10-24-2015, 10:58 AM | #2 |
Rep 2,523
Absolutely
10-24-2015, 11:52 AM | #3 |
Rep 3,341
Spacer's will give it a more aggressive look for sure but I don't think it "needs" them. If it's not aggressive enough for you, spacer's are a cheap trick. I've had fun playing with them on M3's. I'd probably throw my 10-12mm's on the M2 for fun...then take them off when I got tired of them...rinse repeat.
Bosozoku693.50 |
10-24-2015, 12:08 PM | #4 |
Rep 2,337
There are a few cars that can pull off the look well, IMO. Most cars with the wheel at or slightly past the edge of the fender look silly. The gt350R does it the best I've seen in a while. I think the M2 will look fine but I haven't seen one dropped yet.
10-24-2015, 12:54 PM | #5 |
Rep 4,128
Drives: M235i & G30 540i
I would say yes also
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
10-24-2015, 05:26 PM | #9 |
Rep 132
I totally agree, the first question needs to be are you going to drop it...then you determine whether you want/need spacers. IMO, perfections is a perfectly flush look from the edge of the wheel well down over the tire/wheel.
10-24-2015, 09:43 PM | #12 |
Rep 250
10-24-2015, 11:23 PM | #14 | |
1130
Rep 4,686
Drives: L'Orange
5 X 4 = 20 20 X 7 = 140 lb So the car will feel like it is 140 lbs heavier....that's about all spacers do. Say no to spacers!!! |
Bosozoku693.50 |
10-25-2015, 03:03 AM | #15 |
Rep 1,852
5 lbs per spacer ??
CosmosMpower2050.50 AndrewC198910931.00 |
10-25-2015, 03:15 AM | #16 | |
Dinosaur supervisor
3030
Rep 4,214
10-25-2015, 05:57 AM | #17 | |
7485
Rep 12,307
10-25-2015, 06:58 AM | #18 | ||
1130
Rep 4,686
Drives: L'Orange
funny how testy and jumpy people can be here. Relax! Geez... There are lightweight spacers available which are 1lb or less for 10 mm but do you want to risk cracking on a spacer? Hope not. I'm not a fan of spacers in any way....no matter what they dull the feel of a car whether it is steering or suspension feel. Good quality spacers add significant unsprung weight.... |
10-25-2015, 11:11 AM | #19 | |
7485
Rep 12,307
Regardless, you're making it sound like like you have a 90% chance of cracking spacers which is just not true if you torque them to spec. If you look at APEX spacers, which I've ran and are very high quality, they're listed at 1.1 lbs for 20mm spacers. All these spacers are made from aluminum, so there's way a 20mm is going to weigh 5x that amount http://www.apexraceparts.com/apex-pr.../#.Viz-fberQ1J You are essentially saying that 1 20mm spacer (which would be far too aggressive for the M2 for stock wheels) weighs as much as a 2L coke bottle. How does that make sense? Also, if you're a stickler for unsrung weight, why are you running the OEM ZCP wheels? We both know they weigh as much as boat anchors Regardless, it's a free country. Everyone is entitled to run spacers or not. Good day sir!
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
10-25-2015, 11:55 AM | #20 | ||
1130
Rep 4,686
Drives: L'Orange
and I'm saying don't do it. just because you were wrong about their weight doesn't make me on 'crack' right? right. I hope you know what unsprung weight means... |
10-25-2015, 01:01 PM | #21 |
Rep 1,668
Wel, judging the pics overload today I do think this is the 1st Bimmer ever with an out of the factory-box good stance and wheel-gap. At 1st sight I wouldn`t change anything.
Maybe IRL it looks different, but so far so good IMO |
