M2 Technical Topics > Suspension | Brakes | Chassis > F87 M2 BMW M Performance 2-way Coilover Suspension
      03-23-2021, 03:09 AM   #89
squixs
Germany
109
Drives: BMW M2 Competition
I just received the M performance coilovers and I want to confirm whether they currently have the compression and rebound settings as specified by BMW.
Do I understand it correctly that in order to set the compression/rebound that I have to turn the wheels to the maximum (hardest) + position and from there dial it 9 clicks back, if I want to have the rebound "9 clicks open"?
TIA!
      05-10-2021, 09:13 AM   #90
oranzada_m2c
Czech_Republic
17
Drives: M2C 2019
Yes... turn wheels to hard + and than for example 9 clicks open -
      05-16-2021, 11:40 AM   #91
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Originally Posted by 3t3p View Post
Ah I meant exact same springs and dampers. Weren't the 'rose joints' bogus in the end? Or was there an additional mod they did?
No rose joints- urban myth - lots of vloggers have had the opportunity to show the alleged rose joints but don't, to keep BMW PR m/c onside
Current '22 X3M LCI..
chris7197334.00
      07-03-2021, 10:25 PM   #92
pz619
Drives: F87 M2C 6MT, Tesla 3
I just got this suspension and dialed it to BMW specifications. 9 open rebound, 12 in rear, and 6 open compression all around.
I'm having a very slight rocking when coming to a stop that I don't recall with the stock suspension. I'm not sure if I'm just sensitive to it because the suspension is new. Was curious if others have had similar experiences.
      07-12-2021, 12:23 PM   #93
Connors5453
Connors5453's Avatar
Drives: 2023 BMW M2
2023 BMW M2  [9.38]
Same, tightened up the rear by 2 clicks and fixed it!
pz6193278.50
      07-12-2021, 01:08 PM   #94
M Fifty
844
Drives: M2 & 330CI
Compression, rebound, or both?
      07-12-2021, 01:12 PM   #95
Connors5453
Drives: 2023 BMW M2
2023 BMW M2  [9.38]
Both
      07-12-2021, 03:33 PM   #96
pz619
I’ll give it a try, thanks!
It’s getting aligned tomorrow and I’m going to ask them to re-tighten everything at ride height as well.
      07-14-2021, 05:49 PM   #97
pz619
The re-indexing of the suspension actually had more of a positive impact than i thought! Still going to adjust the rebound a bit to make it a bit tighter, but overall it worked out.
      07-14-2021, 05:49 PM   #98
Connors5453
Drives: 2023 BMW M2
2023 BMW M2  [9.38]
Nice!
      09-15-2021, 05:28 AM   #99
mtooperformance
Drives: m2 competition
Installation
Hello-
Did anyone have to use "rubber mount/shock absorber" to install their M performance coilovers? (please see attached photo) PN 33525A2DBC3
Attachment 2696618
My dealer says it's needed but I've been researching and checking and it seems it's not.
Can someone help me with this?
Thanks!
      09-15-2021, 05:31 AM   #100
mtooperformance
Originally Posted by mtooperformance View Post
Hello-
Attachment 2696618
Thanks!
      09-15-2021, 02:50 PM   #101
M Fifty
844
Drives: M2 & 330CI
Well, there is some evidence to suggest the rear lower bushes that come with the kit are prone to failure. I think Bee Pee replaced his with the KW parts (apologies if I've recalled this wrong), while BMW replaced mine under warranty - twice.
      05-21-2022, 11:04 AM   #102
squixs
Germany
109
I want to raise the front by ~5mm (0.2”) since the height is currently at 590mm. Can I do without doing a realignment?
