M2 Technical Topics > Suspension | Brakes | Chassis > Brakes : best option to start on track ? RECAP
      05-29-2017, 01:31 PM   #45
Mr 2
Drives: 2017 LBB M2
I'm not a fan of swapping out pads for track days. Is there something that is middle of the road i.e. streetable for DD but also suitable for 1-2 track days a year?
      05-29-2017, 06:11 PM   #46
M+M
M+M's Avatar
New Zealand
227
Drives: M2 DCT MPerformance coilovers
Originally Posted by OLO-M2 View Post
Thank you JRITT !
Do you think that my discs are now dead or can I recover them with some steel wool and sandpaper ?
In the past I have tried using some fine grade sandpaper to clean off pad deposits from rotors. It has worked ok so worth a try
      05-29-2017, 06:23 PM   #47
DrKevM5
DrKevM5's Avatar
Drives: G05 X5, F87 M2
I've resorted to just leaving the RS29s on for DD use. They squeal a bit, but I also have a X5M and that vehicle is known for squealing brakes so it doesn't bother me. I can get three events out of them, the stocks were done after two days.
      05-29-2017, 09:06 PM   #48
rich8566
rich8566's Avatar
Drives: M2 + Z-4
2014 BMW M235i  [0.00]
I just put on a set of Pagid RS29s front and rear. The stock pads are pretty beat up from just two track days. I used 1/2 of the front OEM pads and about 1/4 of the rear OEM pads. I'm running the RS29s on the street for two weeks before my next event at the Glen. I'm hoping to clean up the rotors that have heavy OEM pad deposits. I'll never run stock pads again on the M2. More to come after my next outing at the Glen.
      05-31-2017, 10:12 AM   #49
jritt@essex
jritt@essex's Avatar
Drives: e90 335i, NSX, 997.2, 987.1
Thank you JRITT !
If you can't get your OEM discs cleaned up by driving them with race pads cold, then you don't have much to lose by trying a medium grit sandpaper. Just remember that the goal is to remove the pad material and not the metal. I'd hit them with the sandpaper, then drive them cold with the race pads some more to try and scrub them further. After that, try doing a bed-in with your race pads of choice.
M2 Belgium Same question here, can the discs be recovered or is a swap needed? Is it advisable to swap pads my self as a non mechanic?
I can't advise you on the swapping of pads. It never hurts to learn a new skill, but if you don't know what you're doing, it's always a good idea to have someone who does work with you. Brakes are a safety item, and not doing them properly could have disastrous results!
      05-31-2017, 02:20 PM   #50
OLO-M2
Belgium
38
Thanks for your kind advice :-)
I had already watched your video, but had not understood that the race pads would actually potentially clean the discs. I thought that
- the bed-in process was only to adapt the shape of new pads to the discs
- mixing deposits from different types of pads was worse than anything
      05-31-2017, 02:48 PM   #51
M2 Belgium
After my second trackday my brake shudder is gone weirdly. I tried to keep braking at max 80% with the stock pads and concentrated on having fun. They still have one day left in them. Will switch to RS29's when I go to Spa and will try how they behave on the street.
      05-31-2017, 03:22 PM   #52
OLO-M2
Belgium
38
When do you go to Spa ?
JCL afterwork session ?
I might go end of June ;-)
      06-04-2017, 12:03 PM   #53
M2 Belgium
No date set yet, maybe curbstone :-)
      06-05-2017, 03:14 PM   #54
Franzino
Franzino's Avatar
Belgium
860
Drives: M2 MY17 / Alpine A110 MY19
You probably also saw my report on DS2500 on track : good, no impact on rotors, but could bite more according to me.
Am going to test Pagid RS29
or the Endless if Franzino offers a good price ;-)
in a few weeks...
In the end I decided to keep the Endless if I want to track my M2 again and I already did....Last minute decision to go to the ring => 45min later the Endless were back in place and the car was ready to hit the track (after bedding in the brake pads again). Switching between OEM street pads and the Endless ME 20 had zero issues...
      06-05-2017, 05:04 PM   #55
M+M
M+M's Avatar
New Zealand
227
Nice - that looks like fun.
      06-06-2017, 03:59 PM   #56
OLO-M2
Belgium
38
Then all of us are happy ;-)
Very glad of the Pagid ! Tested them last we on track and they are great ?
      06-06-2017, 04:03 PM   #57
OLO-M2
Belgium
38
[u2b
QSvyfF2oIjI[/u2b]
Nice video !
Which exhaust do you have ? I don't recognise the noise (probably also distorted by the camera)
      06-22-2017, 05:20 PM   #58
Franzino
Franzino's Avatar
Belgium
860
Nice video !
Standard M2 exhaust....
      06-26-2017, 04:44 PM   #59
Mr 2
Drives: 2017 LBB M2
Question, how come we can't just use stock m3/m4 pads? Aren't they the same brakes?
      06-26-2017, 07:07 PM   #60
rich8566
rich8566's Avatar
Drives: M2 + Z-4
That's what I thought until the OEM pads left excess deposits on my rotors. Too much stopping poster overwhelms the heat limits of the OEM pads. Do yourself a favor and use a proper track pad on the M2.
      07-15-2017, 01:20 PM   #61
peterpeter
Drives: mini
hi guys. still cant seem to get a straight answer for this
i want to upgrade the pads-
(yes going to change fluid) - but what are the options?
rs29- like the idea but its a daily driver so dont want squealing..
ferodos ?
any other options anyone has tried?
what about textars.. the OE porsche pads?
      07-16-2017, 10:40 AM   #62
GVN*2FLY
Drives: ‘16 GT4|‘22 X3MC
Question @Rich - Any updates re: running the RS529s?
I'm seriously considering this option and curious to know about how this has worked for you? I don't drive my M2 daily and think this is the way to go with high-temp fluid and stainless steel lines. I've got 2 days on my stock pads and the fronts are ~1/2 gone, the rears about 1/4 gone.
      07-16-2017, 08:34 PM   #63
rich8566
rich8566's Avatar
Drives: M2 + Z-4
The Pagid RS29s worked well on the track. They handle far higher temps than the OEM pads.
GVN*2FLY102.00
      07-16-2017, 08:38 PM   #64
rich8566
rich8566's Avatar
Drives: M2 + Z-4
ferodos ?
I love the squeal. It kinda funny when 10 heads snap around when they hear me pulling into the local gas station. They always have a surprised look when they see the noise coming from a new M2. Good stuff.
      07-17-2017, 04:38 AM   #65
OLO-M2
Belgium
38
The squeal on mine is less impressive than with the Ferodo DS2500. I also drive it daily
      07-23-2017, 03:18 AM   #66
peterpeter
Drives: mini
so have you tracked with ferodos?
are you happy with them?
