M2 Technical Topics > Track / Autocross / Dragstrip > Monitoring Engine Vitals on iDrive Display
      05-24-2017, 08:58 AM   #1
BAN_M2C
BAN_M2C's Avatar
4155
1987 BMW 325is  [10.00]
2004 BMW X3  [6.50]
2018 Porsche 911 GT3  [10.00]
1974 BMW 2002tii  [10.00]
2004 BMW M3  [10.00]
I am sharing this info out confirming I was able to code under Expert Mode the screen sharing for Android. I use iPhone's but have always had an Android around to use Torque which displays lots of info needed.
This will help on track days.
Searching around I found the following list of parameters which I coded in Expert Mode using the BimmerCode APP. Thanks to Almaretto and Gabrola
I coded all these parameters to be aktiv and now my iDrive menu is showing the Screen Mirroring option.
Had trouble initially connecting the phone but it was because its an older Android, tried with Galaxy S6 and S5 and it works.
Did mine using Bimmercode app.. It wasn't all straightforward to find but in expert mode under the display module I just typed in the parameters and the Bimmercode app narrows them down for you, then set them to aktiv.
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii
      05-24-2017, 10:46 AM   #2
ZM2
Drives: 2017 LBB M2
That's killer. Can you still run background apps like BMW Laptimer while this is active? If so, do you have more detailed instructions for some of us newbies?
Thanks!
      05-24-2017, 11:56 AM   #3
BAN_M2C
BAN_M2C's Avatar
4155
2004 BMW X3  [6.50]
2004 BMW M3  [10.00]
Thanks!
I just did this yesterday and tested more this morning so more testing on other apps needs to be done and I can report out.
I dont use M Laptimer since I actually have the Performance Analyser but that uses an OBD2 dongle so I cant use them together.
I have been in contact with the Performance Analyser developers to suggest letting the app display many of these parameters together this way I dont have to resort to this solution and still be able to record my runs.
I understand Torque allows recording vid also so I will try it.
I do believe you can still run apps in the background, I will confirm by running Music apps while mirroring this and see if the audio still runs thru the cars speakers.
Follow me on IG
Mr 294.00
      05-24-2017, 10:21 PM   #4
Twt
Twt's Avatar
633
Drives: 2017 M2
Great job...just download the MLaptimer app and try to run it through the screen...you will free up the OBD2. I do run the Laptimer on track while my iPhone displays info from the ELM OBN scanner to my FourStroke app.
BAN_M2C4154.50
      05-25-2017, 06:13 AM   #5
BAN_M2C
BAN_M2C's Avatar
4155
2004 BMW X3  [6.50]
2004 BMW M3  [10.00]
Will do that! If this turns out to give me all I need I will sell the Performance Analyser then.
I found a thread on the e90 forums about custom Torque PIDs and someone put ont together for a 335. Need to read more about using those customs PIDs.
Follow me on IG
      06-08-2017, 09:47 AM   #6
Bee Pee
1738
Drives: AW M2 DCT
[img]https://scontent.xx.fbcdn.net/v/t31....71&oe=59BA1A7B[/img]
[IMG]
View post on imgur.com
[/IMG]
OP,
Good work.
For a JB4 user controlling Jb4 via BT on android JB4 app, would screen share work so JB4 app display - see below - shows on idrive ??
BP
Fettled M135i EB AT - gone but not forgotten:
AW M2 DCT
      06-08-2017, 09:52 AM   #7
BAN_M2C
BAN_M2C's Avatar
4155
2004 BMW X3  [6.50]
2004 BMW M3  [10.00]
[IMG]
[/IMG]
OP,
Good work.
BP
I understand it will. Basically anything you see on your Android screen you would replicate on the iDrive screen so the JB4 app would be seen on iDrive.
Follow me on IG
      06-29-2017, 10:38 AM   #8
CosmosMpower
CosmosMpower's Avatar
2049
Drives: F87c, GT3, MK7 GTI
Does M laptimer show oil/water temps? I use AIM solo for timing but I wouldn't mind keeping M laptimer up if it shows this critical info.
      07-03-2017, 03:37 PM   #9
BAN_M2C
BAN_M2C's Avatar
4155
2004 BMW X3  [6.50]
2004 BMW M3  [10.00]
Not sure about the Laptimer but the Performance Analyser does. But it doesn't display it as multi gauges. You can have them data logging during the runs.
Follow me on IG
      07-03-2017, 03:44 PM   #10
trj3
trj3's Avatar
47
So I have bimmercode, I can set this up?
2017 BMW M2 PE MT
2006 Z06
2004 Miata
      07-03-2017, 03:50 PM   #11
BAN_M2C
BAN_M2C's Avatar
4155
2004 BMW X3  [6.50]
2004 BMW M3  [10.00]
Yes, I did mine using Bimmercode app.. It wasn't all straightforward to find but in expert mode under the display module I just typed in the parameters and the Bimmercode app narrows them down for you, then set them to aktiv.
Follow me on IG
      07-03-2017, 03:57 PM   #12
trj3
trj3's Avatar
47
What do you mean you typed in the parameters?
2017 BMW M2 PE MT
2006 Z06
2004 Miata
      07-03-2017, 04:03 PM   #13
BAN_M2C
BAN_M2C's Avatar
4155
2004 BMW X3  [6.50]
2004 BMW M3  [10.00]
When you are searching for the Parameters in Bimmercode under expert mode the app provides you an area at the top where you can type the parameters in for ease of finding them. Pretty similar to the search ESYS provided.
Follow me on IG
      07-03-2017, 08:48 PM   #14
lax01
Drives: 2017 M2
So you can't do this with iOS and Torque Pro right? Has to be Android?
      07-03-2017, 09:18 PM   #15
BAN_M2C
BAN_M2C's Avatar
4155
2004 BMW X3  [6.50]
2004 BMW M3  [10.00]
Correct, my current cel is an iPhone but Torque Pro doesn't support iPhone and the BMW screen mirroring only supports Android.
I figure if this works as I expect during track days, I might jump back to the Android world again.
Never been locked on any of them have moved from iPhone/Android couple times.
Follow me on IG
      07-03-2017, 11:49 PM   #16
DelGriffith
DelGriffith's Avatar
Drives: 2019 SO M2C
......but....... You need an iPhone to use Bimmercode and enable screen mirroring, right?
'02 E39 M5-Gone
'07 E60 M5-Gone
'07 E64 M6 Cab-Gone
'17 F87 MG M2-Gone
'19 F87 SO M2C
      07-04-2017, 12:13 AM   #17
BAN_M2C
BAN_M2C's Avatar
4155
2004 BMW X3  [6.50]
2004 BMW M3  [10.00]
Yes, iPad or iPhone.. I setup Bimmercode on the iPad.. easier to code and navigate on the bigger screen..
Follow me on IG
      07-04-2017, 02:08 AM   #18
lax01
Drives: 2017 M2
Is there any specific reason why screen sharing doesn't work with iOS? Is it just software compatibility? Four Stroke seems similar to Torque
      07-04-2017, 02:15 AM   #19
BAN_M2C
BAN_M2C's Avatar
4155
2004 BMW X3  [6.50]
2004 BMW M3  [10.00]
Apple BS most likely..
Probably same reasons why you can't screen mirroring from iOS devices to TV's directly without an Apple TV
Follow me on IG
      07-19-2017, 03:33 AM   #20
ZPrime
I INDIC8
ZPrime's Avatar
Drives: 2018 LBB M2, 6MT
2018 BMW M2  [9.50]
Completely different technologies at play here. Android stuff is using Miracast. Apple does their own thing. Technically, CarPlay is their own form of screencasting - the car's display behaves like a "second display" to iOS (when you take a screenshot on the phone, you'll also get a screenshot of the CarPlay screen).
You could also code the options into the car using a laptop + ESYS + appropriate coding cable, you wouldn't need an iPhone/iPad for that. Bimmercode is just an alternative (easier to use) than ESYS.
      07-20-2017, 09:33 AM   #21
DoZZa
DoZZa's Avatar
82
Drives: MY17 | M2 | DCT
This wont work on my car!
I followed the steps, the Screen Mirroring option is present, and I can connect to the car with my phone, but as soon as I choose the Screen Mirroring option from the Media section of the iDrive, it asks me to Add a Device!
Device has already been added, so I dont know why this is happening. Anyone have a clue?
      07-20-2017, 09:41 AM   #22
monkiboy
Dominican Republic
534
Drives: '17 x5 3.5i w/MPPK & MPE
have you turned on smart-view on your android device yet to link up to the car?
bottom right icon is what it looks like from the drop down on most android phones:
