12-07-2023, 10:42 AM | #1 |
Rep 908
Drives: 2018 M3 Competition
Brake fluid service needed?
My car is telling me I need a brake fluid service already. 34 months and 7,200 miles in.
I’m not trying to skimp on maintenance of the car, but is this just a time based notification or does the brake fluid really need to be changed? I’ve never had this done on a car less than 5 years old and certainly not one with less than 10K miles. I do some spirited driving but no tracking and mostly commuting or cruising around town. |
12-07-2023, 12:03 PM | #2 | |
Rep 50
mfarrzhp1500.00 Thefog_M2CS91.50 |
12-07-2023, 12:06 PM | #3 |
Rep 6,981
Drives: 2018 M2 AW DCT
First brake service is at 3 years. Subsequent brake services are at 2 years. It is time dependent not based on mileage.
Note: Time is based on production date not on in service date.
12-07-2023, 12:20 PM | #4 |
Rep 126
Also had the brake service due at 5k miles, went to the stealership and paid $480 for oil change and brake fluid. Not exactly sure how thorough their brake fluid service is, but I will be using an Indy going forward as I did with all my previous Porsches/bmws.
mfarrzhp1500.00 |
12-07-2023, 04:35 PM | #5 |
Rep 900
Drives: F87 M2CS
The brake fluid should be based more on time rather than miles as I believe it's because you can get moisture in there overtime. If it's been almost 3 years you should just go ahead and service it. It's not super expensive. I just did it on my E92 with motul rbf for like $20 a bottle and my indy charged $100 for the labor.
The CS, I had it done this summer under maintenance coverage which runs out December. Thought about squeezing another oil service but the car still says another 5k miles so dealer didn't cover, kind of annoying. The car will not be driven for the winter anyways so I'll just do one in the spring. I usually do oil every 5k miles so. With this car, I'd do an oil service with the indy shop and not reset the counter so 5k miles later the dealer would cover another when the car triggered it. Now the CS will only be going to my indy shop along with the m3. The simpler things like spark plugs/coils I do myself. The fluids for me is just a hassle to dispose of so that's why I just take it to the indy
MY18 F82 M4
Austin Yellow / Black / DCT / MPE |
mfarrzhp1500.00 |
12-07-2023, 05:12 PM | #6 | |
Rep 908
I’ve owned (or leased) many cars over the past 25 years, but only 2 or 3 of them have made it past the 3 year ownership mark for me and I don’t think any have made it to 4 years. This one’s a keeper. |
ShaknBak114.00 |
12-07-2023, 05:17 PM | #7 | |
Rep 900
Drives: F87 M2CS
MY18 F82 M4
mfarrzhp1500.00 |
12-07-2023, 05:21 PM | #8 |
Rep 908
Okay, good to know thanks. I leased an F80 Comp right before buying the CS and an F30 lease prior to that, 135i before that. None of them needed the brake fluid changed in the 36 month leases.
I’m done with leasing and hanging on to my cars now that I’m getting older, and BMWs have peaked in my opinion. |
12-07-2023, 09:35 PM | #9 |
Rep 126
I was under the same impression. My Cs also was covered under the maintenance plan, however the dealer told me it costs $700 to transfer it since the car is a 2020 and it's expiring soon. So I had to pay regardless. Not sure if others had a different experience buying a used Cs.
12-07-2023, 09:57 PM | #10 | |
Rep 507
Drives: 2018 M2 6MT
Brake fluid is hygroscopic. It attracts/absorbs moisture from the air. Water in your brake fluid is a bad thing. The solution is to flush and replace with fresh fluid. If you want to monitor the water content of your brake fluid, you can purchase a device that will measure this. Here’s an example on Amazon: https://www.amazon.com/gp/product/B0834PVSBT |
12-08-2023, 01:52 AM | #11 | |
Rep 900
Drives: F87 M2CS
MY18 F82 M4
12-08-2023, 09:57 AM | #12 | |
Rep 6,981
In 2017 BMW stop the maintenance transfer.
Reddevils71078.50 |
12-08-2023, 10:06 AM | #13 |
Rep 21
FWIW my service guy at the dealership said that you can transfer it now, and the cost was $100. That's what I was told when I took it in back in April for a recall/ECU update.
I have the same brake service message (as I suppose we would all be getting around now) and will be taking it in on Monday. We'll see if they really can transfer the maintenance plan like I was told. I'll report back. |
12-08-2023, 10:13 AM | #14 | |
Rep 900
Drives: F87 M2CS
Within the warranty period, all the records get synced centrally but the SA won't give you a paper copy, you can only look at it. After warranty, the records stay at each location where the work is done. I did the same thing with my E92 recently. I could see the first 4 years then nothing, even though the previous single owner only took it to BMW. I could see it on the Carfax
MY18 F82 M4
DanG10848.00 |
12-11-2023, 03:41 PM | #15 | |
Rep 21
12-12-2023, 03:21 AM | #17 |
Rep 900
Drives: F87 M2CS
Is it the carbon filter that's underneath the top lid cover of the air boxes? I know the US cars have them but euro don't to the best of my knowledge. It's the first thing I removed in both of my F8x cars
MY18 F82 M4
12-12-2023, 03:33 AM | #18 |
Rep 163
Brake fluid done last month, nil cost.
But I am in Oz. Service plans also transfer with the car, so our plans may be a bit differently structured to US. *edit to also note- have traveled approx 6000 miles, no track* Last edited by Beenz; 12-12-2023 at 03:35 AM.. Reason: Add more detail |
