M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > First set of BBS FI-R 19x9.5 19x10.5 mounted on a BMW M2
      08-21-2018, 10:51 AM   #67
Raptor911
Drives: 2018 AW M2
The guy who started Titan7 use to work for Rays and is very well known in the industry. In fact the Titan 7 are strong since they are 10 ton pressed vs volk which is 8 ton press.
Originally Posted by z3lai View Post
Unfortunately Titan is made in China
In terms of forge technology, BBS/Rays/Hre are the best in industry
      11-05-2018, 12:50 AM   #68
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
Originally Posted by DetailersDomain View Post
I will be taking a look into this when the brakes go on, I may raise them a hair to see if that changes anything.
the rears are very low in fact I don't have the adjustable perches installed on the rear. as far as the fronts I believe we are at the bottom as well.
Hi DetailersDomain,
By not installing the adjustable perches, were you in fact even lowered by more than MP's lowest which is 20mm(3/4")? I remember the MP perch seems to be 5~10mm itself?
Also, from your comments I think you only rub in the front not in the back?
Really you're the only source I've heard FIR rubs with 255/275mm. I have a M2 FIR friend MP lowered who is due for a tire change. He wants to go a bit wider to 255/275 but is really concerned when I told him your rubbing story. Asked me to check with you.
Thanks.
Lemania 2320
Tags
bbs fi-r, bmw m2, detailersdomain
