03-09-2023, 12:43 PM | #1 |
Rep 22
Drives: 2018 BMW M2
Spark Plugs & Ignition Coils
Hello everyone,
I have recently gotten some pretty aggressive misfiring from my car. Extremely rough idling that continues through throttle acceleration. My research through forums leads me to believe it is spark plugs or ignition coils (or both). I have replaced my spark plugs fairly recently but have not done my coils. I thought it may be a tune issue but after flashing back to stock the problem still persists. I've always had my mechanic take care of it but he is booked up for a while and this is my daily driver. I'm not sure what brands of plugs, coils and gap setup to go with. Through reading I've found BM3's recommendation of gap may not be the best way to go. Here are my listed mods: Wagner Catless Downpipe ER Charge Pipe BMC Drop in Filter CSF FMIC BM3 |
03-09-2023, 12:56 PM | #2 |
Rep 22
Drives: 2018 BMW M2
Forgot to mention:
I am running BM3 OTS Stage 2 91 ACN My mechanic mentioned he put 1 step colder as I was planning to track the car. Not sure what gap he used previously. Misfire codes attached above. |
03-10-2023, 08:57 AM | #3 |
Rep 643
seems like multiple cylinders are misfiring, so less likely it is a bad coil. perhaps bad gas?
but if it is a bad coil, switch the good ones with the bad ones and see if the misfire moves with the bad coil
M235i rwd 6mt
11-12-2023, 10:38 AM | #5 | |
Rep 8
Hey guys, talking about Brazil here! Yesterday I had problems with my Precision Raceworks coils, the car ran normally... I stopped to change the spark plugs as soon as we finished the service, I went out for a spin with the car, unfortunately the M2 when it was going up to 5 thousand RPM or 6 thousand RPM it failed, I was disbelieved... I thought I was unlucky that the spark plugs were bad, it could happen. To my surprise, it was the coils, as I returned the old spark plugs that still worked... and the car didn't return to normal. I removed the coils and put in the OEM ones I have in storage and magically the car returned to normal. I don't understand, I put the precision raceworks in and it gives me a problem. Can someone help me!!??? My friend had the same problem. Fala galera, falando do Brasil aqui! Ontem tive problemas com as minhas bobinas da precision raceworks, carro funcionado normal... parei para efetuar a troca das velas assim que terminamos o serviço, saí para dar uma volta com o carro, infelizmente a M2 quando subia giro 5 mil RPM ou 6 mil RPM ela falhava, fiquei desacreditado... Achei que tive o azar das velas estarem ruim, pode acontecer. Para minha surpresa eram as bobinas, pois retornei as velas antigas que funcionavam ainda... e o carro não voltou ao normal. Tirei as bobinas e coloquei as OEM que tenho guardadas e magicamente o carro voltou ao normal. Estou sem entender, coloco as precision raceworks dá problema. Alguém pode me ajudar!!??? Meu amigo teve o mesmo problema. |
11-15-2023, 05:48 AM | #6 | |
Rep 15
Tags |
ignition coil, spark plug |
