04-23-2017, 06:14 PM | #1 |
Rep 72
Can't Enable Upper Air Vent Setting for Passenger
Hello Everyone,
Not sure if I'm doing something wrong but for whatever reason I can't get the climate control settings to show that the passenger upper air vents are enabled. Here's a pic: I tried sitting in the passenger seat, blast the settings, made sure the split in the center is set to 50/50, and made sure the vents were physically open. No matter what I didn't I couldn't make the passenger setting look like the driver settings. The picture was taken with me in the passenger seat. Air is coming out correctly from all the vents and I can control them with the manual vent controls on the dash but I can't get the split to show up correctly on the screen. Any ideas? |
04-23-2017, 07:32 PM | #2 |
Rep 72
Nevermind.
Checked the full owners manual and it turns out that upper line represents "Windows" and it's only supported on the drivers side. |
04-24-2017, 01:12 PM | #3 | |
Rep 246
The other gripe I have is if you adjust the temp on the driver side you then have to adjust the temp on the passenger side to match. Is there anyway the driver side temp adjust can also alter the passenger side at the same time? My Audi S5 did it by depressing the driver side temp button for a couple of seconds and then both temps would be sync'd , anyone.....? MJ |
Skwinglos35.50 |
04-25-2017, 08:27 AM | #4 | |
Rep 326
04-25-2017, 11:26 AM | #5 | |
Rep 72
When searching for hits on my issue all the posts I found were about climate sync not being on the M2. Strange indeed. |
04-26-2017, 04:04 PM | #6 |
Rep 246
Great feedback people, but genuinely unimpressed given the value of the car.
My OCD is now hitting high gear again. Need to find some meds before I just black out the digital displays and let my agitation return to normal levels..... Seriously, that is a crock.... MJ |
hshot_rooke122.50 |
04-26-2017, 07:44 PM | #7 |
Rep 1,660
C'mon....no sync on the temp....OMG.
hshot_rooke122.50 |
05-02-2017, 09:11 AM | #8 |
Rep 642
Funny, I'll take some of those meds as well. It's not really a problem when you have a passenger in the car as they can set it to what they want as intended. BUT, when I'm driving solo I shouldn't have to dick around with two knobs!
On the OP topic, that one got me yesterday when out with my wife. I kept pushing the RH side button frantically and the upper swoosh arrow thingy in the display would not light up. I was certain it was broken or something and had to stop and play with the entire system repeatedly to no avail. I swear I had seen it light up before. Luckily, my wife had her head on straight and talked me down. Then I had a epiphany.....why would the passenger be controlling the defroster?....there is only one vent up there, right? It's the stupid buttons fault, it is convincing you that the arrow should light up, but it doesn't. Another cost cutting thing, why mfg two different buttons for RH and LH drive cars. I feel better now..... |
hshot_rooke122.50 |
05-02-2017, 01:35 PM | #9 |
Rep 616
Drives: M2, X2 M35i, X6,328i,230i
Garage List 2017 BMW 230i [0.00]
2022 BMW X2 M35i [0.00] 2015 BMW 328i [0.00] 2008 Jeep Commander ... [0.00] 2017 BMW M2 [0.00] 1997 BMW Z3 1.9 Roa ... [0.00] 2014 BMW X6 xDrive35i [0.00] |
I have three Bimmers, including the M2, and none of them will sync the driver and passenger temps. I guess it's a BMW thing.
