01-15-2023, 09:25 AM | #1 |
Rep 1,334
M2C 6MT Street/Track Frankenstein.
I am going to use this thread to publish all the modifications that I am doing to the car, although I only have to change the seats, I am not going to do anything else.
Exterior: Full stock Interior: Short shifter cae (modified) Lightweight lihium battery liteblox 2kg Engine: Stage2 hybrid turbos M2 OG full decat exhaust Catless downpipes Oil lever sensor with spacer for 7.2l of oil Keyed crank hub Suspension: Kw competition M4 GTS Knuckles Sway bars H&R Rear arms with uniball joints Manufacturing the front arms for uniball ball joints and lift kit for rear diff Brakes: CCB rotors, oem pads Wheels: Custom forged wheels Front 19x9.5 et22 Rear 19x10.5 et42 M2cs racing rims are on the way. For now this is all. Sound: Last edited by Track/S; 01-21-2023 at 04:04 PM.. |
01-15-2023, 09:56 AM | #2 |
Rep 1,334
Gts knuckles with custom inserts to be able to use them with kw suspension.
Modified shifter Liteblox battery Last edited by Track/S; 01-15-2023 at 11:38 AM.. |
ClubsportJunkie311.50 SilverLakeM3241.00 |
01-16-2023, 12:59 AM | #5 | |
Rep 1,334
What is the reason? Is it forbidden to send batteries by air? Last edited by Track/S; 01-16-2023 at 01:14 AM.. |
to_riffic3023.50 SilverLakeM3241.00 |
01-16-2023, 01:43 AM | #6 |
Rep 1,334
Carbon cover like M4 GTS
Rear subframe Oil lever with spacer Front arms bushings Testing gt4 oil stick Anodized rear brake protectors and arms. Last edited by Track/S; 01-18-2023 at 04:24 PM.. |
4
01-16-2023, 10:53 AM | #7 |
Rep 312
Awesome, excited to see how this progresses. Any plans for a cage?
Current -- 2019 M2C MT
Sold -- 2009 E82 135i MT Widebody Track Car Sold -- 1989 E30 325i MT Showcar Sold -- 2005 E46 M3 MT |
01-16-2023, 01:25 PM | #9 |
Rep 1,334
01-19-2023, 02:47 PM | #10 |
Rep 1,334
M2CS Racing rims arrived
With 4mm spacer on rear, i hope 20mm at the front is enough, i will ride them with the 2NH brakes Tires 295/30 Last edited by Track/S; 01-19-2023 at 02:57 PM.. |
9
(K)1278.00 imperfectluck426.50 aatlas192.00 infinitekidM2C4206.50 gphung193.50 The_Werm212.00 SilverLakeM3241.00 HomoPirate84.00 Shaq935.00 |
01-20-2023, 04:55 AM | #11 |
Rep 69
I see some serious skills & thought here … a talented Body Man!
From one to another ,Cheers for continued persistence on your beautiful project ! Dan |
01-21-2023, 03:26 PM | #13 | |
Rep 1,334
Yesterday i tried the front rim: With 20mm spacer I had to cut the protector, it is bigger than the inside of the rim. Today I took out the calipers, i'm going to mill the outside face a few millimeters. |
4
01-21-2023, 04:49 PM | #15 |
Rep 1,334
01-22-2023, 02:21 AM | #17 |
Rep 1,334
Before buying the rims I was sure that I would be able to mount them with 400mm brakes, my 19 rims have an internal diameter of 460mm and there is still space between the caliper and the rim (with the naked eye about 15mm), the 18 rims have an internal diameter of 448mm, for this reason reason I knew they could be mounted.
01-22-2023, 04:42 PM | #18 |
Rep 1,609
that is very cool. After all, there is an 18 that actually fit the 2NH.
Whole car is looking amazing |
aatlas192.00 CoffeeLife397.00 |
01-22-2023, 05:01 PM | #19 |
Rep 1,334
9
Fabb228.50 imperfectluck426.50 D_SheerDrivingPleasure1092.50 aatlas192.00 The_Werm212.00 ///MPhatic13862.50 tropicatango437.00 SilverLakeM3241.00 HomoPirate84.00 |
01-22-2023, 07:33 PM | #20 | |
Rep 125
Very nicely done. Any before/after pics of calipers? My only concern would be if this compromised and structural integrity of the caliper. Especially under hard loads Looking forward to see everything mounted! |
tropicatango437.00 |
01-22-2023, 11:58 PM | #21 |
Rep 1,334
tropicatango437.00 SilverLakeM3241.00 |
