M2 Technical Topics > Cosmetic Modifications > Competition Seat Belt Swap
      01-27-2018, 05:53 PM   #45
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
Go aftermarket?
These seem decent. How difficult can it be to do yourself?
https://www.jcfitment.com/oem-berger...hing-seatbelts
"I would rather cry in a BMW than smile on a bicycle." Ma Nuo
      01-28-2018, 08:31 PM   #46
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
Originally Posted by as7920 View Post
Well I'm about to order one of two possible M2 cars, one with M Seat Belts and one without.
Spec of car without is much better and includes more of the options I'm after.
Now we know M2 can come with its own, how easy (and costly) is a retrofit going to be?
RealOEM suggests we need
No. Description Supp. Qty From Up To Part Number Price
For vehicles with
Competition package
S7MAA=Yes
01 UPPER BELT FRONT LEFT 1 72118058479
only together with Pos. 9
01 Upper belt, front right 1 72118058480
For vehicles with
M safety belts
S4GQA=Yes
01 UPPER BELT REAR LEFT M 2 72118092861
01 UPPER BELT REAR RIGHT M 2 72118092862
According to RealOEM.
The belts fit the M2
https://www.realoem.com/bmw/enUS/partxref?q=72118058480
$460 delivered from Germany.
rich8566608.50
      01-29-2018, 12:52 AM   #47
as7920
as7920's Avatar
597
Drives: 2023 SG/FR M4 xDrive Competiti
Yes, thats the site I grab the part numbers for. I'd like to know if its an easy swap out tor retrofit option and how expensive it will be.
All 4 belts come in quote expensive £585 (£265 option from factory) and then there is labour.
      01-29-2018, 04:01 PM   #48
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
Changing out the belts is one of the easiest things your can do. I would say do it yourself. I bet the whole job is less than 2 hours if you take your time. Removing the trim is the only hard thing - While you have it off your can bypass your ASD.
as7920597.00
      01-29-2018, 05:50 PM   #49
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
It took a professional body shop 4 hours just to do my fronts. A lot of trim has to come off.
      01-29-2018, 06:36 PM   #50
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
They sound "Professional"! Although it is always better to take your time.
Here is a set on ebay.
https://www.ebay.com/itm/BMW-3-M3-4-...JX2nu-&vxp=mtr
      01-30-2018, 01:33 AM   #51
as7920
as7920's Avatar
597
M2 has four striped belts too. Is that the same as M3/M4?
Dealer has suggested they can do it pre delivery. Haven't a complete price yet though.
      01-30-2018, 05:10 PM   #52
AndrewC1989
You have to remove and reinstall the rear seat bottom, rear seat side bolsters, rear quarter interior panels, all the weather stripping, sill plates and B pillar covers, disconnect the battery, install the belts, reconnect the battery and reset the airbag fault codes.
Personally, I don't consider that "one of the easiest things you can do". Also wasn't a 2 hour job.
Not trying to be argumentative, just saying i've had a belt swap done already and after seeing what had to be done, it isn't what I would consider quick or easy.
963mw331.00
      01-30-2018, 05:30 PM   #53
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
I ordered the belts today so will let you know how long it actually takes me. I have replaced the seatbelts on 3 MINI's and my mates F82. I have upgraded the stereo on every car I have had. BMW's are a bit of a pain but removing the back seats and plastic panels is not brain surgery. I'll have to pull all those panels anyway to add trunk insulation and adding new amps and wiring, This stuff always seems more scary than it actually is.
I will do a write up for the forum so others can enjoy working on their M2's too!
AndrewC198910931.00
termigni1081.00
mjsaville101.00
      01-30-2018, 05:50 PM   #54
pissclams
bad ***** poster _
278
Drives: 2011 E93 M3, 2018 F87
Originally Posted by Nantucket View Post
Thanks for the info.The BMW Canada website is so bad that it still only lists the info for the MY17 model.
They’re doing you a favor, this thing has too many M designations on it already. Anyone within a hundred mile radius can figure out that you’re driving an M car.
      01-31-2018, 08:37 PM   #55
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
Andrewc89 - just out of interest Sassicaia did a write-up for doing the above in his M4. Was quoted 2 1/2 hours by his dealer and did it himself in an hour....... he had not really worked on cars before....
      02-01-2018, 09:16 PM   #56
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
Originally Posted by MagnusT View Post
I'd like t know too. Curious what they cost in Germany.
The rears are 130 euros each and the fronts around 180 euros each.
Around $750 including shipping. they remove the taxes. Fronts are the same as the M4 backs are model specific.
      02-24-2018, 05:52 PM   #57
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
For those who are not scared of pulling a few panels.
Here is the compete set.
https://www.ebay.com/itm/BMW-OEM-Com...1aj3K-&vxp=mtr
$699 plus shipping
      08-12-2018, 05:23 PM   #58
as7920
as7920's Avatar
597
$699 plus shipping
Did you ever get your belts installed?
      08-12-2018, 06:59 PM   #59
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
No. Cancelled the order. Bought a better than stock intercooler and am working on a big turbo. It has become all about driving for me and honestly I like the non "boy racer" interior. If I need a change I will pull the stock belts and have my upholstery shop stitch the edges. That costs $200!
      08-14-2018, 09:47 AM   #60
IND-Distribution
IND-Distribution's Avatar
9587
Drives: G82 M4 / G87 M2
The euro belt tensioner will not work in the U.S cars. If you do buy euro spec belts then the webbing will need to be transferred to your factory U.S tensioner.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      12-06-2023, 10:33 AM   #61
bmwstephen
Drives: 95' M3, 17' M2
Is it easy to transfer webbing from one seat belt real to the other?
