05-24-2017, 12:59 AM | #1 |
Rep 15
Turn off A/C when climbing a mountain?
There is a sign that when climbing a mountain turn off the a/c since it can overheat your car. Is this true or this would happened only to old/classic cars?
05-24-2017, 01:14 AM | #2 |
F80 n00b
2753
Rep 367
I think most modern cars in good working condition will do fine at normal operating speeds and load. I do see you are in the UAE, so if outdoor temps are in the 40 Celsius range, it might not be a bad idea though...
05-24-2017, 01:56 AM | #3 |
Rep 110
Our cars (M) are way overpowered for normal street usage, the amount of power needed for the airconditioning is about 10hp max on a hot day.
From that perspective, a stock M5 will have 550hp 'left' on a hot day for driving through the mountains. Seems enough and should not lead to problems. If you have an older car with old technology airconditioning (less efficient, uses more hp) it might lead to issues when you only have 100 / 120hp or so. In that case, yes take that into consideration on a hot day in the mountains.
BMW E88 125 - 2008
BMW F10 M5 - 2016 BMW E70 X5 3.0d - 2007 BMW R1150r Rockster - 2003 Mercedes LP2223 - 1970 (http://www.lp2223.com) |
05-24-2017, 02:18 PM | #4 | |
Rep 1,247
05-24-2017, 08:52 PM | #5 |
18665
Rep 14,108
Drives: G82 M4C X-Drive
Keep in mind that the M3/4 has good amount of cooling for track conditions that is more than adequate for what you are describing.
Oops, thought I was in the M3 forum. Your S4 should be fine, just keep an eye on that temp since you are in the UA.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 Last edited by jmg; 05-24-2017 at 08:59 PM.. |
05-26-2017, 01:23 PM | #8 |
Rep 515
I make a mountain climb every day that says "turn off ac for next 14 miles to avoid overheating"
As said, no issue if the car is modern and well maintained. |
05-27-2017, 09:51 AM | #9 |
Rep 1,347
Drives: 2011 335d
Your AC turns-off under heavy loads (WOT) anyway. It might be an issue if you were in an original 2002 BMW but not anything in the past three decades.
MightyMouseTech4337.50 |
05-31-2017, 02:32 AM | #10 |
Rep 15
Yes, you are right, if your car is well maintained even it doesn't matter while your car is too old. It totally depends upon What condition of your car is? well maintained or not? And you are right dude, modern cars have no issue like that. thanks a lot
05-31-2017, 05:59 AM | #11 |
10803
Rep 27,595
driving a BMW no, anything else you may want to play it safe and follow the signs recommendations
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
06-05-2017, 05:38 PM | #12 |
Rep 2,062
Just like low speed limits...this is mostly for older cars that were less efficient. Modern systems nowadays have better clutches that'll disconnect as needed and run a different refrigerant. I just rounded over 100k in my '10 X5M and topped of my A.C. after noticing it wasn't as cold as I'd prefer in CA's 90*+ temps vs WA's 60* averages...$34 later and it's ice cold
06-05-2017, 06:22 PM | #13 |
European Editor
10532
Rep 22,992
Normally I'd say leave the AC on. But... the OP lives in United Arab Emirates - so What is a HOT day? 40'C ? 50'C ???
I guess... I'd keep an eye on the oil temps... and IF you see more than 165'C oil temp... maybe turn off the AC. Btw... during our summer Alpine drive's... I've never had a problem climbing the Alpine passes with the AC on. Dack Dack
06-07-2017, 03:13 AM | #14 | |
Rep 15
Dackelone10531.50 |
06-07-2017, 11:54 AM | #15 |
Chef
927
Rep 1,059
Don't quote me on this, but I remember hearing a suggestion to turn the heater on in older cars during hill climb to keep it from heat soaking and on track to help cool off the systems.
Anyone has knowledge on this? |
06-07-2017, 12:25 PM | #16 | |
Rep 5,506
I've done this to keep my car from overheating on my engine swapped and turbocharged Nissan back in the 1990s which had various problems... the things I was willing to put up with to add horsepower back then... lol But on a modern car, it is not necessary if your car is well maintained.
Auto Detailing Enthusiast!
Dackelone10531.50 |
