01-08-2018, 12:27 PM | #45 | |
Rep 4,511
as far as staggered 18" rims - perhaps its a "one size fits all approach" by BMW for winter wheels for whole F8x range as both 640m and 19" 641m are quoted by Realoem for M2/M3&M4. According to Realoem - 235/40/18 F&R - suitable for snow chains whereas staggered tyre set 235/40/18 front with wide rear 255/35/18 - NOT suitable for snow chains. Your set is probably non-snow chain set up - TBH I'd be happy with wider rears and will probably switch to 255/35/18 in the future.....Out of interest what tyre pressures does the plate inside the door jamb quote for 255/35/18 winter tyres ? I ask as my UK car only quotes 18" tyre pressures 235/40/18 F&R. Cheers BP
Current '22 X3M LCI.. |
01-08-2018, 07:14 PM | #46 | ||
Rep 1,124
01-09-2018, 02:47 AM | #47 | |
Rep 4,511
Any photos of yr 18" x 9" winter setup ??
01-09-2018, 11:03 PM | #48 | |
Rep 3,968
Why not put the same size WHEEL on all four corners if you want to keep the contact patch the same? Why would you change the wheel size but keep the tire the same? or how about this If you want a square tire setup, put a squire rim/wheel setup on.... Bee Pee - I'll check tomorrow. But/and, I assume it is the exact same.
01-10-2018, 11:06 AM | #49 | |
Rep 485
I am an IT nerd and tend to answer questions very literally (this one was “why put the same size tires on two different sized rims?”) - I was only trying to explain why you would (in the context given). Wasn’t trying to pick a fight either. |
01-10-2018, 08:19 PM | #50 | ||
Rep 1,124
Bee Pee1774.00 |
01-18-2018, 07:06 AM | #51 |
Rep 326
Question for you guys, I just sold my winter beater and now am looking at getting winter wheels and tires.
Will be going with 245/40/18 as it appears most winter M2 setups are. I understand the basics, but the speedo should be fine at that size correct? It keeps the basic diameter of stock so I should be fine correct? |
01-18-2018, 09:09 PM | #52 | |
Rep 1,124
hshot_rooke122.50 |
01-19-2018, 07:57 AM | #53 | |
Rep 326
01-19-2018, 02:53 PM | #54 | |
Rep 3,968
check out realoem.com http://www.realoem.com/bmw/enUS/show...diagId=36_2140 235/40/18 is the square setup size for the M2.
2021 911 C4S Gentian Blue, manual 2023 X3 M40i - loaded sans Park Assist Last edited by doug_999; 01-19-2018 at 03:01 PM.. |
hshot_rooke122.50 |
01-19-2018, 05:58 PM | #55 | ||
Rep 1,124
01-21-2018, 07:49 AM | #56 | |
Rep 326
01-22-2018, 09:49 AM | #57 |
Rep 186
I think i know the answer but....will M2 wheels with winter tires in sizes 235/40 18 fronts and 255/40 18 rears, work on an M4? I have a feeling the fronts might be a little narrow but its a smoking deal.
They are OEM wheels but I don't know the designation/model number. Even if the tires a little too narrow, it would be cheaper for me to pick up this set of wheels and replace the tires with the 255's all around as mentioned elsewhere in this thread. |
01-22-2018, 10:30 AM | #58 | |
Rep 3,968
01-31-2018, 12:26 AM | #59 |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
For what it's worth, on an 18x8 wheel [edit: with appropriate offset - mine are ET29 and running the same on all corners], you can go down to 225/45 for winter without any rubbing. I'm on 225/45 Michelin XIce3.
I'm an IT guy by trade and tech nerd by choice. I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway. I'm also a fan of aural pleasure. Last edited by ZPrime; 01-31-2018 at 10:19 PM.. |
rich8566608.50 |
01-31-2018, 03:24 AM | #60 |
Antonito
20
Rep 40
Winter rubber
Hey folks! Just picked up (yesterday) LCI BSM M2 with Pirelli Sottozero II tires on replika 437 wheels, same size (staggered 19") as original summer wheels/tires - wondering if I'll have difficulties maneuvering in the snow. Just about everyone on this forum seems to be going with a square 18" set up. Interestingly though Automotive mag fours seasons M2 had the 19" staggered set up and according to the article, it handled just fine. Any thoughts?
01-31-2018, 01:50 PM | #61 | |
Rep 630
Drives: 2021 G80 M3
02-12-2018, 10:05 AM | #62 |
Rep 1
Hi guys! I'm new to this and just received confirmation my 2018 BMW M2 arrived. The dealership is willing to put on my winters for me, but wanted to confirm if 245/40r18 on 18x8 ET20 will fit square setup? Will these clear the callipers and not rub on the fenders? Will they stick out?All feedback appreciated as I'm trying to learn everything!
02-16-2018, 07:21 AM | #63 | |
Rep 326
02-16-2018, 02:39 PM | #64 | |
Rep 817
02-16-2018, 08:46 PM | #65 | |
Rep 1,124
