M2 Technical Topics > Suspension | Brakes | Chassis > Ohlins Road and Track F87 M2
      09-29-2016, 05:19 AM   #45
NachoM
Drives: M2 Alpine White
This suspension system is one of the best Ive experienced...and I am saying this after running on Bilstein (now B16 Damptronic) for most of my life. The robustness you feel is inmense!
I would go for this one any day for my M2...if it would not be my daily driver car...
Nacho Martinez
Alpine White M2
      10-01-2016, 07:23 AM   #46
TomAce
TomAce's Avatar
Germany
67
Drives: M2 (F87)
Have you already driven an Öhlins equipped M2? I only know that Öhlins is absolutely seen as one of the best brands for Opel Speedster / Vauhall VX220 / and Lotus Elises. A friend of mine has Öhlins coilovers and they "suck up" the road as we say in Germany...
      10-11-2016, 11:29 PM   #47
HP Autosport
Drives: F80 M3
Originally Posted by Acexxon View Post
When will the proper M2 kit be available for the US market? Anyone?
Can supply lower rate rear springs to complete a kit for the M2.
      10-12-2016, 11:02 AM   #48
BimmerSpain
BimmerSpain's Avatar
Spain
82
Drives: Coming Soon Bmw M2
Originally Posted by HP Autosport View Post
Same as F8x M3/M4. Can't post price here, please go to the link below:
http://www.hpashop.com/Ohlins-Road-and-Track-F8x-M3-M4-Ohlins-RT-F8x-M3-M4.htm
In other systems is the same suspension as M3/M4?
For example,if i buy to you a M3/M4 Kw V3 kit,can i use this in my M2 ir i need something else??
Thanks for all!
      10-12-2016, 12:29 PM   #49
HP Autosport
Drives: F80 M3
Thanks for all!
Not sure if KW is any different, but with TCKR and MCS M2 and M3/4 interchange.
      10-14-2016, 02:17 PM   #50
Acexxon
Drives: 2016 F06 M6 F87 M2
I don't know man... if it was that simple... Ohlins would have rolled out the M2 kits already yeah?
      10-14-2016, 02:42 PM   #51
HP Autosport
Drives: F80 M3
E9x M3 kits were used on the E82 1M without any changes At the end Ohlins drop the damping firmness a bit for the lighter 1M, that was it.
For the E9x none m, those kits were used on the E8x 1 series.
We will likely see a lower rear spring and damping rates on the M2 kit next year.
In the mean time many have installed the Ohlins on the M2, some are okay with the rear rates and some chose to go lower. For those wanting the M2 kits, we can offer the rear springs at a substantial discount.
      10-14-2016, 06:08 PM   #52
Acexxon
I will wait for the complete kit
      10-14-2016, 07:54 PM   #53
HP Autosport
Drives: F80 M3
If you are willing to wait, that is a good option.
Will keep you guys posted with new information as we get them.
      11-09-2016, 07:24 AM   #54
jeff@autocouture
jeff@autocouture's Avatar
966
Drives: 2002 E53 X5 4.6is
Totally agree with HP Autosport, The kit for M3/4 and M2 are not substantially different. The rear spring rates could go lower for the M2 and if you absolutely want them lower there are tons of different places to get these springs. we will be putting together a nice Swift + Ohlins Package for those interested...
Saanen180.50
      11-10-2016, 12:04 PM   #55
HP Autosport
Drives: F80 M3
Ohlins offering spring rate options now!
Rear spring options will be fill by using Swift springs.
No additional charge at all. Just order the spring rates you want from the options below.
Spring options:
Part # Length I.D. Rate
48010-03 200mm 65mm 30 N/mm // 172 lbs/in // 3 kg/mm
48010-05 200mm 65mm 35 N/mm // 200 lbs/in // 3.5 kg/mm
48010-07 200mm 65mm 40 N/mm // 229 lbs/in // 4 kg/mm
48010-09 200mm 65mm 45 N/mm // 258 lbs/in // 4.6 kg/mm
48010-11 200mm 65mm 50 N/mm // 286 lbs/in // 5 kg/mm
48010-13 200mm 65mm 55 N/mm // 314 lbs/in // 5.6 kg/mm
48010-15 200mm 65mm 60 N/mm // 343 lbs/in // 6.1 kg/mm
48010-19 200mm 65mm 70 N/mm // 400 lbs/in // 7.1 kg/mm
48010-23 200mm 65mm 80 N/mm // 458 lbs/in // 8.2 kg/mm
48010-27 200mm 65mm 90 N/mm // 515 lbs/in // 9.2 kg/mm
48010-31 200mm 65mm 100 N/mm // 572 lbs/in // 10.2 kg/mm
48010-35 200mm 65mm 110 N/mm // 630 lbs/in // 11.2 kg/mm
48010-39 200mm 65mm 120 N/mm // 687 lbs/in // 12.2 kg/mm
48010-43 200mm 65mm 130 N/mm // 744 lbs/in // 13.3 kg/mm
48010-47 200mm 65mm 140 N/mm // 801 lbs/in // 14.3 kg/mm
48010-55 200mm 65mm 160 N/mm // 915 lbs/in // 16.3 kg/mm
48010-63 200mm 65mm 180 N/mm // 1030 lbs/in // 18.4 kg/mm
48010-71 200mm 65mm 200 N/mm // 1144 lbs/in // 20.4 kg/mm
48020-03 230mm 65mm 30 N/mm // 172 lbs/in // 3 kg/mm
48020-07 230mm 65mm 40 N/mm // 229 lbs/in // 4 kg/mm
48020-83 230mm 65mm 230 N/mm // 1316 lbs/in // 23.5 kg/mm
      12-08-2016, 10:03 AM   #56
M3 Adjuster
Albania
7906
It IS that simple ...and as dumb as it sounds.... some companies really hate creating another SKU... ..
it's common knowledge that the M4 and M2 share the same suspension components ... but you are welcome to wait ....
      12-08-2016, 12:56 PM   #57
HP Autosport
Drives: F80 M3
Yep, too many different SKU's to keep on hand.
      01-15-2017, 04:28 PM   #58
Volki_M2
Volki_M2's Avatar
Andorra
17
http://f87.bimmerpost.com/forums/sho....php?t=1343598
      01-15-2017, 09:52 PM   #59
HP Autosport
Drives: F80 M3
Have a part#, but no specs yet.
      01-16-2017, 12:27 PM   #60
HP Autosport
Drives: F80 M3
Just spoke to Ohlins USA. There is nothing official on it, no specs or price. Ohlins USA will continue to sell the F8x M3/4 kits until the M2 kits are available.
      03-29-2017, 03:11 PM   #61
HP Autosport
Drives: F80 M3
Official USA release!
      03-29-2017, 10:33 PM   #62
c0rehax
Drives: f87 m2
Price and do you run the Vorshlag plates with these?
95 m3 (Black/Black)- Stromung, Bilstein PSS9, BBS : Sold
03 m3 (SG/Black)- Dixis, KW, Volk, Supersprint, RE : Sold
11 m3 (SG/Black)- KW, Volk, Vorstiner, IND, Mode Carbon, RE: Sold
03 m5 (JB/Black)- Dinan, Volk, ECS, Slimmbones : Sold
17 m2 (BSM/Black)- MPE, IND, more to come : Current
      03-29-2017, 11:26 PM   #63
HP Autosport
Drives: F80 M3
Price incoming.
Here is a photo of the setup with Vorhslag camber plates.
      03-30-2017, 03:08 PM   #64
rwalker
Drives: the wheels off
is that an articulated spring perch?
      03-30-2017, 06:13 PM   #65
HP Autosport
Drives: F80 M3
No, the articulation is from the monoball bearing.
      04-16-2017, 01:54 PM   #66
DrKevM5
DrKevM5's Avatar
Drives: G05 X5, F87 M2
I'm assuming you can run the ground control camber plates with this?
