M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Tire warranty
      06-13-2017, 09:45 AM   #1
iceboss23
Drives: 2016 M2
Tire warranty
Are original manufacturer tires replaceable under warranty? If so do I just contact the dealer? Anyone with any experience here would love to hear how this works. My tires are worn at 17k.
      06-13-2017, 10:43 AM   #2
AGM2
AGM2's Avatar
Drives: M2 LBB 17
They don't warranty worn ,, only flat if you got the extend warranty !
I got the warranty for the tires and rims
      06-13-2017, 11:15 AM   #3
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
LOL 17K miles and you want them warrantied? Most people get like 1/2 to 1/3 of the miles on the oems.
Msmall143270.00
      06-13-2017, 11:29 AM   #4
lax01
Drives: 2017 M2
Assuming Michelin Pilot Super Sports, read the Michelin Limited Warranty document here: http://media.michelinman.com/content...6_REV_0716.pdf
This is also assuming you did not buy the optional Tire Protection plan from your dealer.
      06-13-2017, 11:42 AM   #5
lax01
Drives: 2017 M2
MPSS should have warranty till 30k
      06-13-2017, 12:13 PM   #6
ZM2
Drives: 2017 LBB M2
I believe 30k gets cut in half for staggered setups.
Msmall143270.00
      06-13-2017, 12:40 PM   #7
iceboss23
Drives: 2016 M2
According to this, because we have a staggered setup, the rear tires are covered to half the mileage but the fronts should have the full 30k. That said it does require even wear across the width of the tread and mine are not even.
Thanks for the link.
      06-13-2017, 12:41 PM   #8
iceboss23
Drives: 2016 M2
and if you wear them evenly you can get fronts replaced for half the cost. Read the warranty.
      06-13-2017, 12:42 PM   #9
iceboss23
Drives: 2016 M2
Yeah not the one you pay for at the dealer but the Michelin warranty associated with the 300 tread wear rating.
      06-13-2017, 06:01 PM   #10
Deutsches Blut
82
Drives: 2012 335i E92 M Sport / 2008 C
Correct. Reason being staggered = no rotation and rotations are part of the maintenance of a tire and in most cases is required to receive mileage warranty.
      06-13-2017, 06:06 PM   #11
Deutsches Blut
82
17K on Michelin PSS or Continental OE tires tells me your not driving the car they way it should be. And by that I mean, you must be driving pretty conservatively. Are fronts worn as well?
      06-14-2017, 08:19 AM   #12
iceboss23
Drives: 2016 M2
Hah fair enough. I have 8 track days on them and a ton of freeway miles so actually I'm pretty happy with how long they've lasted. Add to that that the tread is still pretty good but I just have the driver's front showing cords on the shoulder from this last track day. Needed more pressure or camber plates.
      06-14-2017, 05:28 PM   #13
ZM2
Drives: 2017 LBB M2
Cosmos and the other guys (and me) will tell you pressure isn't enough. Camber plates are needed for the track. RRT in Dulles, VA does all my work. Great shop.
      06-14-2017, 06:23 PM   #14
Deutsches Blut
82
You are driving it properly. You did well at 17K. And no dealer will give you warranty with belts showing. Maybe try Michelin 4S next for comparative mileages. They are supposed to give better mileage than the PSS.
