M2 Technical Topics > Suspension | Brakes | Chassis > Alcon F87 M2 OE Replacement 2-Piece Disc Assembly
      07-25-2017, 12:09 PM   #1
IND-Distribution
IND-Distribution's Avatar
9587
Drives: G82 M4 / G87 M2
Brake performance has always been one of the weak links of the BMW M Cars since the E36, E46 and E90/E92 M3 models came with single piston sliding calipers and heavy one piece discs. Chances are if one takes their M3 to the racetrack and needs significant braking improvement, the only option is to completely upgrade the braking system.
On the new F87 M2, BMW has upgraded the OE calipers to Monobloc 4 piston front and 2 piston rear units which are significantly better than the previous models. Since the role of the brake discs is to be a thermal heat sink, as they absorb most of the “load” in the braking system, one of the most cost effective brake upgrades one can do for their BMW F87 M2 to improve disc life and overall performance is to upgrade the OE drilled discs to Alcon Motorsport 2-piece discs.
The OE drilled discs found on the M2 are designed for maximum comfort, low noise and to be cost effective to the vehicle manufacturer. However, they are not suited for track day or heavy duty use since drilled discs are more prone to fatigue and heat related cracking. Since the new BMW M2 is considerably faster out of the box (3450 lbs, 355 horsepower) compared to the older BMW M models, and easier to upgrade (raising the boost, changing suspension, swapping to larger tires), the brake discs will be the first to get taxed. Alcon Motorsport discs are slotted instead of drilled and feature a stronger proprietary cast iron blend compared to the OE discs which makes them more suitable for higher demand usage.
This Alcon 2-piece disc assembly upgrade also works with the OE brake system components, needing no additional modifications, which also makes the upgrade very cost effective long term.
One of the main consumable costs involved when running any car aggressively on the street or on the race track is that of the brake components (brake discs, pads, fluids). The current generation BMW M cars are significantly faster and more demanding on brakes compared to the previous model BMW M models (E46, E92, etc…). Running the OEM discs and pads at elevated temperatures (like those found on the racetrack) will almost always result in brake fade, loss of performance, and excessive wear rates of the discs and /or pads.
While it is possible to simply keep spending excessive amounts of money on replacement OE discs, the metallurgy and design of the OE discs are designed for maximum comfort and cost savings to the vehicle manufacturer, not for maximum longevity or performance. Swapping the OE discs to Motorsport grade brake discs, which are designed for use under the most severe braking conditions, will reduce the overall long term costs of brake consumables on the track and improve the overall performance of the brake system.
Multiple BMW teams have relied on Alcon Motorsport discs in professional racing categories such as IMSA, Grand-Am, and Pirelli World Challenge for their longevity, resistance to thermal cracking, and improved performance. The same Alcon Motorsport discs used in professional racing with BMW Motorsport teams such as Fall Line Racing and Turner Motorsport are also used in the Alcon 2-piece disc program.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      07-25-2017, 03:40 PM   #2
M2 Belgium
Can these be ordered as a set and delivered to belgium? And at what cost?
      07-25-2017, 05:20 PM   #3
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
Pm Sent
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
      07-25-2017, 05:23 PM   #4
Jevi Javi
Dominican Republic
80
Drives: e46 M3 + G05 X5
interesting.
Same size disc as OEM? weight?
Price?
      07-26-2017, 11:20 AM   #5
gsrbri
gsrbri's Avatar
Drives: F87 6MT
I'll be devil's advocate and apologize in advance...
1) What data do you have showing the need for this improvement? Before/after brake temperature measurements? Cost comparison?
2) I have found the gray iron rotors to be very, very durable - even with higher friction pads. I have logged over 25 track events on my M4 and the rotors are still within thickness spec (but very close, to be honest). The rotors have minimal cracking around the holes
3) The stock units are aluminum hubs/hats and float on stainless steel pins (true two-piece rotor). Certainly a compromise, and not replaceable (rotor ring), but a pretty slick design but somewhat pricey. What is the true improvement here, beyond incremental?
The calipers seem to be the weak-point of the system, as well as lack of factory brake cooling/ducting. The fronts get so hot that the painted caliper changes color.
All that said, it's nice to have options.
      04-30-2019, 04:28 AM   #6
Franzino
Franzino's Avatar
Belgium
860
Drives: M2 MY17 / Alpine A110 MY19
Excellent questions and my thoughts exactly. Still never a reply from the vendor...shows there is a lot of talk about so called improvements, but not much real data or extra info when asked for it.
