08-13-2017, 01:58 PM | #1 |
Rep 276
anybody used stock brake pads for a track day?please advise
thinking about just flushing the fluid with endless650 . will the stock pads hold up for a 150 track miles?? The M2 is not my track car i have a GT4 for that but just want to see how it is on track. don't feel like spending 800 for a set of raybestos ST43s for one day. thanks carl
08-13-2017, 03:55 PM | #2 | |
Rep 570
M3 Adjuster7904.50 |
08-13-2017, 04:30 PM | #3 | |
Rep 1,886
Drives: M5 CS / iX 50i
https://www.instagram.com/day_laborer/ (DM me from this account) Email: nextlevelautobrokersdc@gmail.com Part-time with Next Level Auto Brokers, LLC https://www.instagram.com/nextlevelautobrokers/ |
rich8566608.50 |
08-13-2017, 05:06 PM | #4 | |
Rep 1,124
08-13-2017, 07:46 PM | #5 |
Rep 1,367
So rear track pads not needed? I never ran rear track pads on my E46M3 and didn't have any issues...was thinking PFC08s up front for my first event...get some rears if there's a need
08-13-2017, 09:29 PM | #6 |
Rep 650
08-13-2017, 11:30 PM | #7 |
Rep 1,367
08-14-2017, 02:12 AM | #8 |
Rep 3,402
I did the 2 day M school last year, for the M2 all of the cars had the upgraded pads so I took that as an indication that they don't believe the stock pads will hold up to repeated track use.
08-14-2017, 01:08 PM | #9 |
Rep 1,886
OEM Rear pads will be fine as long as you're not causing the traction control light to go off all the time; in other words, as long as you are smooth with your steering inputs
08-14-2017, 02:14 PM | #10 |
Rep 3,714
Don't do it, get proper track pads and get a full set don't be a cheap ass in a 50K+ car. Flush your brake fluid with high temp fluid too.
08-14-2017, 02:33 PM | #11 |
Rep 1,367
08-14-2017, 09:08 PM | #12 |
Rep 1,124
I did track pads on all four corners.
08-14-2017, 11:33 PM | #13 |
Rep 1,466
So are the stock pads not BMW M Performance Pads? Or is it just that the M Performance Pads are really not acceptable for track use?
2018 ///M2 LCI, LBB, 6MT...
08-15-2017, 12:42 PM | #15 |
Rep 77
Stock pads turn to butter - I had to take to the escape road at Spa after 2 laps, real brown trouser moment.
CosmosMpower2050.50 M3 Adjuster7904.50 |
08-15-2017, 12:51 PM | #16 |
Rep 82
Different car but I can't recommend enough the Pagid RS-29 pads. Whole different ball game from stock and race wanna be pads like Ferodo DS2500 since RS-29 are full race spec pads used in various motorsport competitions from sprints to endurance racing.
Are the M2 rotors floating? |
08-15-2017, 12:55 PM | #17 |
Rep 228
Not only will they be gone, you will also have a chance of ruining your rotors. Mine had some minor residual on it after a light track day that luckily was gone after a few days. Anymore runs could've been warped rotors.
08-17-2017, 02:47 PM | #19 | |
Rep 3,714
But it's your car, do whatever you want. I'll continue to run track pads on all 4 corners and use fresh high temp brake fluid. The extra $250 bucks is peanuts to make sure the car works properly when you factor in the cost of the car, track time, tires, gas, hotel/food for a track day. Last edited by CosmosMpower; 08-17-2017 at 02:53 PM.. |
08-17-2017, 02:50 PM | #20 |
Rep 3,714
Did you measure caliper and rotor temps? Did you track usage on the pads and thickness of the rotors after a season? Just because you didn't have brake failure doesn't mean it's "ok".
08-18-2017, 10:21 AM | #21 | |
Rep 582
My comment was in the context of a single day on track running a conservative pace. Considering the OP has a GT4 for track use, this is what I understood the context to be. Also, I wouldn't install/use pads that don't have much meat on them to begin with, regardless of type. I'm not advocating stock rear pads on track as an indefinite go-to set-up. I run track pads/fluids all around myself. |
