M2 Technical Topics > Track / Autocross / Dragstrip > DriveDeck Sport (M Performance Analyzer)
      06-30-2017, 12:11 PM   #1
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
Looks like the M Performance Analyzer developer offers their own version of the app...
https://itunes.apple.com/us/app/driv...675718679?mt=8
https://drivedeck.de/produkte/drivedeckpro/
Unfortunately, it looks like it requires their ODBII stick which costs just as much...
https://drivedeck.de/shop.html
BAN_M2C4178.00
rkmjr101.00
      06-30-2017, 07:03 PM   #2
lax01
Drives: 2017 M2
Is the M Performance Drive Analyser OBD stick (or their stick) anything other than a wifi bridge for the OBDII port? Anyone try it with the VGate2?
      06-30-2017, 09:56 PM   #3
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
Unfortunately, you have to enter the serial number on the ODBII stick. BimmerCode doesn't work with it and says it requires the VGate stick. A bit of a PITA. Thankfully the VGate isn't too expensive.
See Step 2 on page 4, https://drivedeck.de/media/wysiwyg/d...nglisch_v2.pdf
      07-01-2017, 07:40 AM   #4
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
These are M Performance Analyzer Core Data screens shots.
They were taken after the dash temperature gauge reached OK and the arrow was in the middle and the car is idling, except for the Mass Air Flow screen shot, I had to rev the engine to get the gauge to move. It appears, I forgot to take a screen shot of the Speed ODB, which would have shown 0 MPH.
It would be nice if they let you customize a screen to show a couple of these gauges at one time.
      07-01-2017, 07:46 AM   #5
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
This is a sample of an autocross run w/o video. Surprised how accurate the course is only using the phone GPS and their algorithms. The phone is laying face up next to the shift lever and ashtray.
      07-01-2017, 11:07 AM   #6
lax01
Drives: 2017 M2
So oil temp is available...there has to be an internal menu in the car which will display oil temp somewhere...
      07-01-2017, 11:19 AM   #7
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
Still learning but based on my reading; all of the car sensors are continually broadcasting their values to the CAN network. If you have a device on the network, e.g. ODBII stick and program, you and read those values.
Just b/c there is a sensor (or calculated value) doesn't mean there is an iDrive UI that we can see
I had thought some markets can display an oil temperature gauge instead of the efficiency dynmics we have, in which case I'm surprised someone hasn't coded it on.
UPDATE: There must be an oil sensor in the M2. When I hooked up to the X5 the oil temperature gauge was not an option under Core Data.
      07-01-2017, 05:02 PM   #8
lax01
Drives: 2017 M2
yeah, I got Torque to work with my VGate 2 - but it be nice to have a simple gauge to monitor oil temp / pressure on the track...doubt the water temp gauge is anything more than a "dumb" gauge...just seems wrong for an M car to not have a physical (or digital) oil temp gauge
      07-03-2017, 12:47 AM   #9
ZPrime
I INDIC8
ZPrime's Avatar
Drives: 2018 LBB M2, 6MT
2018 BMW M2  [9.50]
There's also Harry's Laptimer, which can tie in to various OBD2 readers to pull much of the same data from the car. Don't know if OBD2 readers can pull oil temp or boost though, some of that stuff may only be available to the M-perf app.
Does the M Perf app allow you to use an external GPS source? The built-in GPS on a phone is generally not accurate enough to give you good laptimes at track speeds. You want a 5-10Hz external GPS source if you can get one.
      07-03-2017, 06:07 AM   #10
BAN_M2C
BAN_M2C's Avatar
4178
1987 BMW 325is  [10.00]
2004 BMW X3  [6.50]
2018 Porsche 911 GT3  [10.00]
1974 BMW 2002tii  [10.00]
2004 BMW M3  [10.00]
@omasou I have been using the App for a while now and its been useful to record and get some datalogs. I responded to your PM about the App but don't recall if we talked more about it.
I have contacted the developers who are quite responsive to debug some issues I had in the past which were corrected with the last update they pushed out.
I told them the should add a feature to customize a gauge screen where you could display multiple to monitor at the same time. Showed them a picture of how I set them up on the Torque App.
They said they would take it into consideration as a future update.
But who knows if they will ever implement. :
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii
      07-03-2017, 07:07 AM   #11
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
Thanks for the option. I'm already invested in this so I want to try and make it work. Really the only improvement I would like is to log all Core Data, have it auto start and stop w/o me having to press the button each time and trigger the GoPro which it cannot b/c it is already on WiFi but w/an iPhone holder I can use the iPhone camera.
How do you hook an external GPS to an iPhone?
This is the response I received about the GPS and data analysis...
The M Performance Drive Analyser is using the GPS data from your smartphone.
The GPS data interval is 1 Hz, exactly the same as the GPS interval from your car.
By the way, a faster GPS data interval does not necessarily mean a better accuracy.
The app is using a GPS data interpolation algorithm that produces 5 GPS positions per second
using TrackDrive. TestDrive is using speed and rpm directly from your car so that the
accuracy is at 0.1 second.
You can export .csv files and send them to your email account by using the EXPORT button in the TrackDrive archive. These files can be used directly by RaceRender tools.
FYI...You can also use iTunes to export all of the data.
So yes it could be better but I was pretty amazed at how accurate the ax course render was and the phone was next to the shifter not on the dash.
      07-03-2017, 07:49 AM   #12
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
Yes, I remember thanks! BTW, I asked them the same thing
      07-03-2017, 07:51 AM   #13
BAN_M2C
BAN_M2C's Avatar
4178
2004 BMW X3  [6.50]
2004 BMW M3  [10.00]
Goooood.. they will most likely grasp the idea if more users suggest it.
It would be perfect if you could sync and use the Apps data with a GoPro video.
Follow me on IG
      07-03-2017, 02:01 PM   #14
ZPrime
I INDIC8
ZPrime's Avatar
2018 BMW M2  [9.50]
This is a good read to better understand GPS + phone capabilities with these sorts of track apps. The TL;DR summary - you want a higher sample rate than the 1Hz the phone can do, and you want a more accurate receiver if possible, mounted with a good clear view of the sky (far up on the dash / in the windshield, or outside the car if possible).
(TrackAddict is a competitor to Harry's and DriveDeck)
The external GPS box I have connects to the phone via Bluetooth, and Harry's Laptimer then polls it for GPS instead of the internal phone GPS.
      06-03-2019, 07:09 AM   #15
Megator
Megator's Avatar
518
Drives: M2 Competition
BTW just because you get an oil temp reading it does not mean that there is a sensor.
My Focus RS had an oil temp gauge and I can tell you it had no oil temp sensor. The value was calculated using an algorithem that was tuned at the factory and did not reflect real world values if the car was tuned or fitted with an oil cooler.
      06-03-2019, 02:39 PM   #16
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
Hummm...perhaps you're correct...
http://www.realoem.com/bmw/enUS/show...diagId=12_1712
      06-04-2019, 07:21 AM   #17
Megator
Megator's Avatar
518
Perhaps not!
http://www.realoem.com/bmw/enUS/show...90#13621433076
BMW seems to use the same sensor for oil and water temps. Sensor part #13 in that diagram seems to be right next to the oil filter and oil filter passages?
That is the S55 though!
http://www.realoem.com/bmw/enUS/show...51#13621433076
N55 is the same
I found this guide, but cant seem to see that sensor in these pics https://bmwtis.info/removing-and-ins...e-bmw-s55/amp/
      10-24-2019, 05:46 PM   #18
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
The developer updated the M Performance Analyzer to support multiple gauges. So if you have a feature you would like to see, you might want to reach out to them and let them know.
      12-25-2019, 05:17 PM   #19
SM2
SM2's Avatar
Drives: 2015 Audi S6 | 2017 BMW M2 | 2
Can this be coded in with bimmercode. I found the M laptimer and activated that app via coding.
      12-25-2019, 06:39 PM   #20
SM2
SM2's Avatar
I think M laptimer allows you to do go pro stuff.
      12-27-2019, 08:21 AM   #21
BAN_M2C
BAN_M2C's Avatar
4178
2004 BMW X3  [6.50]
2004 BMW M3  [10.00]
Start stop and pause I believe. But can't sync completely last time I checked.
Follow me on IG
