M2 Technical Topics > Suspension | Brakes | Chassis > Coilover Knock/Clunk
      08-10-2021, 07:24 PM   #1
gwc415
Hello,
I recently had my AST 5100s rebuilt for my 2018 M2. The last month I had them prior to being rebuilt, there was this loud clunk that would occur while going over bumps or potholes. I recently picked up the rebuilt coils and the noise is still there. I just got new end links but those didn't seem to resolve it. It seems to only be coming from the passenger side front, and is noticeable up to 40 mph. On the freeway, there is no noise even when the road shifts significantly or I go over bumps.
Any ideas what could be causing this?
      08-11-2021, 03:47 AM   #2
MR RIZK
MR RIZK's Avatar
758
Drives: AW M2C
If the issue is not obvious why not drop back in the oem left front and see if the noise disappears. This will be a quick test to see if it is the damper or something else in the front end.
Common areas to check are all bolts on the arms, lthe pinch bolt on the damper, if there is play in the camber plate spherical joint or if the top nut is loose
      08-11-2021, 08:17 AM   #3
AM///X3M
Drives: 2019 M2C HS 2023 X3M Comp
Originally Posted by gwc415 View Post
Hello,
Check out this tread. The steering rack. It solved the clunk noise for most people.
https://f80.bimmerpost.com/forums/sh....php?t=1637057
Instagram @am_m2c
      08-11-2021, 10:13 AM   #4
twboy1999
Drives: 1994 honda accord
thanks for the info AM///M2C
2019 M2 HS 10000km and counting
      08-11-2021, 02:27 PM   #5
AM///X3M
I’m pretty sure that’s the clunk you have. Because I had the same problem and I followed the recommendation from the tread and fixed my issue.
Instagram @am_m2c
Tags
ast, bmw, coilovers, f87, suspension
