06-28-2016, 05:05 AM | #1 |
Rep 124
anyone tried the M-performance brake pads?
For all of you who have taken your car on track how did the pads hold out?
Has anyone tried the performance pads and if you have whats your thoughts/experience of them? I remember in the lauch event at Laguna Seca all the cars were fitted with the M-Performance brake pads they seemed to very noisey so probably not great for DD. |
06-28-2016, 06:33 AM | #2 |
Rep 354
All race and performance pads are noisy.
It's common practice to switch between the pads when going to track. I when to track two times so far, did two hot laps, and then two cold laps. In 30+ minutes session pads strength didn't fade at all. So these pads are perfect if yo're not tuning or planning to do more than few track days per year. |
06-28-2016, 08:39 AM | #3 |
Rep 124
Thanks for that. I currently run carbotechs on my track car so pad squealing is something I'm familiar with.
I'm taking the m2 to the ring next month but trying to get a couple of uk days in prior to get a proper feel of the car. Having *ahem* few points on my licence means I'm driving around like miss daisy till they clock off so haven't really given her any stick yet and the small amount I have the brakes seem adequate but I'm a marketing man dream so the promise of increased bite and fade free has me intrigued. |
06-28-2016, 11:15 AM | #4 | |
Rep 209
I took a couple of the other instructors for rides, and the reaction was "These are the stock brakes? Seriously? Damn!" To echo what you said above, for occasional track days, the stock pads are adequate. Consider upgrading if you do a lot of track days, or if you're running sticky tires like Hoosiers, or if you've tuned the car for more power. |
06-28-2016, 11:40 AM | #5 |
Rep 522
It's interesting how some are noting that the stock pads are adequate for 30+ minute sessions, and others are saying that the stock pads are completely insufficient for track work and they shredded the stock pads within a few sessions.
06-28-2016, 11:42 AM | #6 | |
Rep 2,948
If you are pulling hot lap after hot lap and going heavy on the brakes, then the stocks won't last 2 sessions, hell maybe even one. It's all a matter of driving style/skill - the more skilled drivers will undoubtedly be harsher on the brakes since they can push the car to the limit and thus will wear them out faster. |
06-28-2016, 11:46 AM | #7 | |
Rep 522
06-28-2016, 04:51 PM | #8 | |
Rep 209
I ran at High Plains Raceway, and in all but my first session, I was consistently braking from 130+ MPH to 70 for turn 4, and from almost 110 down to about 60 coming into turn 1. After 5 sessions I had no issues. I wasn't braking quite at "sprint race" levels, but more like I would for an enduro (I race an E36 M3 in GTS2). I must say I was pleasantly surprised, my track-package 228 had more noticeable fade while going nowhere near as fast. |
06-28-2016, 04:59 PM | #9 |
Rep 2,560
Drives: Rapidly from A to B
Maybe it was my lack of driving skills (advanced group with 10 years of regular track time) but I overheated the pads and left uneven deposits on my rotors requiring that they be replaced.
I checked a couple weeks back and the performance pads weren't available in the states. So I called Carbotech and they made me a set of xp10 and xp8 pads for front and rear. Haven't used them yet but will in 2 weeks.
06-28-2016, 10:57 PM | #10 | |
Rep 209
More importantly, did you experience any loss in brake performance? 'Cause about the only thing I noticed was a slightly softer pedal, but I could still stand the car on its nose. Oh, what track was this at? |
06-29-2016, 06:10 AM | #11 | |
Rep 124
Ahh that's very interesting. I'm surprised you used the two compounds, Is this the standard set up for the m3/m4?? In terms of tyres I run r888 on my other car but thought I thought I might go for cup2's on the M2 |
06-29-2016, 07:07 AM | #12 | ||
Rep 2,560
06-29-2016, 07:15 AM | #13 | ||
Rep 2,560
06-29-2016, 12:50 PM | #14 |
3837
Rep 54,338
Drives: F80 M3
Pagid RS29's have been very popular for the M3/M4 guys and will work just as well on the F87 M2 on the track. They make noise just like all the rest of the track pads so street use should be kept to a minimum. However, we do have customers running them all the time simply because they are doing track days 1-2 times a month very consistently.
06-29-2016, 03:06 PM | #16 |
3837
Rep 54,338
Drives: F80 M3
If you are just doing a shake down, you should be okay. You will likely fade the pads before boiling your fluid. If you have the time to flush it out, it won't hurt. Just remember if you are using the standard high temp DOT it is best to do this flush before each event. With Castrol SRF, you can get away with just bleeding it before each even and flush once a year.
07-08-2016, 05:40 PM | #17 |
Rep 160
Having experienced major brake fade (long pedal, squeaking, grumbling, etc.) half-way down an alpine pass from Italy to Switzerland last weekend I'd be amazed if the stock pads could deal with a trackday at a circuit with a few heavy braking events.
On the pass I had one passenger and about 40kg of luggage, but I wasn't going hard (owing to the big fresh air drops to punish a mistake) and it was only about 15C. I was really surprised the brakes struggled so much. |
03-10-2017, 11:41 AM | #18 |
Rep 177
03-10-2017, 09:28 PM | #19 |
3837
Rep 54,338
Drives: F80 M3
05-21-2017, 04:01 PM | #20 | |
Rep 1,124
Now I'm trying to figure out how to correct my rotor issue short of throwing new parts at the car.
05-23-2017, 06:24 AM | #21 | |
Rep 1,017
You've got a few options: a) Go to BMW and ask them to fix your issue. Up to you how you present this and how it's covered. b) Invest in a rotor hone and try cleaning them up yourself. c) Get someone to turn/machine the disks for you d) replace all parts yourself. I think anyone that's taken their M2 to the track has had similar issues to you, the stock pads just aren't upto serious track work. It's quite annoying the compound BMW are using. |
rich8566608.50 |
05-23-2017, 11:28 AM | #22 | |
Rep 4,512
I'm using M4 sport pads upfront and MP BBK pads in the rear on my MPBBK'd M135i. Works a treat.
Current '22 X3M LCI.. |
rich8566608.50 |
