M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > F87 M2 Wheel Spacers Fitment Thread
      04-19-2019, 12:54 PM   #155
M Fifty
846
Drives: M2 & 330CI
Just looking at the website of a UK based tuner that does packages for the M2 OG. They offer a 12.5mm spacer kit front and rear. Has anyone done that?
      04-19-2019, 02:18 PM   #156
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
there are members running 15 and more. But general consensus seems to be 10-12
https://f87.bimmerpost.com/forums/sh....php?t=1251250
      04-19-2019, 02:28 PM   #157
M Fifty
846
Drives: M2 & 330CI
Yes, I read the thread. Hence, the question as to whether the 12.5 on all 4 corners was really the way to go...
      04-22-2019, 11:16 AM   #158
mr_lab_rat
mr_lab_rat's Avatar
566
Drives: 2017 M2, 2018 X1
It looks more even with 12.5f/10r but you really have to be a nitpicker like me to see the difference. No problems with fender clearance either way with stock tire size.
      10-29-2019, 07:30 AM   #159
RacletteMan
I run 10mm front and back and am lowered on Ohlins. My front winter tires in the stock 245/35/19 size rub when the wheels are turned. Tires are Michelin PA4.
Thinking of either getting 5mm spacers in the front or running 235/35 in the front. I will post back with my results.
2016 Grand Cherokee Ecodiesel - 2012 1M - 2003 E55 AMG - 2005 Nissan 350z 35th anniversary - 1998 BMW 530D - 2003 Alfa Romeo 147 GTA - 1992 Mercedes W124 500E - 1992 Ford Escort Cosworth - 1989 BMW E30 325IX - 1988 Peugeot 405 Mi16 - 1963 Chevy Impala SS 2dr hardtop
      11-06-2019, 09:17 PM   #160
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
I know you aren't asking but I would in a heartbeat reduce the spacer to 5mm before reducing the tire size. I can't comprehend a performance reduction and new-found stretch look associated with the 235 being a better alternative than simply reducing the spacer by 5mm.
JTO245276.00
      11-07-2019, 04:06 PM   #161
RacletteMan
Thanks. I am not going with the 235 but will raise the car a few mm instead. The rubbing is due to the winter 245 being taller than the summer 245 so 5mm spacers would not help anyway.
      11-19-2019, 09:15 PM   #162
FreeDarko
Drives: F80
M2 Competition here lowered on Eibachs with stock wheel/tire setup. Running 7.5mm spacers all around.
Anyone else running similar setup and experiencing rubbing. I'm getting it on turns. I'm assuming there are vents on the M2c that wasn't there on the M2 that's causing the rub on lock.
      12-04-2019, 11:09 AM   #163
Billy_BMW
54
Drives: BMW M2 Competition
Yep. Running 12mm front spacer and KW V3 on M2C and getting rubbing at full lock on RHD drivers side. It’s minor and no damage to tyre so I’m prepared to live with it. You can probably avoid it by using no spacer on stock wheels but then it wouldn’t look anywhere near as good. 👍🏽
      12-04-2019, 11:19 AM   #164
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
What exactly is the difference with the Comp model that doesn't allow as much clearance? Is it just the way the inner fender liner is made?
      12-04-2019, 01:15 PM   #165
Billy_BMW
54
I think that’s exactly it. I presume different fender liners due to the different cooling layouts between engines.
It’s very prevalent on RHD cars I’m assuming. I laugh when I see guys asking to put 255/265’s up front when I’m rubbing with just 245’s and spacers!
      12-05-2019, 07:14 PM   #166
Pyrat 2
Pyrat 2's Avatar
Not sure I understand. Several people including myself have run 255 up front with no issue whatsoever. If you are looking for more tread on the ground then you need to very carefully add just enough spacer to keep the tire off the strut. That way when you turn the wheel, the outer edge of the tire doesn't hit the liner. If you add too much spacer so that it looks perfect when the wheels are straight, then you will end up hitting the liner when you turn the wheels. Hopefully that makes sense.
If on the other hand your goal is just to be more flush, but without more tread width, you still need the same approach but you'll be able to add larger spacers before hitting the liner.
      12-09-2019, 11:21 AM   #167
Billy_BMW
54
The spacers I’ve added are purely for visual appeal. However, please see thread below where the problem is apparent on other RHD M2C’s as well.
https://f87.bimmerpost.com/forums/sh....php?t=1624545
As I said, it’s liveable and hasn’t had any impact on the tyre wear or fender liner. I do plan to raise mine as it’s visually better (in my eyes) once the car is at a slightly higher height. Still lower than stock but not as low as how others like it (slammed etc).
      03-30-2020, 11:02 PM   #168
austinhuffzzz
54
Drives: 2016 BMW M2
hey guys, Quick question for all of you. I got a great deal on a set of Michelin PS4S and they are 255/35/19 square
my question is what spacers do you think I can run on the stock 437 wheels? car is on Eibach springs and don't want it to rub as it is my daily.
Thinking 5 up front and 20 in the rear due to the wider size in front and the skinnier size than factory in the back? Curious your thoughts.
      03-31-2020, 09:35 AM   #169
JTO24
never could compete with Lloyd Braun
JTO24's Avatar
Drives: 2022 G80 M3 6MT
5mm would be safe up front I think. I rubbed slightly on large dips with 255/35 PA4 winter tires lowered on Eibach with 7.5mm all around. I can't comment on the rears w/ a 20mm spacer, though. 7.5mm all around on my summer tires (OE PSSs) lowered on Eibach = zero rubbing.
2022 G80 M3 6MT | Skyscraper Gray | Kyalami Orange
2018 F87 M2 6MT | Alpine White (sold)
2016 981 Cayman 6MT | Jet Black (sold)
2015 F80 M3 DCT | Tanzanite Blue | Gold Brown (sold)
2013 E92 M3 6MT | Mineral White | Fox Red/Black (sold)
      03-31-2020, 10:46 AM   #170
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
20 in the rear is wayyyy too wide. I wouldn't exceed 15 in the rear and 18 in the front. Here's my car with a 15/15 set up on 245/265.
Appreciate 8
      03-31-2020, 10:47 AM   #171
austinhuffzzz
54
Drives: 2016 BMW M2
[img]
View post on imgur.com
[/img]
[img]
[/img]
You think even with the 255 tire out back?
      03-31-2020, 10:50 AM   #172
AndrewC1989
Sorry I missed the part where you said you were running a square 255 set up. 20 in the back would probably work then. I'd go wider in the front tho. Maybe a 10.
      05-29-2020, 11:31 PM   #173
MrFlema
Drives: 2020 M2 Competition
Where did you get those 7.5mm spacers? I found a couple but for use on front hubs only
      05-31-2020, 09:04 AM   #174
Twt
Twt's Avatar
635
Drives: 2017 M2
Turner makes a great hub centric 7.5mm with a finished center
FreeDarko217.00
      06-03-2020, 10:21 PM   #175
mr_lab_rat
mr_lab_rat's Avatar
566
Also don't forget that people run different different alignments. I used to be happy with 10f/7.5r on stock alignment.
After I got camber plates and running very mild 1.85 in the front I needed to bump it up to 15f/7.5r to look even.
JMM125.50
      06-22-2020, 05:43 PM   #176
KevM2
KevM2's Avatar
BMW M2 Competition  [0.00]
  [0.00]
Ok so I just got my Vorsteiner ff 103 wheels which are the recommended size at 19x9.5 et 22 front (equivalent to a 13.4mm spacer) and 19x10.5 et 40 rear (equivalent to a 6.4mm spacer). They said to use stock tires but I have a feeling my stock Contis would look too stretched! So I'm thinking of going with 255x35 front and 275x35 rear. What do you guys think? Should I expect any issues? Car is stock height.
