03-10-2017, 11:20 AM | #1 |
Rep 177
replace brake fluid after each track day ???
Hello,
My (non BMW) dealer tells me that if I run my M2 on track I will need to replace the brake fluid after every track day. => WDYT ? Thx, |
03-10-2017, 01:35 PM | #3 | |
Rep 379
Every 10 to 15 or so days, it depends on a number of things. At this point for you it is a non-issue. Don't even bother changing fluid now either. You will learn when you need to move on to a better fluid.
Former BMW CCA National Capital Chapter HPDE program Chairman 2021-2022 |
03-10-2017, 02:19 PM | #5 |
Rep 177
I have created another global thread about brakes here :
http://f87.bimmerpost.com/forums/sho...2#post21396422 Please react on that other thread and not on this one |
03-14-2017, 12:03 PM | #6 | |
3841
Rep 54,349
Drives: F80 M3
If you drive your car normally, meaning no overheating the brakes, the brake fluid in your car will last at least 1-2 years before flushing is needed. However, if you overheat your brakes, even just a tiny bit, air bubbles can form and your hydraulic system is now compressible(soft pedal) and you will need to bleed your system to get rid of the air. OEM use rubber hose that is permeable by moisture, that process starts as soon as your car is filled with brake fluid at the factory. Your DOT 4 brake fluid may only have low 300s F(wet) of boiling temp instead of high 400s F(dry) when it is right out of a fresh bottle. That is the second reason to bleed or flush the system so you have absolutely the highest boiling temp possible every time you hit the track. Aftermarket PTFE lined hoses are less permeable by moisture and the tightly woven stainless braid has less expansion over OEM rubber, two very good reasons to upgrade. Not the mention most high quality hoses also adds some sort of coating on top of the braid for added abrasion resistance. |
03-22-2017, 08:06 AM | #7 | |
7906
Rep 11,785
This clearly falls under " overkill". Most HPDE organizations recommend you have fluid that is less than six months old when attending an event. If you want your car to be in the absolute best possible shape .. you can Change all fluids - oil, trans , diff and brake fluid after or immediately prior to every track event... or both ! But seriously , it's much easier to simply replace the stock brake fluid with a high temp brake fluid like Castrol Srf. It's around $60-80 a liter but has an incredibly high wet boiling point that is better than the dry boiling point for more than 90 percent of the products on the market. |
JTO245274.50 |
03-22-2017, 08:11 AM | #8 |
Rep 177
Thanks for your advise.
To replace completely the fluid I've Ben told that you need to open the abs box, which leaves a trace in the "log system" of the car... which could play against you in case of issue if you don't do it @ BMW => factory IT reset could be useful ;-) |
03-22-2017, 09:52 AM | #9 | |
Rep 295
03-29-2017, 03:43 AM | #13 |
Rep 2,560
Drives: Rapidly from A to B
FWIW I flush fluid before my first track event of the season. Then purge some before every subsequent event when I'm putting on the track pads. I change oil after every event unless I have two weekends back to back.
Yes. Probably overkill. Cheap insurance though.
03-29-2017, 01:28 PM | #14 |
Rep 1,084
FWIW: I once ran year-old (but freshly bled) fluid at a track day and had some pretty serious fade. Now I'm always on freshly flushed fluid. It's so cheap to just throw in fresh DOT4 (i.e. from a sealed bottle) right before a track weekend that it doesn't make sense not to.
When running more expensive fluid (e.g. RBF 660) I still replace my fluid at least twice per year.
03-29-2017, 01:36 PM | #15 |
Rep 177
Nice, it seems that my question and my dealer's advise are not necessarily that stupid ;-)
Do you do that by yourself ? I have seen some tuto on youtube and, although it does not seem that complex... I would not do it by myself ! |
03-29-2017, 01:44 PM | #16 |
Rep 1,084
Yeah, I use a Harbor Freight suction bleeder to slurp everything out of the reservoir, then use a Motiv pressure bleeder to run around to the 4 corners. I can do it at the same time as I change over to track tires on my Quickjack, done in 30 minutes. A quart bottle of DOT4 is like $8 at O'Reilly's.
04-04-2017, 01:06 PM | #18 |
3841
Rep 54,349
Drives: F80 M3
You don't want less than optimum brake fluid to ruin a day or two at the track. It's easy enough to do with some just hand tools and a jack. Gravity is a good option if you don't own a pressure bleeder.
04-28-2017, 07:50 AM | #20 |
Rep 25
I'm in the overkill/cheap insurance camp. I use higher temp fluid, never go on track with fluid more than 90 days old, and never run more than 2 weekend events without a flush. Going on almost 10 years, and have never had a significant scare in my cars, and I like that track record!
05-09-2017, 10:02 AM | #21 |
Rep 126
I've been tracking various cars for nearly 20 years and have tried a bunch of fluids.
Once I started using Castrol SRF, I only flushed once a year. It's "wet" boiling point is close to many fluids dry point. It's expensive at ~$80 a liter, but if you only have to change once a year, it's actually cheaper. |
05-09-2017, 10:40 AM | #22 |
Rep 177
I have been told that Castrol is very good for resistance to high temp, but not to last with a good quality during a long time ... and therefore needs to be replaced very often !
Someone told me to use "ATE Type 200 ", which is supposed to have a good resistance to high temp for my use a 3-4 track days a year, but a better resistance over time. => WDYT ? |
