12-23-2022, 03:55 AM | #1 |
Rep 15
N55 weird tuning result (dyno graph)
Hi guys,
i have a little problem with my car tuning result, right now my mod list is : - ER Catless downpipe - Forge Intercooler upgrade - Forge Chargepipe - K&N Drop in filter - Spark plug upgrade So i tried to use BM3 OTS Map Stage 1 & 2, the dyno result is kinda weird, i don't know why my car always have the same power and torque at 5000RPM to redline, even the stock tune have a better result at 5500 - 6800 RPM. Here is the dyno result Stage 2 OTS VS Stock tune. as you can see the dyno graphic crossing the line (beetween stock vs OTS) at 5000RPM to 6800RPM. I also trying to custom tune my car, and the symtomps always at 5000rpm the power will drop like a stock tune. Below is Dyno result Custom tune VS Stock tune at 5000RPM, the engine always holding back. the IAT is the same around 120F, Boost level also the same beetween OTS VS Stock and Custom VS Stock. NO BOOST LEAK. The OTS & Custome tune have the same boost pressure characteristic. Meanwhile the Stock tune have a lower boost pressure and tappered down when it reach the redline. The timing ignition on stock tune is more advance because the lower boost pressure from the graph it seems something holding my engine at 5000RPM, is there any thing i should check or change so it not holding the power? any input will helps. Thank you |
12-23-2022, 10:05 AM | #2 | |
Rep 4,173
The intercooler is garbage, and I'm sorry you spent money on it. Depending on Ambient temps (I'm seeing here, your region, it should be around 83F?) 120F IAT is terrible. Your car is already reducing timing and losing power past 110F. You'll need a new intercooler before you do anything: if you don't want to take off the bumper, the biggest you can fit without modification is the CSF. If you want the best, a Race core/Slim profile core will be your best bet. VRSF Race/MAD Race/ER/Wagner EVO 3 (I would buy them in that order) So outside of your timing being pulled at higher RPM because of the high temps, you're also working through a bottleneck. You'll want to upgrade your inlet to the MST Version 2 inlet. The inlet on it's own is worth about 10WHP past 6000RPM. Fix those two, and you can make as much as 370WHP at redline - but the turbo isn't really sized appropriately for this range, which means you'll generate a lot of heat (hence why the IC is so important) Edit: while it's not a "power mod" I recommend upgrading the Diverter valve when you do the inlet. They are in the same location, so you'll save on labor. It improves throttle response and helps you hold more boost.
Mods: Yes.
12-23-2022, 06:11 PM | #3 | |
Rep 15
Thank for the input, i never thought the problem is intercooler. i will take a look at it |
12-24-2022, 05:13 PM | #4 |
Rep 1,243
Drives: 2017 Big Turbo BMW M2
I recommend switching to the 6.5 inch Wagner Evo III intercooler kit. The intercooler is the best and light weight in comparison to the 7 inch CSF race intercooler. The kit also comes with a charge pipe and boost pipe.
12-24-2022, 06:41 PM | #5 |
Rep 4,173
I don’t think that this is true. It’s pretty much the same weight as the VRSF / MAD race, and it’s x3 more expensive and from what I’ve seen, doesn’t cool as well. Yeah it comes with the extra hardware, but it’s more involved on its install.
12-24-2022, 07:02 PM | #6 |
Rep 1,243
in 5th gear it was proven to keep consistent IATs with the CSF increasing 10F. It has better better cooling and it is 5-10lb less in weight. Me having a big turbo build, it was a no brainer. I guess if you’re not big turbo or tracking, it may not be needed
12-24-2022, 07:31 PM | #7 |
Rep 4,173
I’ll agree it cools better than the CSF, I don’t believe it cools better than the VRSF Race. The CFS is only 8” tall and 5.5 deep - the EVO3 is 13” tall and 7” deep - it has more surface area, so all else being equal it should.
12-24-2022, 08:01 PM | #8 |
Rep 1,243
I’m pretty sure I read it does better than the VRSF one. I saw the comparison on another forum that you previously had written on. pretty sure the VRSF one is much heavier too from what I heard.
12-24-2022, 08:16 PM | #9 | |
Rep 4,173
And no, the VRSF actually does cool better. I’ll link you to the thread and logs again. On a Stage 2+ car (stock Turbo) it was 15F above ambient. On a stage 2 car 5-10F - and this is consistently back to back runs. The Evo 3 on stage 2 had one hero run and then was 20-25F over ambient consistently. The reason I’m making the distinction is because the stock turbo generates massive heat past 5800RPM because it’s out of its efficiency range. Add this in to less internal surface area because of its Tube and Fin construction, it will not be as efficient at shedding heat as a bar and plate style IC I try not to get into this too much anymore, because no one listens anyhow, but I’ll find the thread. |
12-24-2022, 08:24 PM | #10 |
Rep 4,173
https://f87.bimmerpost.com/forums/sh...5&postcount=49
Comparison here. If it can’t perform on the street, it’s not going to perform on the track - street performance is indicative of track performance. The Evo 2 displayed poor IAT control on the street, and no surprise, on the track also. The ATM did better on the street, and also on the track. This is also despite more weight and less fin density. https://f30.bimmerpost.com/forums/sh....php?t=1518971 |
12-24-2022, 08:28 PM | #11 | |
Rep 1,243
12-24-2022, 08:30 PM | #12 | |
Rep 1,243
12-24-2022, 08:40 PM | #13 | ||
Rep 4,173
The EvO is physically larger and has more external fin density, is lighter and still performs worse. Quote:
I’m also aware that there is a Pure Stage 3 N55 at 24/25 PSI with stable IATs on a VRSF, but it’s a E chassis, otherwise almost the same thing we have. |
12-24-2022, 08:46 PM | #14 | |
Rep 1,243
12-24-2022, 08:52 PM | #15 | |
Rep 4,173
Post a log when you have a chance. Edit: 124F is higher than you’ll want on pump, but at what ambient? |
12-24-2022, 08:55 PM | #16 | |
Rep 1,243
And as for your car build, I feel that. I currently go to college and barely have time to keep up with the car. I been working full time while taking five classes and we keep trying to dial in the tune. I also have lot of new parts have been getting installed in preparation for Bimmer Invasion. I probably have like 20 parts that are being added but at the same time I forget I own an M2, because I barely get to drive it. |
12-24-2022, 09:31 PM | #17 |
Rep 4,173
Travel the world and track it, that’s my advice in life lol.
Also, get married, the right woman will make everything you do better. |
shaneguags1196.00 |
12-24-2022, 09:48 PM | #18 |
Rep 1,243
I do have potential plans on tracking it. Traveling is hard with school, but I’d like to think I’ve done a fair amount in the past. Also, I will not be getting married anytime soon I just turned 21 not too long ago. Hard to find love in Tampa at my age
12-25-2022, 03:16 AM | #19 |
Rep 15
Hi guys,
Thank you for the detailed info (testing and data on Intercooler). i think the Evo 3 is too big for me and i just want to the direct plug n play intercooler. is there any recomendation for it? How about Wagner Competition evo 2, is that good intercooler? or there is better option? Btw i live in Asia (Indonesia), so the ambient temperature around 97 - 104 F degree Thank you again guys |
12-25-2022, 10:26 AM | #20 | |
Rep 4,173
VRSF Race, MAD Race, and even BMS Race. It will require the removal of the front bumper and but they will give you the BEST IAT control, which you’ll need based on the high ambient temps you’re seeing. They should be able to keep you within 10-15F over the ambient temps during a pull, which is pretty good. If you can’t or won’t remove the bumper, the VRSF 6.5 competition, Do88, and CSF are the next best options. Wrap your charge pipe in gold reflective heat tape if you can as well. From what I’ve seen with the CSF, it’s within 20F+ over ambient. Last edited by AmuroRay; 12-25-2022 at 01:35 PM.. |
shaneguags1196.00 |
12-25-2022, 02:53 PM | #21 | |
Rep 647
I haven’t monitored temps on track. BimmerLink wouldn’t cooperate last time I tried but I’ll give it another go in a couple weeks. |
12-25-2022, 07:34 PM | #22 | |
Rep 4,173
Tags |
dyno, f87 lci, n55, tuning |
