05-20-2018, 04:32 PM | #23 |
Rep 305
Hey guys reviving this thread...
Have had my Ohlins + GC camber plates installed last week and since the install, the tire/road noises/NVH have gone up 2-3 fold... Car is headache inducing right now on the highway with that wind/tire/road echoish sound in the car. I have no clue if it's the lower stance or the increased camber causing such noise, because it is present also at mid speed. I checked my tire pressure and it was a bit too high (38-40 PSI) so I reduced it and it didn't change anything. I have a hard believing it is only the new camber plates causing that much change in the road noise. Everything appears to be tight and well installed. I checked my alignment sheet again today and noticed the toe seemed to be quite high... Could that be the cause of the excessive tire noises? Thanks for the help! |
05-21-2018, 03:26 PM | #27 | |||
Rep 305
I'm a bit clueless... The suspension rides beautifully, no clunk or anything, bumps modulation is great, but there is always that noisy tire sound resonating in the background in the cabin. It appears at 50-70 km/h and is irritating at 120 km/h. Guess I'm too sensitive for camber plates... Will have the alignment corrected, double check that every part/bolt is tight and swap for OEM top hats if nothing changes... Last edited by S1monQc; 05-21-2018 at 04:54 PM.. |
05-21-2018, 03:39 PM | #28 |
Rep 305
I also ordered seals for the front doors to isolate the sound coming from the tires...
See this post/thread about sound deadening: https://f87.bimmerpost.com/forums/sh...&postcount=123 https://www.2addicts.com/forums/show...34&postcount=1 Since the tires are rolling outside the fender area (-2,4 camber and 10 mm spacers), I think it's not a bad idea to seal the area between the fender and the doors... Simon |
05-21-2018, 09:26 PM | #29 |
Rep 305
After some more digging tonight, I noticed some interesting things about the plastic/rubber spacers supposed to be in place around the springs front and rear.
Here is Ohlins manual front and rear: #6 for front and #4 for rear have the same part number (rubber spacers) #4 for front and #8 for rear have the same part number (plastic spacers) Well here is the pics of my coilovers: Rubber spacer is in place, but... I don't see any plastic spacer at the bottom... Same situation at the back... There is no spacers at the top of the springs, so the spring is straight on the lock ring... Will get in touch with the shop and Ohlins to ask for some more spacers... If possible all rubber... |
05-23-2018, 06:10 PM | #31 | |
Rep 570
I'll look at the suspension and see about the rubber spacers. Here is my full kit, pre-install. |
05-24-2018, 02:27 PM | #32 | |
Rep 305
Shop said the provided spacers were all installed... And that does match your picture with only 1 kit of rubber spacer at the front and 1 kit of plastic spacers at the back. Basically Ohlins instructions aren't good and the instructions PDF has multiple revisions with different informations... Not very happy with Ohlins for that one... I will have my alignment corrected with 0 toe and maybe reduced camber up front (-2 instead of -2,4) and if I get tired of the sound, will put back OEM plates. Everyone I consulted are telling me the sound comes from the camber plates and I wish I had Vorshlag plates on hand to try these, but dunno if it's worth the $$ and hassle to have these swapped to maybe have noise reduction |
05-24-2018, 09:29 PM | #33 |
Rep 221
Something is not right man.
I have the exact same setup as you and had 0 additional noises or NVH unless I hit a massive pothole the front will crash more than the stock rubber mounts. But that's only on a pothole big enough to make you cringe slightly. No new noises / added harmonics at any speed. Also running -2.5 up front on 19/19 stock tires. |
05-25-2018, 12:34 PM | #34 | |
Rep 305
Why does it only happen to me lol |
05-25-2018, 02:11 PM | #35 | ||
Rep 190
Alignment specs: -2.5° Camber Front 0 Toe Front -2.0° Camber Rear 1/16" Toe in Rear Mostly smooth to smooth roads are same/similar to stock for NVH but roads with really rough surface have a decent increase in what sounds like tire/road noise. Moderate condition roads have a slight increase in this road noise but not really noticeable. No clunking on bumps other than big potholes as other have mentioned. I have the supplemental door seals already. I am sensitive to increase in NVH and I did an 8 hour round trip the day after my alignment/corner balance. It didn't drive me crazy so I guess I would say any NVH I have noticed is minimal. EDIT: This is with brand new Michelin Pilot Sport 4S tires as well.
:::: 2017 AW M2 :::: (SOLD)
05-25-2018, 03:05 PM | #36 | |
Rep 305
05-25-2018, 05:41 PM | #37 |
Rep 305
05-28-2018, 10:46 AM | #39 | |
Rep 305
I noticed the echo high piched sound gets more significant while braking. I have my alignment friday, will report back after! I'm looking at sound deadening options, hopefully that will bring back the sound pre-camber plates! |
05-29-2018, 08:27 PM | #40 |
Rep 570
Here are mine
Ohlins R&T and Vorschlag Plates Corner balanced Car is street driven with 10 track events per year - hence the -2.0 front. Toe is minimized as much as possible F and R |
03-14-2020, 06:12 PM | #42 | ||
Rep 4,525
Mine went to -1.8 upfront with MPerf coilovers and then -0.5 camber correction hub swivels got me to -2.25 upfront. I run -1.5 rear camber and traction/grip is much better.
Current '22 X3M LCI.. |
WoodyOGM21.50 |
03-23-2020, 11:53 AM | #43 | |||
Rep 796
05-21-2020, 03:24 PM | #44 |
Rep 450
Just got my alignment done after adjusting ride height and adding spacers. They told me that they can't get any better on the rear toe without increasing camber? Seems like a lot of rear toe. I see gsrbri just above with same camber but much better toe. Shop being lazy or is what they're saying true? I'm running KW V3.
