M2 Technical Topics > Track / Autocross / Dragstrip > Track Pad knock - PFC08
      06-21-2017, 01:44 PM   #1
dvas
dvas's Avatar
518
I'm running PFC08s on all four corners and have had no issues thus far on track - good initial bight and excellent modulation. Other than lots of break dust and squeal, these have been great.
My question is: Is it normal to hear/feel the pads knock into place whenever changing direction from forward to reverse? For instance, they knock into place whenever I apply the brakes after having just previously reversed the car and knock into place while reversing and applying brakes after having gone forward previously.
I assume this is normal and a non-issue but just wanted to check the collective wisdom here. A buddy running these pads on an E92 M3 noticed the sound and said that he doesn't get the same phenomenon - although I understand his car has a different caliper design. Thanks.
      06-21-2017, 01:54 PM   #2
MagnusT
MagnusT's Avatar
Sweden
538
I run Pagid RS29 and have the same problem. I first thought it was a mistake on Pagids part that they got the backing plate dimensions wrong. But it's the same on both front and rear pads. And I read somewhere that they are made slightly to small to prevent getting stuck when expanding due to heat.
PS: Do you mean you are running PFC08? Or FCP??
PPS: I get really strange looks from people on the street when the car does this loud knocking sound
dvas518.00
      06-21-2017, 02:15 PM   #3
dvas
dvas's Avatar
518
Yeah, meant PFC 08s, edited.
I get a lot of looks too on the street. People always seem to be looking for a 16 wheeler.
      06-21-2017, 02:41 PM   #4
nd2002
nd2002's Avatar
179
Drives: 2017 M2
Carbotechs here, same issue. Normal, it seems.
dvas518.00
      06-21-2017, 06:08 PM   #5
ben_lzn
Drives: 2011 135i M pkg
I'm running PFC 08s as well and they do the exact same thing and it is totally normal.
One thing to note is that they got much quieter past my first track day. Still squealing a bit once in a while but absolutely acceptable for daily driving.
dvas518.00
      06-23-2017, 08:52 PM   #6
trj3
trj3's Avatar
47
I have the 08s mine do it. Just use them at track. I will look when I take them out to see if there is any damage to the sides of the pads from knocking.....
2017 BMW M2 PE MT
2006 Z06
2004 Miata
      06-23-2017, 09:41 PM   #7
Twt
Twt's Avatar
634
Drives: 2017 M2
Same issue...pads are great on track and acceptable for street.
      06-24-2017, 01:19 AM   #8
greasypeanut
Drives: F87
after i removed my pfcs08 i didnt notice any damage on anything. just some blue paint missing from my bad aim with a hammer on those pins lol.
to the OP, mine knocked as well. also the squeal was god awful on the street. they only lasted a day after my track day before i had to take them off.
      06-26-2017, 11:34 AM   #9
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
Yes
