M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > M2 OG 255 Front, 275 Rear Tires on Stock Rims?
      11-06-2022, 09:35 PM   #1
MustRunFlatOut
Drives: 2018 BMW M2
Just returned from a weekend at VIR with my 2018 M2 on its original Continental Sport Contact 3 tires. Had some great runs, but these tires are nearly down to the wear indicators. Reasonably good performance with even wear, so no real complaints. However, I am considering going with 255/35 front, 275/35 rear tires on the stock 9 and 10 inch rims. Do any of you know if this tire size increase causes any clearance or handling issues? With track brake pads and high temp brake fluid, I believe the next biggest improvement for track runs is better tires of the Extreme Summer variety--no R compound as this is my daily driver.
I could use a bit better corner turn in and braking performance on track, and was hoping a slight width increase may help at both ends. Also, I would like to upgrade to the Goodyear Supercar 3 tires, but it appears those may not be available anytime soon. I suppose the Michelin SuperSport 4S tires are a good alternative. Any suggestions about my comments above?
Thanks!
      11-06-2022, 10:55 PM   #2
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.68]
I ran that tire combination on my M2 with stock rims. No problem. Tires we're Michelin PS4Ss.
      11-07-2022, 02:24 AM   #3
chris719
Drives: '08 M Roadster
Thanks!
You can run 255/275 with most tires. Some winters will rub. I would look into Yokohama AD09 for stock sizes if you want something that might still be streetable but above the PS4S. Disclaimer- I have not run this tire, but initial feedback seems good.
      11-07-2022, 03:12 AM   #4
MR RIZK
MR RIZK's Avatar
758
Drives: AW M2C
RE71rs in that size will rub the liners on a M2C lowered 20mm as the tire shoulders are quite square. Spacers I run are 10/5mm.
Heat gun for the liners and a slight trim from the rear bumper support tab is required.
I reckon with street tires clearance will be ok but haven't tested personally.
Maybe this thread will help
Increasing tire size from 245/265 to 255/275: any cons ? https://f87.bimmerpost.com/forums/sh....php?t=1468422
jefe2000739.50
      11-07-2022, 10:12 AM   #5
PackPride85
I ran 255/275 on mine with ps4s tires back in September at VIR with no issues. If you drive aggressively VIR will destroy the outsides of a 300tw tire pretty fast, especially left front in full course layout.
I'm switching to dedicated 18" square set with a stiffer 200tw tire for next season. Going to check wear and move into camber plates if needed.
      11-11-2022, 02:57 PM   #6
MustRunFlatOut
Drives: 2018 BMW M2
Guys, thanks for all your insight on tire sizes! Based on your responses, I will likely go with the upsize 255/35 Front, 275/35 Rear to replace the 280 tread wear Contis that came with the car and now need replacing. Interesting that sizes may vary somewhat with the same specs between tire suppliers. My son has been running Goodyear Supercar 3 tires on his near stock 2017 Camaro SS 1/LE and has been very happy with them, so I hope I can get a set of those. I know, different car altogether than my 2018 M2, but they have worn and performed well for him at the track... including at VIR, Watkins Glen, Dominion and NJMP tracks.
Thanks again!
      11-16-2022, 07:57 AM   #7
MannyM5
MannyM5's Avatar
197
Drives: 2016 BMW M2, 2001 Honda S2000
I'd go with the new Bridgestone re71rs in the 255/275 for street/track👍🏼
      11-17-2022, 10:39 AM   #8
booya_45
Drives: 2017 M2
I did this size for 2 years and worked fine. Went to 275/35/18 square setup after to stretch the tire durability, tire options, and cost.
      11-17-2022, 01:15 PM   #9
PackPride85
On stock suspension? I just bought my 18" 9.5 track wheels but wasn't sure if I could do 275 on stock suspensikn/camber. With 265 I had already planned on 5mm spacers up front.
      11-18-2022, 09:58 AM   #10
booya_45
Drives: 2017 M2
Thanks for asking. When I went down to 18’s, I ended up doing TCK DA’s with -3 camber up front and a wheel spacer as well. This was on a 9.5in wide titan 7 wheel.
      11-29-2022, 12:35 PM   #11
m2c_6mt
Drives: 2021 M2 Competition
I have the AD09 255/275/19 right now. Great street tire, very good grip from cold...steering feedback is improved. Sidewall is stiffer but not horrible. Tire noise is livable, probably quieter than RE71RS. Dry grip is slightly below RE71RS and A052 but a step up from PS4S for sure. Only place where they fall short is heat resistance if you're in a hot climate and autocrossing (or track racing, I assume) - they overheat pretty quickly, you can't over drive them.
      12-07-2022, 10:11 PM   #12
M2_MEDUSA
M2_MEDUSA's Avatar
Drives: 2021 M2 Comp. SpecialEdition
285/35/19 and 295/30/19 No problem on stock rear rim, I ran both, Running 265/30 and 295/30 all stock rims MPS4S
Instagram: M2_Medusa
Bee Pee1779.00
      12-08-2022, 07:00 AM   #13
Mavus
Mavus's Avatar
2030
Drives: E90 335i, F80 zcp
Thanks!
larger tire will not always increase your grip. you need to ensure the rims will provide sufficient support for tires when they are loaded in turns and are not bulging out under pressure due to undersized rims. As an example I used 255 on 9.5 rims re71 on my e90 with front camber at -2.5. The tire wear was even on track and front end grip was significantly increased.
Things you need to consider for track on dual purpose car: optimal rim and tire sizes for track, front camber, tire type. All 3 are needed to improve front end grip and turn in.
gl
      12-16-2022, 02:28 AM   #14
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Any photos ?
Are you running any mods ie spacers/suspension upgrades ?
Current '22 X3M LCI..
      12-17-2022, 07:58 AM   #15
M2_MEDUSA
M2_MEDUSA's Avatar
Yes,
Lowered on Eibach springs and 10mm spacer in the front.
      02-18-2023, 07:29 AM   #16
E90convert
Drives: F87 M2 DCT, F15 X5
I found this thread to be helpful. I am also looking at new summer tires in the spring and considering the 255-275 option on stock wheels. Car is my daily and will see a few track weekends per year. I am thinking A052, but concerned about treadlife compared to the PS4S. Can anyone share experience with treadlife on these tires? Interestingly, the 245/265 PS4S have a 0.5” larger tread width than the 255/275 variant. But the 255/275 has a slightly larger section width. Which really matters?
      02-18-2023, 10:40 AM   #17
///MPhatic
The Seeker
///MPhatic's Avatar
13863
Drives: OG M2 • Exige
You've really got to be kidding.
The A052 is a one-lap competition tire for rich boys.
The PS4S is a Summer tire that does everything.
Might as well compare a Ferrari to a Civic.
If you can afford an M2 you can afford both.
There is no tire that's going to beat the PS4S for a daily tire, keep your standard wheels for those tires then pick the track rat tire/wheel combo for the type of laps you'll be doing.
TW is more important than SW.
      02-18-2023, 11:01 AM   #18
E90convert
Not kidding, I'm genuinely interested in treadlife between the two. Am I going to get 1 season out of an A052 or 2-3 seasons? The PS4S wore great on my Z06 and Cayman and I got 3 seasons out of it (but both were not DD cars). I'm not sure if the A052 will wear a ton faster or not. Do you have some experience to share with DD/track on a 200 treadwear tire with the M2?
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport
Sold in 2023 '12 F30 335i 8AT Sport Line
Sold in 2020 '08 E92 335xi 6MT
Sold in 2016 '08 E90 335i 6MT - FBO
      02-18-2023, 12:35 PM   #19
///MPhatic
The Seeker
///MPhatic's Avatar
13863
How long a tire lasts depends on how you use it, and how frequently its used.
For longevity the 71RS is your tire for sure, it's also very friendly at the track. It's the king of 200 tw tires for sure.
      02-18-2023, 03:00 PM   #20
m2ss
m2ss's Avatar
1790
Drives: people crazy
Yes,
Are those 19" 763m wheels?
How low did you go?
2020 M2C
2018 M2 LCI
Gone 1M, 991.1, 991.2, 718S, 991.2 TT, R8 Spyder RWD
      02-18-2023, 04:34 PM   #21
///393
///393's Avatar
829
Drives: X6
Track tires for track. Street tires for street. 300tw already sling a F ton of rocks. 200tw super stickies are just silly to roll on the street. You’re not setting qualifying laps on public roads so you don’t need more grip than a 300tw PS4S delivers. Plus, once the 300tw start to wear and you get some movement, its funner than hell.
RT660 or RE71RS is the move for track tires currently, but, they’re for the track.
I’ve you’ve got the cash to burn you can split the difference with a Cup2 240 but it’s going to be compromising outright grip on track as compared to the RE71RS & RT660. Big believer in the right tool for each job, and that requires two tools.
      02-19-2023, 11:29 AM   #22
MooMooM2
MooMooM2's Avatar
1819
Drives: M2 Comp
and here I am... wanting less grip on my daily tire
But I agree, ps4s is a great daily tire, look no where else
