02-06-2018, 08:04 PM | #221 |
Rep 184
I’d pay to have the extended overrun coded out of Stage 2.
DragonGate71.50 |
02-06-2018, 09:11 PM | #222 |
Rep 1,388
02-06-2018, 10:31 PM | #223 | |
Rep 184
djacts60.00 |
02-06-2018, 11:25 PM | #224 | ||
Rep 69
BeemerBoost118.00 VF-Engineering1008.50 |
02-08-2018, 03:22 PM | #225 |
Rep 184
Mike at VF just sent me a new Stage 2 file that has OEM throttle overrun. I’m so happy I was able to get exactly what I wanted with the HEX tune. The power delivery is amazing, and the car is more stealthy with the OEM-style throttle overrun. The default HEX overrun sounded amazing, but it was just a little too much for me. Can’t recommend VF enough. Hopefully I’ll get the M2 on a dyno once my intercooler comes.
///cbrash226.50 |
02-08-2018, 07:37 PM | #229 |
Rep 184
02-08-2018, 08:01 PM | #230 |
Rep 121
Just went for a test drive with the stage two tune. There is no traction in second now. 3rd is extremely more responsive. Overall it's a great tune.
Scared me when I thought I needed a tow truck, but it all turned out okay. Thank you Abe at VF for helping me get everything going. |
VF-Engineering1008.50 ///cbrash226.50 |
02-09-2018, 06:58 AM | #231 |
Chuggin' Along
333
Rep 588
Just so you know for the future, and to save yourself towing fees, you can always use the stock flash file to get the car running and get it home.
02-12-2018, 01:29 PM | #232 |
Rep 152
Can a windows tablet be used to upload and download the tune? Obviously it will need to have a USB port.
It would be nice to be able to switch tunes and also see vitals of the motor from a tablet instead of a laptop. |
02-14-2018, 04:53 AM | #233 |
Public Last Class
97
Rep 244
Drives: 2018 M2 DCT LBB
Do you have to pay every time you want to use a different tune file?
For example if I purchase stage 2, can I also use stage 1 or the Oem burble files too? |
02-14-2018, 10:26 AM | #234 |
Rep 2,829
Just got a Intercooler install and waiting on cp's to arrive ... Hopefully get another 10-15 horsepower
BMW I12 i8 Frozen Yellow- H&R springs, 22" Radenergie F10 Monoblock Forged /// F87 M2 Aw -Vorsteiner Aero Kit, VFF-107,Macht Schnell-Springs,VF-Engineering/Hex tuning Stage Two,ER DP,Stock Exhaust,Drop-In Bmc Filter,AA Intercooler,FTP Charge pipe+boost pipe/// Wish list :Mexico delivery 2024 BMW M2 (G87) |
///cbrash226.50 |
02-14-2018, 01:34 PM | #235 | |
Rep 1,388
02-14-2018, 01:50 PM | #236 | |
Rep 1,388
Orange fever2351.00 BSMF87139.50 |
02-14-2018, 04:59 PM | #237 |
Public Last Class
97
Rep 244
Thank you for that information. I just read your thread on Two Dynos, also very informative.
http://f30.bimmerpost.com/forums/sho....php?t=1357567 It mentions EGT’s which I’ve not heard of before but assume its an indicator of engine stress and/wear? Is this why stage 2 has a DP requirement? Without it the turbo experiences higher heat causing excessive wear and possible failure? What can you tell us on how the tunes might affect the long term life span of the engine? Is it safe to assume stage 1 is easier on the engine than stage 2? From what I’ve been reading it seems like the M2 turbo is close to maxing out in oem tune which is why it has less headroom for increased power. Is this true? If so, is the turbo smaller in decress turbo lag and improve throttle response? Thanks |
02-15-2018, 11:15 AM | #238 | |
Rep 322
Re: Stage 1 vs. 2 -- Broadly, yes, Stage 1 is less stressful on the engine than Stage 2, but you shouldn't think of it that way. The N55 is a seriously stout motor, and the motor itself won't have any issue over the long run on a simple Stage 1 or Stage 2 setup (a hybrid turbo and 500+WHP might be a different story). There may be additional stress on some ancillary components -- you'd want to change spark plugs and coils more frequently, maybe every 20k/50k miles, respectively, to keep the little guy in tip-top shape -- but other than that you should have no concerns for what is meant to be a bulletproof off-the-shelf tune. |
02-15-2018, 01:15 PM | #239 |
Public Last Class
97
Rep 244
That makes sense. I also think with a tune the mid range becomes so strong especially 3-4k that you’re less likely to rev as high all the time? Higher revs might actually be harder on it?
I’ve seen so many threads that debate whether or not the M2 has a closed deck or not. It shouldn’t be a mystery. I’m pretty sure VF even knows the correct answer. |
02-15-2018, 02:13 PM | #240 | |
Rep 322
You're overthinking the idea of additional boost being harmful to the motor going forward. The N55 platform has proven itself to be super robust with simple bolt-ons. Concerns should only start for the folks who are doing proper builds, and producing upwards of 500-550whp with a hybrid turbo, E85, meth... The advice would be to just get the Stage 1 tune (if you're sold on VF) and call it a day. If you crave more power after that, then grab a downpipe and you can upgrade to Stage 2 for $100. Simple. |
pmilani43.50 Orange fever2351.00 |
02-16-2018, 10:27 PM | #241 |
Rep 3,402
Ended up picking up a cheap Lenovo laptop on sale for $150 with windows 10, that way I have no problem keeping it in my car for programing as I need to on track days etc. My Macbookpro has my entire life in it and is mucho expensive so this was the best result for me. Ordering the tune as soon as my downpipe and intercooler arrive.
///cbrash226.50 VF-Engineering1008.50 |
02-18-2018, 04:17 PM | #242 |
Rep 485
Will this software run on Windows 7? I might pull my 3-year-old gaming PC out of mothballs if so.
Also, is there any chance of an option to disable cold start coming? I remember reading something several pages back about that being an emissions thing, but stage 2 is a non-CARB certified, off-road tune. Cold start noise is annoying enough with the sport cat, and I’ve got a Remus exhaust waiting to go on. |
