BMW M2 Forum > Regional Forums > CANADA > What gas are you putting in?
      08-21-2017, 09:17 PM   #1
arwin
Drives: 2017 AW M2
I usually put in Petro 94 in my car but I'm wondering what you guys have been putting in your M2. Is the shell v power supposed to be just as good?
I've had bad experiences with the top grade esso. I've tried husky 94 in my F30 before but I feel like the Petro/Sunoco 94 is the best.
      08-22-2017, 08:51 AM   #2
gmzanatta
gmzanatta's Avatar
1823
Drives: LBB 6MT M2 # 660/713
All we get here in NB is 91, so you have to make do...I prefer Shell V Power, best I can get around here, but in a pinch I'll fuel up at the Esso or Irving if I absolutely have to.
      08-22-2017, 10:15 PM   #3
CanadianDriver
Drives: P3D-
Esso 93 at selected stations
In a recent road trip, I was forced to put Esso 91 due to stations not having 93
No noticeable drop in performance (I wasn't pushing it hard though)
      08-23-2017, 09:45 AM   #4
F87_LCI
F87_LCI's Avatar
1787
Drives: 2018 LBB F87
Most Petro Can stations have the 94...is that not the best choice?
      08-23-2017, 09:50 PM   #5
CaptChaos
CaptChaos's Avatar
55
Drives: 2017 M2 - Mineral Grey
The only 94 we have available in Vancouver is from Chevron. No ethanol. The other vendors only offer up to 91.
      08-24-2017, 08:43 AM   #6
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
94 for my M2 at Petro-Canada.
      08-24-2017, 09:42 AM   #7
tux2005
234
Drives: 2017 M2
I've been going with Shell V-Power 91 to avoid ethanol but I'll probably go with Petro 94 for track days.
      08-25-2017, 07:38 AM   #8
gmzanatta
gmzanatta's Avatar
1823
Yes, but there is not a single Petro station in all of NB that carries 94...it's unreal.
      08-25-2017, 10:03 AM   #9
IS+1
Drives: 2017 M2 (AW 6MT)
Shell V-Power whenever feasible. But I go on lots of road trips so have used Ultramar, Petro Can, Mobil and others in the US, including the occasional no name gas stations. As long as it's 91 octane or higher I'm happy, and try to avoid ethanol if possible. This is the same approach I used on my previous N55 135i, and I drove it to 208,000 km with no issues, including track use. So don't sweat it if you can't find 94 octane.
      08-25-2017, 09:34 PM   #10
arwin
Drives: 2017 AW M2
Does Petro 94 have ethanal in it?
      08-25-2017, 09:46 PM   #11
SW19
SW19's Avatar
2478
Drives: 2016 Alpine White M2
It does in Ontario.Sunoco purchased Petro Canada back in 2009 and since then all of there gas is the same as Sunoco.All of the gas they sell in Ontario has ethanol.My E46 M3 always performed better with Shell V power,which doesn't have ethanol in Ontario.That is what I still use in my M2.
      08-26-2017, 10:44 AM   #12
S1monQc
Drives: '18 AW M2
Shell V-Power 91 only
      09-05-2017, 10:28 AM   #13
hshot_rooke
123
Drives: 2017 BMW M2
What province/city are you in?
      09-10-2017, 07:10 AM   #14
CanadianDriver
Drives: P3D-
Ontario... I encountered the lack of 93s along the 401 stretch to Montreal.
      01-02-2018, 03:15 PM   #15
johnnyb2fast4u
johnnyb2fast4u's Avatar
Drives: 2017 m2
does anybody use octane booster where you can only get 91 octane m2 manual says recommended 93 min 91
      01-03-2018, 02:34 PM   #16
alscks0414
alscks0414's Avatar
690
Drives: MY18 X3 M40i, MY18 M3 ZCP
Shell V-Power 91 all the way.
If yours tuned, then probably wanna go higher octane but if yours is stock engine with stock turbo and intake.. 91 ethanol free Shell V-Power will be the best selection.
      01-27-2018, 11:40 AM   #17
arwin
Drives: 2017 AW M2
Can someone explain the difference between using petro 94 w/ ethanol vs using shell v-power 91 w/o ethanol?
      01-31-2018, 08:58 AM   #18
alscks0414
alscks0414's Avatar
690
Usually NA gas providers will contain from 0 % up to 15 % of ethanol contents. (Usually 10 %), and vehicles that are manufacturered relateviely recent (after around 2008 i think) will have no harm, according to manufacturer, to run with gas with 10 % ethanol. (For Flex Fuel says 15 % is okay as well)
However, therer are few known factors that ethanol does and could affect engine of vehicles.
1. As ethanol is more volatile than octane it dries out the rubber (or soft plastic) components in fuel line and supply system resulting in cracks and gaps. More volatile characteristic also connects with higher freezing point which could result in condensation when temperature changed from low to high. (eg. entering garage from cold weather outside)
2. Ethanol is more corrosive in contact with some metal like zinc/ aluminum alloys and giving negative effect on injection in general in long term.
3. Also known to give more inefficent gas mileage. (I believe this was actually stated from New York Times before. Although it should not be a huge concern ppl driving vehicles like M2... LoL)
      02-01-2018, 03:24 PM   #19
ilvtofu
Drives: 2018 BMW M2
I usually run Shell 91 if I'm filling up in the lower mainland. Air miles are nice but I also consistently saw better results from my Cobb data logs (on my STI) with Shell.
      02-01-2018, 09:30 PM   #20
stefan
stefan's Avatar
Drives: M2 Comp
All Canadian 94 does. Do not use ethanol in your BMW. 91 is fine. Do not use additives.
///M Power
      02-11-2018, 07:04 AM   #21
swifty
Drives: F80, Levante & Tesla 100D
I only used Shell 91 on my e92 m3 since it was a NA engine but assumed it would be better to go with Petro 94 here in Ontario on the turbo cars.
Might need to reconsider.
Current Bimmer: '16 F80 M3, '20 F87 M2c
Gone but never forgotten: '13 FO e92 M3, Swifts, volks/advan, Akra Evo, Kics R40
Past: Alpine white e46 323i, Jet Black e39 530, Saph Black e60 530, Space Grey N54 e92 335, Mineral White N55 e92 335
      04-16-2018, 03:56 PM   #22
Canuckistan
Veni, vidi, vici.
36
Drives: 2018 F87 M2
FWIW, I just had this discussion with the head tech at Performance BMW. His opinion was that a good quality no ethanol 91 like Shell was better than the ethanol-containing 94s. He also said that Petro Can 94 didn't have real ethanol and was artificially boosted, so you don't even get the added power benefits. I read that somewhere else on the forums, but can't corroborate.
2018 F87 M2, LBB, DCT, MPE
Past: 2008 E90 M3/2008 335xi Sedan/2004 X5 4.4/2001 X5 4.4/2001 M5/2000 540i/1999 328Ci/1981 528i
