10-03-2016, 05:52 PM | #23 |
Rep 105
Norcalmav23292.00 |
10-03-2016, 06:57 PM | #24 |
Rep 1,153
10-03-2016, 09:12 PM | #25 |
Rep 254
My thinking as well
2017 M2 - AW DCT - BM3 93 oct, Pure Stage 2, FBO, happy
2013 BRZ - was a GREAT car... just not fast enough 2008 VW GTI - first experience with boost 97 Integra GSR - crashed it |
10-05-2016, 10:51 PM | #27 | |
Rep 3,073
Follow me on IG
FrankMPower49.50 |
10-06-2016, 03:18 AM | #28 | ||
Rep 137
MY M2 BUILD:
http://f87.bimmerpost.com/forums/sho....php?t=1280115 INSTAGRAM: @nicklin_m2 https://www.instagram.com/nicklin_m2/ |
4
10-14-2016, 12:40 AM | #30 |
Rep 570
E10-20-035-01-22 is the part number
I've just ordered mine so il get them fitted and let you know how they are. Last edited by kiysersosae; 10-14-2016 at 02:12 AM.. |
10-14-2016, 10:51 PM | #32 |
3808
Rep 54,295
Drives: F80 M3
Yes, wider track will improve cornering abilities. In racing track widths are often adjusted to suit the driver or the track. If you want a car that can change direction quicker, it is achieved by having a wider front track.
10-23-2016, 03:48 AM | #33 | |
Rep 570
Does anyone know if the 25mm drop at the front may be a tad bit low if you have the carbon front mperformance parts? Don't want to loose them. |
10-23-2016, 07:41 PM | #35 |
Rep 3,073
Forgot to update here..
Got an alignment appointment for Nov 1st at the local dealer..
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii Last edited by BAN_M2C; 10-24-2016 at 08:16 AM.. |
10-24-2016, 01:08 AM | #36 | |
Rep 570
Sorry for the questions Cheers |
10-24-2016, 01:48 AM | #37 |
Rep 41
In an other (German speaking) forum Eibach ProKit drop was measured exactly 23 mm on each axle. Above pictures also seems to indicate equal drop of front and rear axle (as it was with my M3 E46 Eibach drop exactly 20mm both axles).
10-24-2016, 02:01 AM | #38 |
Rep 41
Did you shorten "spring travel restrictors" (in German "Federwegbegrenzer"). Eibach certificate for German off. testing center ("TüV") says nothing about this but Eibach users says it is required.. .
10-24-2016, 06:23 AM | #39 |
Rep 570
10-24-2016, 07:22 AM | #40 | |||
Rep 3,073
I failed to measure before installing but I do believe it's around an 1" all around. I will snap some pics from the front and post them up. Quote:
Hey Esteban, This Pro-Kit is very straight forward and you will only need to replace the springs. There is no bump stop trimming or replacement required. We usually include replacement bump stops if necessary. In this case, not needed.
Follow me on IG
10-24-2016, 08:14 AM | #41 | |
Rep 570
BAN_M2C4176.00 |
10-24-2016, 08:16 AM | #42 |
Rep 3,073
You are welcome! Good luck with the install and share some pics afterwards!
Follow me on IG
10-26-2016, 04:13 AM | #44 |
Rep 343
Now we just have to figure out what spacers work with this setup!!
It's looks better than the H&Rs I'm trying to figure out the best combination of spacers with this setup. I think the prokit with some mild-ish spacers and maybe F80 size tires front and rear will be perfectttt and fill in the wheel wells. |
