10-23-2023, 05:49 PM | #2 |
The Seeker
14191
Rep 3,426
If you're wanting that much, contact Plated, they have the best spacers out there.
https://www.425motorsports.com/catal...lanted+spacers I raised mine with some bolts from McMaster and some aluminum spacers. |
10-23-2023, 06:41 PM | #3 |
Rep 569
I’m curious why you guys are raising your seats when the rest of the world seems to think the 2 series is too tall and upright
10-24-2023, 10:19 PM | #5 |
Rep 3,102
Drives: 21 Vantage, 18 Vantage, 00 WRX
The seats in the CS are lower than those in the C.
I’m tall so no problems but if you are shorter I could see why. |
F87EVO4062.50 |
10-25-2023, 01:48 AM | #6 |
Rep 1,233
Drives: BMW F87 M2 CS (6MT)
Really? are the lower that the comp?
Sometimes, the simplest recipes, done well, with quality ingredients, are the tastiest, - evo Car of the Year 2020
2020 BMW F87 M2 CS - 6MT - Misano Blue Metallic |
10-25-2023, 09:01 PM | #8 |
Rep 3,102
F87EVO4062.50 Reddevils71078.50 |
10-26-2023, 01:23 AM | #9 |
Rep 1,233
weird , but good to hear. Im 1.80m and the driving position is perfect !
2020 BMW F87 M2 CS - 6MT - Misano Blue Metallic Last edited by F87EVO; 10-27-2023 at 02:02 AM.. |
10-26-2023, 06:12 AM | #10 |
Rep 3,361
Yeah, if you measure them and/or investigate it closely, that's not the case. The seats are the ZCP ones from the M4, and the bases on them are identical to the non-ZCP seats...as in identical part numbers. Only the backrest is changed for the ZCP/CS seats. The parts for the lower frame, padding, and seat cover are all identical across the board.
Current Stable:
F87EVO4062.50 |
10-26-2023, 08:13 AM | #11 |
The Seeker
14191
Rep 3,426
10-26-2023, 04:44 PM | #12 |
Rep 897
Drives: F87 M2CS
I'm 5'7" and I keep the seat all the way lowered and no issues. Personally myself, I like sitting lower with that gocart feeling. Ngl, when it gets sketchy in parking garages, etc. I will lean forward just to be safe and make sure I'm seeing everything. But having front pdc definitely makes life easier too
MY18 F82 M4
Austin Yellow / Black / DCT / MPE |
10-26-2023, 08:58 PM | #13 | |
Rep 3,102
10-26-2023, 09:21 PM | #14 | |
The Seeker
14191
Rep 3,426
Reddevils71078.50 |
10-27-2023, 05:14 AM | #15 |
Rep 3,361
It's not different. At least in the three CS' I've seen alignment results from...they all are spot on spec for the M2C at -1.5 +/- 0.5 degrees. The actual spec is in degree/minutes -1°29' +/-0°30'. For a while, people suspected BMW used the camber correction hubs available which add 0.5° negative camber, but no completely stock CS has ever shown -2.0°.
Current Stable:
///MPhatic14191.00 |
10-28-2023, 12:06 AM | #16 | |
Rep 3,102
10-28-2023, 07:56 AM | #17 | |
Rep 142
extract german car magazine road test on m2CS front toe in 0'06" camber 1'48" - respective ranges 0'02" to 0'18" & -1'14 to -1'44" rear toe in 0'16" camber 1'24" - respective ranges 0'10" to 0'22" & -1'35 to -2'05" Std M2/M2C alignment ranges:- front (nominal) toe in 0'05" & camber -1'29" - respective ranges -0'01" to 0'11" & range -0'59 to -1'59" rear (nominal) toe in 0'08" & camber -1'50" - respective ranges 0'02" to 0'14" & range -1'30 to -2'10 |
MDuckie96.00 |
10-28-2023, 12:14 PM | #18 | |
Rep 3,361
So BMW is saying the CS has a nominal front camber value that is 19 minutes more negative? 19/60 = 0.3 degrees, so CS should show -1.8 on the rack versus -1.5 on the M2C. How did they obtain that since the camber correction hubs add 30 minutes of negative camber (i.e. nominal value 1'59" afterwards). And if so, why are CS owners posting alignment results such as this one with almost spot on 1.5 degrees (1'28"L, 1'32"R) which is the same as the M2C?
Current Stable:
10-28-2023, 12:25 PM | #19 |
The Seeker
14191
Rep 3,426
