05-25-2017, 11:40 AM | #2 |
Rep 680
It sure does. A bit of a pain to program, but they all are. Mine's working fine these days (and the other cars work too).
05-25-2017, 11:44 AM | #3 |
Rep 1,298
Hell yeah a pain to program and screw reading the manual to figure it out. I found a youtube video which made it easier to program and wish i would of done that first, stupid manual
M3 Adjuster7904.50 |
05-25-2017, 11:44 AM | #4 |
Rep 120
05-25-2017, 04:55 PM | #8 |
Rep 3,293
I had no problem programing mine for both the rolling code at home and non-rolling code at work.
Mike
particulardude379.00 |
05-25-2017, 06:57 PM | #9 | |
Rep 490
05-25-2017, 08:45 PM | #10 |
Rep 1,133
I agree, it was a pain it took me a couple of try's. I had to ignore the Blinking LED on the mirror that was telling me it learned and keep holding down the button and then it took.
05-25-2017, 09:05 PM | #11 |
12
Rep 16
Mine was easy. I went to the actual garage door opener and took light cover off. There is a button you push that gives you 30 seconds to auto program. Just get in the car (or just about any car with homelink) and hold the button down until it stops blinking. I have it in 3 of my cars and just did all 3 in 2 minutes, along with 2 other remotes.
05-25-2017, 09:20 PM | #12 |
Rep 1,298
05-25-2017, 09:56 PM | #13 |
Rep 1,124
5 weeks in the M2 and I have not been able to program it.
05-26-2017, 09:11 AM | #14 |
Meh
926
Rep 781
Drives: M3CS & Cayman S
once i programmed the m2, it broke the programming in my i8. which was weird. haven't tried programming the i8 again since i just use my automation system to control the garage. i8 has ifttt integration so i can automate my garage to open and close based on it leaving/entering a geofence.
05-26-2017, 09:26 AM | #15 |
BMW Newb
581
Rep 903
Programming it wasn't an issue....I just followed the steps in the owner's manual which went fine.
However, I'm finding that, intermittently, it just doesn't seem to work properly. Maybe 1 in 20 times, the garage door will not open. I'll need to leave it for awhile, or open it manually...and after that Homelink seems to work fine again. |
05-26-2017, 11:00 AM | #16 | |
Rep 1,124
05-26-2017, 11:28 AM | #17 |
Meh
926
Rep 781
05-15-2019, 01:31 PM | #18 | |
Rep 195
Anyone else have problems with Homelink working sometimes and other times not? Thank ahead of time |
05-15-2019, 02:05 PM | #19 | |
BMW Newb
581
Rep 903
After the first few weeks I was able to consistently get it to work. I think it was just user error. Maybe didn't have quite the same range as my previous car, but once I figured out the distance, how long to hold the button down, etc. it was not an issue. Good luck! |
05-15-2019, 03:33 PM | #20 | |
Rep 195
It'll open fine from a good distance, I pull in and then I can't close the door. Then I tried to leave the garage and it wouldn't open the door. I was reading on a Tesla forum about possible interference from led lights, so I tried that theory. I waited for the lights to go off and I was able to open and close the door. Then I tested it again with the lights on and the door opened, but I couldn't close it. I may just delete the door and reprogram it to see if that takes care of it. Frustrating! Lol! |
05-15-2019, 06:49 PM | #21 |
Rep 462
This is interesting. What is rolling/non-rolling? I have a card I have to reach out and swipe for work garage - is this something I can program into HomeLink?
"... if he fails, at least he fails while daring greatly, so that his place shall never be with those cold and timid souls who knew neither victory nor defeat.” —Theodore Roosevelt
Instagram@particulardude |
05-16-2019, 08:47 AM | #22 | |
Rep 392
There no way the homelink could replace a keycard entry. Homelink only works with radio frequency controlled devices. |
