handle does
      02-08-2018, 09:58 AM   #116
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
I have rattles from passenger seat at 1500~1800rpm under load, outside of that rev range it's fine. I know it's passenger seat because it is not there when there is a passenger.
Anyone have the passenger seat rattle and fix? Thanks.
Lemania 2320
      02-20-2018, 04:10 PM   #117
MagnusT
MagnusT's Avatar
Sweden
538
Bumping again.
Any updates?
Fixed! They had it for a day and a half only. They didn't have to release and slide back the whole dash as the PUMA suggested which was good. You never know if something starts rattling inside the dash after that. The PUMA is for the right side only but they did the left side too anyway as they had the windscreen out and everything.
Very very very nice to have the klicking noise gone
      02-20-2018, 04:39 PM   #118
Skwinglos
Glad to hear that is was fixed!
Do you have the PUMA number or any other information so I can follow up with my dealer? I think you mentioned the basic of the fix but any more details would be appreciated.
      02-22-2018, 12:15 PM   #119
MagnusT
MagnusT's Avatar
Sweden
538
It says "PUMA 63324690"
      03-04-2018, 12:54 AM   #120
mikeyymonster
mikeyymonster's Avatar
Drives: 2021 M2C
Originally Posted by eeyang92 View Post
I had the rear rattle fixed roughly 2 weeks ago, and it slowly came back until it was back at full rattle 1 week ago.
How did they fix it the first time?
2021 M2C
2014 M235i
Instagram: @mikeyymonster
      03-04-2018, 01:22 PM   #121
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
My rattles in the rear came back very intermittently after my first fix, so I knew I had found the culprit, but clearly hadn't done a good enough job, so I went back and redid it. I put much more thick velcro tape in the area this time. Felt side only.
The doors don't click into place, I just let them rest on the felt.
They don't move at all now and there is 0 buzzing now during my extremely loud cold starts (dp+exhaust)
Happy that it was a simple fix. Those deck lid clasps sure do like to chatter.
      03-04-2018, 04:13 PM   #122
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2020 BMW X4M CS  [0.00]
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
mines makes a loud noise behind A pillar...
Also when I put a 3000w amp and 12" RF P3 lots of rattles obviously...stuffed some insulation around the space over the trunk and anywhere I heard rattles....removed almost every trunk and rear seat panel (and rear seat) and used DEI Spray on sound/heat insulation....Now its sounds great....Still BMW is so solid, with seats up, you can barely hear sub...1 seat down and it is the loudest single subwoofer Ive heard no exxageration....
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3
      03-04-2018, 04:14 PM   #123
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
that yellow plug that powers seats and subwoofers came lose under my passanger seat and was making an annoying noise, just reattached it and went away...MAYBE thats ur issue...good luck
      03-04-2018, 05:32 PM   #124
SeanWRT
SeanWRT's Avatar
3179
Thanks for the headsup!
Regarding the yellow plug, I thought it was the black bar in the middle that is loose. I fix that black piece. Rattle seems going away a little bit but still there. Did you mean the entire yellow thing that's loose?
Lemania 2320
      03-04-2018, 10:34 PM   #125
bmwv
2017 BMW M2  [0.00]
I plan to do the same. How do u remove the rear seat panel and the a pillar trim?
      03-21-2018, 10:05 AM   #126
MagnusT
MagnusT's Avatar
Sweden
538
The clicking noise in the right A-pillar I had in my car that was fixed (PUMA 63324690) wasn't completely fixed The clicking itself sounds the same but it's much less frequent now. It seems to be temperature dependent and we've had below zero weather for a while. Anyhow, it's going back for another go.
      03-21-2018, 01:26 PM   #127
Skwinglos
Thanks!
Ugh, that sucks. I'll echo the temperature dependent thing. From my experience this only happens when the vehicle is cold and if you heat up the cabin it eventually goes away.
      04-04-2018, 12:22 PM   #128
Rupes
Rupes's Avatar
Drives: F87 M2 (current), E90 330xi (w
Serious question: do Porsche's rattle this much? I have a 12 year old 330i that is totally silent and a brand new M2 that rattles like crazy. On uneven/roughly paved asphalt, it sounds like someone is jingling a can of coins inside the car. The reason, I've been told, is the tight suspension - so does this exist in other "fast" cars?
      04-04-2018, 04:34 PM   #129
akkando
akkando's Avatar
5863
Yea my dealer gave me this BS too. "Oh it's an M car, the suspension makes is rattle more."
      04-05-2018, 08:12 AM   #130
ClothSeats
Drives: 17 1LE
Some rattles are to be expected in a track-oriented car with removed sound deadening. I recently watched this review of a 6GT. Ignoring the looks, I was impressed at the measures taken to reduce noise and cancel vibrations. But, they add a lot of weight.
      04-16-2018, 05:15 PM   #131
MagnusT
MagnusT's Avatar
Sweden
538
Not to long ago I started to hear a new rattle, this one coming from the middle of the back seat. I have foldable seats. The middle part where the foldable arm rest is I can fold down the whole middle section to be able to load long things like skis or something through it.
With the whole middle section up and closed - rattles
With only the arm rest folded down - rattles
With the whole center piece folded down - NO rattles what so ever.
Anyone know a fix? Or know a puma on this?
      04-16-2018, 06:27 PM   #132
silverado
silverado's Avatar
288
My M2 is too new for rattles, but it's very interesting to read about all the different rattled people are hearing in the M2. I owned an M235 for 3 years and 30,000 miles and I was so impress that it had ZERO rattles. It's plausible that the stiffer suspension is the source of the difference between the two.
2018 F87 M2 | LBB | Executive | Moon Roof | Apple CarPlay [2018 F22 M240 (sold) ; 2015 F22 M235i (sold); 2006 E90 330i (sold); 1983 E30 Coupe 320i (sold)]
