10-25-2015, 03:21 PM | #23 | |
Rep 8,165
F-gen BMW's are just way too high and/or have bigger fenders if you know what I mean.
10-25-2015, 03:37 PM | #24 |
Administrator
6725
Rep 4,201
Just some food for thought, when you specifically stare at the wheel/fender line, everything looks tucked, but if you step back and just look at the car as a whole, usually factory BMW M spacing is pretty damn good. The M2 seems to be even more spaced out then the 1M IMO
10-25-2015, 05:53 PM | #26 | |
Rep 4,186
-JLT- |
koastal375.50 AndrewC198910931.00 |
10-25-2015, 08:52 PM | #27 | |
Rep 132
Lets face it, spacers are for looks, not performance. |
M3 Adjuster7905.50 AndrewC198910931.00 |
09-10-2016, 08:04 PM | #28 | |
Rep 105
The above general comment of "1 pound of unsprung weight is equivalent to adding 7 pounds of sprung weight" is complete BS and an old wive's tale. It depends on how much rotational inertia is added by the unsprung weight, and how the angular velocity of that inertial element scales relative to the translational velocity of the vehicle itself. Even in the worst cases where the mass is added all the way out at the edge of the tire diameter, adding 1 pound to the tire only translates to the equivalent of adding about 2 pounds to the vehicle body instead (in terms of impact to straight line acceleration). For the case of a spacer where the increase in inertia per unit mass is so incredibly small (since the spacer diameter is so small), there is virtually zero impact from the inertia, and it behaves like it's same original mass simply added to the vehicle (so 1 pound = ~1 pound). Go ahead and work out the math if you don't believe me (compare the relative kinetic energy in the rotating + translating unsprung mass vs. the energy in an equivalent purely translating mass). It's relatively straightforward basic kinematics. |
pup73516.50 |
09-16-2016, 11:50 PM | #29 |
Rep 679
I put 10mm front and 13mm rear H&R on my 435 GC and it made a HUGE difference in the look of the car- I should have went 13 Front and 20 rear...
09-29-2016, 01:29 PM | #30 | |
Almost completely sane
694
Rep 1,080
'17 BMW M2 (BSM 6MT Exec CarPlay, TechnicPnP ASD bypass, IND M Perf shift knob + keyhole cover, Pedal Haus pedals + heel plate, 3M CR90 tint, BavSound Ghost woofers, Racing Dynamics strut tower brace, Dinan midpipe, Turner intercooler)
'00 Honda S2000 (Silverstone Metallic, black leather, factory titanium shift knob + front lip + trunk spoiler, front shock tower brace, front subframe x-brace) |
10-03-2016, 03:03 PM | #31 |
Rep 356
I went with 12MM in front, and 10MM in rear, and it's perfectly flush. Like science. Big thanks to VAC Motors to figure that..
10-05-2016, 06:06 PM | #32 | |
Rep 542
Thanks -c
2016 BMW M2/LBB/6MT/Exec Pkg
2009 Acura MDX-stock 2008 Acura RDX-stock 2005 Honda S2000-mostly stock 1994 Nissan 300ZX Twin Turbo-barely stock |
10-05-2016, 07:36 PM | #33 |
Rep 2,560
Drives: Rapidly from A to B
I had 3 mm spacers on my 135is so I could use a square setup and get 255/35 tires in front with no strut rub and no fender rub. Was perfect. Whoever said spacers were for looks only is wrong. As far as the weight. Negligible especially in consideration that the wheels themselves were about 5 pounds each less than the stock wheels.
I'm thinking about getting some 35 offset wheels for my M2 for track use and using a 5 mm offset on the fronts again to fit the square setup on the car. I haven't finalized this decision but certainly am not discounting this option because of spacer weight. |
BAN_M2C4180.00 |
10-06-2016, 12:33 AM | #34 |
Rep 216
Drives: 2017 BMW M2
I have BMS 15mm rear and 12mm front on my car right now and the rear is very aggressive but it looks so right on this car. These are the spacers from my F80 and I really did not intend to put them on the car. I asked my salesman to take them off the F80. I expected to find them in the trunk of car with the other items I asked them to remove from the F80. I went to pick up the car and they were on the F87 and my stock lugs were in the trunk. I like the look very much. Accidental greatness? Some pics are in my garage. It validates for me, that the rear BMW style 359 19x10 et25 will work on the car with stock suspension and stock size tire.
I will say that I consider the spacers to be a street only mod and will not run a spacer at the track.
2016 750i X-drive
2017 GMC Sierra Denali 1997 MB SL500, 19"AMG replicas Past BMWs: E30 323i, E36 325is, E36 M3, E46 M3, E39 M5, E46 325i, E90 335i, F80 M3, F87 M2 |
R0ME0518.50 |
10-14-2016, 04:59 PM | #35 | |
Rep 357
Just confirming that you installed 15mm rear/12mm front on your M2? I have exact same spacers left over from my MY15 X3 and have been contemplating installing them on my M2. Did you encounter any clearance problem? Do you have photos to share? |
03-20-2017, 06:08 PM | #36 |
Rep 357
Finally put the 12mm spacers I had lying around on my M2. Looks great and absolutely no clearance issues. In fact, because camber's a more negative now, the ride harshness has actually improved. I guess that's because it's riding on inside sidewall a little more.
04-22-2017, 03:45 PM | #39 |
Rep 159
I guess my always thinking spacers were a bad idea and something the sport compact crowd did was incorrect. I get that it's for appearance but there's no adverse risks for the wheels, hubs or brakes? Sorry if this is a noob like question...
06-07-2017, 10:42 PM | #40 |
Rep 4,551
Drives: 2015 328d xDrive
I had a 12 front and a 10 rear and switched to 15s all around. Personally I like it way more this way.
11-10-2017, 11:48 PM | #41 |
Rep 719
11-11-2017, 07:07 PM | #42 |
Rep 4,203
11-11-2017, 07:46 PM | #43 |
Rep 4,551
NYC Bimmer259.50 |
