05-25-2017, 04:17 PM | #1 |
Rep 2
Basics: M235i -> M2 Suspension Stiffness
I have a 2014 M235i and I'm in the process of ordering an M2. I've driven an M2 and M4. I've compared with a Cayman S. I'd like the normal ride of the M2 to be more comfortable on rougher and undulating roads. After doing some reading I think I understand the M2 ride is really not adjustable at all from the factory? Is that true for the M4? The settings don't seem to matter like they do on my M235i. I've read in Roundel that TC Kline claims to improve drivability and performance. While I can live with the stock suspension I'm curious if there is a solution to improve the softest ride with either little over impact or be more adjustable when needed. Thanks
06-06-2017, 02:23 PM | #2 | |
3845
Rep 54,376
Drives: F80 M3
Some of the aftermarket coilover will improve ride quality through much higher quality dampers with better damping. OEM dampers are usually over damped on the compression and under damped on rebound, thus the stiffer ride. Ohlins has the DFV technology to deal with bumps: http://hpashop.com/Road-Track_c332.htm TC coilovers can be tailored with custom rates for the best ride possible. The other option would be Ohlins if you are looking for slightly less noise(no camber plates = less NVH). |
