M2 Technical Topics > Track / Autocross / Dragstrip > Autocross!
      08-18-2017, 11:09 AM   #89
Sprockett
Drives: Cayman S
Originally Posted by z3papa View Post
I personally think a M2 can be competitive in BS even with limited camber, and with higher COG. Those folks looking solely at hp and weight really aren't getting it. The SAC looks at width, length, suspension, and consider real world limitations or benefits such as gearing, ability to overcome nannies etc.
Can you explain your reasoning here of why the M2 might be competitive?
      08-18-2017, 06:33 PM   #90
z3papa
Drives: 11 E92 M3 ZCP, 07 335i
First off, the only close data point of a Nationally competitive driver is that of Jeremy Foley in the 1M where he has won two National events this year. The M2 is every bit as good a car, similar size width and length, weight, dimensions, wheel/tire sizes, and differential. Essentially you have the FRC/base Vette which is much wider with no great thrust vs. Focus RS which has more dig out thrust but less manuverable vs. Solstice which is smaller but less powerful vs. S2000 (AP2) which is better on tight courses and killed on power courses and the Porsche entries. If Foley is in the top 10 then that will say a whole lot for the M2. D
Sold 2011.5 E92 M3 ZCP.
      08-19-2017, 11:53 PM   #91
Sprockett
Drives: Cayman S
Points taken but the m2 is actually significantly wider (it's basically as wide as the corvette). Also slighter longer wheelbase and is slightly heavier than the 1m. It does have supposedly a much better electric diff actually so I shudder think how hard it is to put down power with the 1m cause the m2 is pretty tough.
Besides all that I'll point out that it also has some pretty different gearing than the 1m. On short tires the DCT trans tops out at just 57mph in second and this means having to shift to third on any/every course. While one might say shifting is free with the auto it's still something to think about and the thrust in third isn't much of an advantage all of a sudden. I believe the manual gives 7mph more but on 'real' courses and even staying on big 19s (this will limit front tire width before rubbing) it may still be annoying. I know the Cayman currently tops out at 68 and I've hit the limiter plenty...with no where near the thrust of the BMW.
      08-26-2017, 12:05 AM   #92
alex s
Drives: '17/M2 '18/328dT '18/M3cs
Originally Posted by M3 Adjuster View Post
Reminds me I need to get a Ram mount for my iPhone also.
FYI, RAM Mount is a complete garbage, unless you DO NOT plan to take any video with your phone. Then it works fine.
      08-26-2017, 12:14 AM   #93
alex s
Originally Posted by CosmosMpower View Post
Anyone know what the street prepared SCCA class is for the M2, is it BSP?
Should be ASP. 1M is in ASP
      03-27-2018, 09:51 PM   #94
DOMs335D
221
Drives: 1991 318is; 2017 M2
1991 BMW 318is  [0.00]
2017 BMW M2  [0.00]
2011 BMW 335is  [0.00]
Hello Autox gurus,
Need some advice. I don't want to lose my BS class, but I want to put on some proper autox tires, which means I need a second set of rims which fits with the stock suspension/alignment. What do you guys suggest? My preferred option was Apex FL-5's but they require camber plates then I was looking at the 513M wheels. but they are stupidly expensive.
I have been autocrossing for 4 years but this is my first year in the M2, and over the winter season I quickly realized that the MPSS are good, but no match for the likes of Conti's Extremecontact DWS or on warmer days the RE-71R.
Thanks in advance!
      04-03-2018, 05:05 AM   #95
USANigel
USANigel's Avatar
17
Drives: F87 M2 Long Beach Blue
2014 BMW X1  [0.00]
2008 Porsche Boxste ...  [0.00]
2017 BMW M2  [0.00]
Originally Posted by DOMs335D View Post
Hello Autox gurus,
Thanks in advance!
There is a good discuss of options here:
http://f87.bimmerpost.com/forums/sho....php?t=1419810
From what I’ve read, you can go with a wide variety of wheels (eg Apex), most suggest 18” is the way to go but tire sizes are limited in either 18 or 19 for 71Rs or BFG so you kind of need to know your preferred tires too.
I ran 71Rs at ~18 local Autox events last year on stock size 19” rims (I wouldn’t buy stock again ... at the time I couldn’t get confirmation 18” would fit, now I would go 18”). If you want to keep in BStreet class at SCCA, you need 9” and 10” wide, but local clubs other than SCCA may not care too much. 265 or 275 front and 275 rear seem to be a preferred option.
(You probably know this, but as soon as we add camber plates we lose BS class)
      04-03-2018, 08:28 AM   #96
DOMs335D
221
2017 BMW M2  [0.00]
Thanks for the feedback! I must have thought that both width and diameter are +/- 1", but of course that's incorrect. I am thinking of going with the same setup as the LBB M2 in the B-street thread. Only thing slowing me down at the moment is the APEX guy saying that it won't work
      04-04-2018, 02:09 AM   #97
USANigel
USANigel's Avatar
17
2014 BMW X1  [0.00]
2017 BMW M2  [0.00]
Check my 2018 B Street thread. I polled the drivers from last year's National championships. They were running stock 19"!
DOMs335D220.50
      10-18-2018, 12:56 PM   #98
z3papa
Just wanted to bump this thread and quote up after 2018 results. I guess Doug Rowse's 2nd place at Nat's and win at the Pro Finale pretty well put the discussion to bed.
      10-18-2018, 02:50 PM   #99
Old Geezer
Drives: 2019 M2C
Does anybody know what size tires Doug Rowse is running?
      11-20-2018, 10:27 PM   #100
HOT M
HOT M's Avatar
Drives: 2019 M2C
anything else you recommend for using phone for video?
2019 M2C Sunset Orange/Black (Ohlins/swift coilovers, Ground Control Camber Plates, Dinan Heat exchanger, BM3 ECU tune, CF mirror caps, diffuser and rear spoiler, Vorsteiner V-FF 101 Patina Bronze wheels)
      12-06-2018, 10:03 PM   #101
marcfs71
Drives: 2018 BMW M2
Autocross
SCCA Fastrack for December, 2018 has the following recommendations:
Recommended Items The following subjects will be referred to the Board of Directors for approval. Address all comments, both for and against, to the Solo Events Board. Member input is suggested and encouraged. Please send your comments via the form at www.soloeventsboard.com. Street Category #22582 Muscle cars to B Street? The SAC recommends the following proposal: Move from AS to BS: BMW M3 and M4 (F80/F82)(2015-18) Chevrolet Camaro SS 1LE (V8)(2017-18) Ford Mustang Shelby GT350 (2015-18) Mustang GT Performance Package Level 2 (2018) Nissan 350Z NISMO (2004-08) 370Z NISMO (2009-18)
Easier to read if you go to:
https://www.scca.com/pages/fastrack-news
I'm mostly concerned about the Mustang GT350. I'm also concerned about the Camaro SS 1LE. I don't think the other cars can run with the M2 but the american muscle cars definitely can with the right driver!
      12-08-2018, 05:10 PM   #102
NJ Drive
NJ Drive's Avatar
51
Drives: 2018 M2 LCI
I wouldn't worry about any of the super ponies or the other proposed cars outmatching or outpacing the M2. I support the move.
      02-08-2019, 08:39 PM   #103
Shadowfax028
Drives: 2016 BMW M235i
Just curious, where do you think the M235I should be classed?
      02-10-2019, 08:32 AM   #104
NJ Drive
NJ Drive's Avatar
51
Drives: 2018 M2 LCI
M235i looks like a solid DS entry.
