M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Blew my turbo on ots??
      02-08-2024, 07:59 AM   #1
Shawqi90210
Drives: E92 M3
So yesterday I was driving around I ran into a x3m on the road we started to play around a bit for fun and we came to a light and I did a launch control car took off completely fine and right after I left 3rd car made a weird noise and it sounded so wrong car went into neural and turned off. I pulled over car was smoking white. I let it sit and tried staring it again it cold started just fine the second the rpm drops it wants to die.
I know I shouldn’t have started it but the car had no codes at all so I was super confused. Eventually I towed it home and immediately started to get to work. I removed the inlet and behold my turbo was shredded.
Car has 40k miles and for it to blow the turbo on a ots map is insane to me. A it’s map isn’t even aggressive. How would a stock turbo even blow on ots.
Anyway I’m not too mad because I have a 750 just laying around bc I was planning on swaping it out but definitely not this fast car has only been tuned for less than 20k miles.
Any ideas on why ots would blow my turbo??
      02-08-2024, 08:05 AM   #2
ThreeStripes
Drives: X3M
What tune and fuel?
      02-08-2024, 08:08 AM   #3
Shawqi90210
Drives: E92 M3
Originally Posted by ThreeStripes View Post
What tune and fuel?
Bm3 stage 2+ e30 and I measure the e content my self every time and make sure it’s mixed right
      02-08-2024, 08:22 AM   #4
ThreeStripes
Drives: X3M
If you’re not running a fuel filter, and running E85 blends, injectors foul from the contaminants and eventually fail which can f@ck stuff up real bad from lean events.
My money is on that’s what happened here. Bolt that P750 on, get a bend calibration flex fuel kit with the Bosch filter, and have them custom tune it.
      02-08-2024, 09:55 AM   #5
M2guru
2018 BMW M2  [10.00]
Dissect the turbo to understand what happened. Did the shaft break? Oiling problems? Nut(s) come loose? Here is mine: https://f87.bimmerpost.com/forums/sh...7&postcount=69
      02-08-2024, 10:08 AM   #6
Shawqi90210
Drives: E92 M3
Yea that would probably do it to be honest ima dig a bit more see what happened but still surprised it would blow the turbo only on my 3rd tank of e30
      02-08-2024, 10:10 AM   #7
Shawqi90210
Drives: E92 M3
That’s a good idea when I find time I’ll take it all apart to see what really happened I can only see the front damage haven’t even pulled the dp yet I just wanted to see if it was the turbo or I blew my motor
      02-09-2024, 01:52 AM   #8
samsamdar
samsamdar's Avatar
Drives: OG M2
2018 BMW M2  [6.67]
I had my DS25 HPFP and a couple injectors fail not long after running E85 without the bend filter kit (maybe 6-7 tanks worth of full E). I got lucky that I wasn't pushing the car hard when my HPFP and injectors failed and I turned the car off immediately. Highly reccommend you get the Bend filter and lower the E content unless you have an upgraded HPFP AND LPFP.
      02-09-2024, 01:57 AM   #9
samsamdar
samsamdar's Avatar
Drives: OG M2
2018 BMW M2  [6.67]
Also highly reccommend you check the injectors and HPFP for functionality. You can tell if HPFP failed by logging pressures and you can check injectors by pulling the spark plugs and cranking the car to see if any fuel comes out. If fuel comes out of the spark plug holes, then you know your injectors are stuck open.
      02-09-2024, 04:39 AM   #10
M2guru
2018 BMW M2  [10.00]
I'd be very surprised if fueling had anything to do with the turbo failure. The turbo doesn't know fuel - only air and oil.
      02-09-2024, 10:56 AM   #11
TheSandman_M2
TheSandman_M2's Avatar
68
I don't think you should run that map with a stock turbo.
6speed_M23633.50
      02-09-2024, 10:58 AM   #12
Shawqi90210
Drives: E92 M3
Only thing it says is hpfp and dp and intercooler which I already put beofre using that map
      02-09-2024, 11:01 AM   #13
mike@x-ph.com
mike@x-ph.com's Avatar
Without data logs, it's all speculation.
It could be as simple as a boost leak, making your turbo spool a lot more to achieve a target boost until it finally fails.
What we know for sure, with the correct mods, fuel and healthy turbo, the boost target of OTS maps are well within the safety margin
https://x-ph.com/sale/
Phone number 702-494-9435
VGSON210.00
      02-09-2024, 02:04 PM   #14
M2guru
2018 BMW M2  [10.00]
I respectfully disagree that it's all speculation. As suggested, if you disassemble the turbo, you'll get a look at the bearings and other parts that can tell you what happened.
      02-09-2024, 03:00 PM   #15
mike@x-ph.com
Maybe you misunderstood my previous response.
To clarify in simpler terms, it's impossible to determine what went wrong and what caused it based on the currently available information.
Even if you disassemble the turbo, you might not know what caused the failure. You will see the end result, but what leads up to it might be more challenging to determining without datalogs
mikerunt306.00
      02-09-2024, 03:08 PM   #16
VGSON
VGSON's Avatar
210
Drives: F87 OGM2
I wouldn’t suspect fuel/tune..more so a failure from foreign object, failed bearings causing side to side play, oiling…
M2guru383.50
      02-11-2024, 04:13 PM   #17
TheSandman_M2
68
it hits 20-21psi, a little to much for the stock turbo.
      02-11-2024, 04:17 PM   #18
ThreeStripes
Drives: X3M
Good feedback. Leaving my prior inaccurate speculation above as a PSA on E85 though.
      02-11-2024, 10:47 PM   #19
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
Maybe it didn’t “blow” on the OTS map but finally gave out while on the OTS map.
      02-18-2024, 09:25 PM   #20
Shawqi90210
Drives: E92 M3
Haven’t got to really dig deep in the car yet I’m ordering everything I need for the swap and fueling to keep up with the boost. I was wondering how can I fully flush my oil because I’d assume metal probably went through and is probably sitting in places it shouldn’t. So already know I need to check my intercooler and charge pipe, but oil wise how do I flush the whole system out to get as much as I can out ?
      02-19-2024, 04:32 AM   #21
M2guru
2018 BMW M2  [10.00]
It likely does depend on the cause a bit. For me, when my turbo shaft broke, I didn't run the car but for maybe a mile or two afterwards (as I tried to diagnose the issue while being 2.5 hours away from home). After I found out it was the shaft and found a bunch of oil in my intercooler (quarts!), I checked the oil filter. There was obvious journal bearing material on the outside of the filter. I don't think any of it made it past the filter. So from the turbo, the oil goes to the pan and from the pan, to the filter.
I did send a sample of oil in to Blackstone of the oil from the intercooler.
I tried to clean the oil from the filter housing as best I could. Then I poured about a quart of oil into the housing (hoping it would flush anything to the pan). I also sent about 3 gallons of oil in the oil fill hole and then drained the oil after each one in an attempt to flush out the pan.
What I did next was to prime the oil system after filling it up with about 3 quarts of oil. I then drained that oil.
Where I sit now is with about 1 quart less than normal in the car and I have driven about 100 miles (max). I used this oil to try the new tunes. I will drain and refill and add a new filter before I drive it again and I'll consider it good. I'll send the 100-mile oil into Blackstone and the oil I will put into it after normal (track) use to see what it shows.
I hope that helps. I was debating dropping the pan and bottom end to check things out, but the more I thought about the path of oil and that the filter should have stopped anything, I felt that was more insurance than I wanted to "pay."
      02-20-2024, 10:57 PM   #22
Shawqi90210
Drives: E92 M3
I hope that helps. I was debating dropping the pan and bottom end to check things out, but the more I thought about the path of oil and that the filter should have stopped anything, I felt that was more insurance [...]
This helped a lot!!! I wanted to know how to flush the oil. I will for sure do the same process.
I was wondering for the oil I just use to flush do I really need to use my regular oil I use or can I just get cheap oil to flush the system but drive on my normal oil that I use for the car ?
