06-07-2017, 03:58 PM | #45 |
1427
Rep 2,650
I rearranged my previous post so that is reads a bit better. The 18x10" ET25 is already available
- Ryan
06-07-2017, 04:11 PM | #46 | |
Rep 269
thanks
06-07-2017, 04:54 PM | #47 |
1427
Rep 2,650
Sounds great
06-08-2017, 09:15 PM | #48 |
Rep 61
Placed My Order
I ordered the FL-5 18x9.5ET28 in black for a square setup. I will probably put 275s on. Thanks Apex!
Gotta look for camber plates now. |
ApexWheels1426.50 |
06-11-2017, 12:08 PM | #49 |
Rep 507
Maybe I missed it, but what is the time frame for the M2 specific fitment?
Present: 21 M2C 6MT/Ford something
Past: M2 Mineral Grey 6MT Past: BMW e30 m52 turbo 628whp/558wtq |
06-11-2017, 01:21 PM | #50 |
Rep 61
ApexWheels1426.50 |
06-11-2017, 03:23 PM | #51 |
Rep 507
Thanks
06-13-2017, 06:35 PM | #52 | |
1427
Rep 2,650
- Ryan
06-19-2017, 08:23 PM | #53 |
Rep 4,253
Does a classic design like the Arc-8 not fit? These were my favourite wheels of all time. Had them on my VF E36 M3.
///M Power
ApexWheels1426.50 |
06-20-2017, 01:11 PM | #54 |
Rep 1,084
ARC-8 don't clear the brakes
ApexWheels1426.50 |
06-20-2017, 03:36 PM | #55 | |
1427
Rep 2,650
- Ryan
06-29-2017, 12:31 AM | #56 |
Rep 1,963
Off topic a little but will your 11" et 44 ec-7 with a 305 tire work in the rear of the M2 for everyday use like it does with the M4?
Current
AW BMW M2 Past VO BMW 1M |
06-29-2017, 12:50 AM | #57 | |
1427
Rep 2,650
- Ryan
06-29-2017, 08:45 AM | #58 |
Rep 3,695
06-29-2017, 03:43 PM | #59 |
1427
Rep 2,650
They do not sir, and we are also in the process of phasing that design out as they are a bit too similar to our EC-7's. With the two newest designs in addition to the existing popular ARC-8 and EC-7 designs, we will have a diverse line of wheels for our customers.
- Ryan
07-19-2017, 09:48 PM | #60 | |
Rep 1,124
[QUOTE=Eddy@ApexRaceParts;21708743][
07-26-2017, 08:22 PM | #61 | |
Rep 3,695
Do you plan on making the SM-10 in the same fitments as the FL-5? |
07-26-2017, 10:26 PM | #62 | |
1427
Rep 2,650
The EC-7 18x10" ET33 would be the better choice for a square fitment. Perfect fitment in the rear, and spacers up front for proper strut clearance. Spacer thickness up front would depend on suspension type, and tire size/brand, but many have used either 10mm or 12mm. If you used the 18x10 ET43, the rears would would sit a few mm recessed in comparison to the OEM rear wheels, but more importantly the front would require very thick spacers for strut clearance - 20mm or so. Here is a photo of an AlekShop built M2 with our 18" EC-7's: APEX EC-7 18x10" ET33 275/35-18 Bridgestone RE-71R Tires Ohlins Coilovers 12mm spacers up front (for strut clearance) AP Racing BBK Now if you are strictly asking about rear inner clearance because you are only using them in the rear, either the 18x10" ET33 or ET43 would work just fine. Keep in mind the proposed FL-5 rear wheel in the OP is 18x10.5" ET40, which sits 3mm closer to the rear suspension than the 18x10" ET43. We're initially running with the FL-5 design due to popular demand, and depending on how these sizes sell we'll know if a second design is warranted or not. To be determined. - Ryan
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 07-26-2017 at 10:36 PM.. |
07-26-2017, 11:11 PM | #63 |
Rep 3,695
I'm thinking staggered to get as much rubber as possible in the rear.
I think the 18x10 ET33 would rub the fender with a 285 and lowered coil over setup. My rear is dropped 25mm. Last edited by ZM2; 07-26-2017 at 11:20 PM.. |
02-01-2018, 09:30 PM | #64 |
381
Rep 731
02-02-2018, 03:02 PM | #65 | |||
3522
Rep 6,702
02-08-2018, 08:40 AM | #66 | |
Rep 3,695
Do you think a 275/35/18 and 295/30/18 Hoosier R7 would fit with no problems on a lowered/cambered car and the 9.5 ET28, 10.5 ET40 FL-5s? |
