05-24-2022, 12:29 PM | #70 | |
3871
Rep 54,430
Drives: F80 M3
Yes, for the M2 N55/M3 and M4 with blue calipers, NOT M2C. Yes, front and rear. https://www.hpashop.com/Brembo-Premi...?categoryId=-1 Last edited by HP Autosport; 05-24-2022 at 12:35 PM.. |
05-24-2022, 01:12 PM | #71 | |
Rep 216
05-24-2022, 01:31 PM | #72 |
3871
Rep 54,430
Drives: F80 M3
Brembo Ceramics are directly replacement for the factory pads, but with less dust, long rotor life, low noise. However, ceramic tend not to absorb heat well so the heat is typically transferred to the caliper/fluid and rotors. It is a great pad for street driving, but the R4-S will be better for a performance application.
07-15-2022, 02:55 PM | #76 |
3871
Rep 54,430
Drives: F80 M3
Specifically designed for the North American market, this Brembo formulated friction material with premium shim offers comfortable, quiet, smooth braking and cleaner wheels.
Designed and engineered to enhance braking power, Brembo Ceramic Brake Pads minimize braking distances while offering a quiet and safe braking experience on a variety of road conditions. Original Equipment Direct Moulding Pressing Process provides a proper and accurate fit. The positive molding process uses extreme pressure to compress friction materials and provide balanced bonding to the backing plate. Each pad is then thermal scorched following Brembo's O.E. specifications to lessen running-in and fading. Brembo's multi-layer ESE (Elastomer - Steel - Elastomer) red shim, clearly identifying the pads as Brembo pads, dampens noise and minimizes vibrations. Additional noise dampening is handled by the backing plate which also acts as a heat shield to reduce heat transfer to the caliper. Developed for a wide range of applications, including premium imports and domestic models, Brembo Ceramic Brake Pads offer the performance, dust reductions, comfort, reliability and longevity drivers demand. Vehicle Fitment: F2X F3x F8X with BMW Sport Blue Calipers. ***Not for M2C*** |
12-04-2022, 08:45 PM | #85 |
3871
Rep 54,430
Drives: F80 M3
Designed and engineered to enhance braking power, Brembo Ceramic Brake Pads minimize braking distances while offering a quiet and safe braking experience on a variety of road conditions. Original Equipment Direct Moulding Pressing Process provides a proper and accurate fit. The positive molding process uses extreme pressure to compress friction materials and provide balanced bonding to the backing plate. Each pad is then thermal scorched following Brembo's O.E. specifications to lessen running-in and fading. Brembo's multi-layer ESE (Elastomer - Steel - Elastomer) red shim, clearly identifying the pads as Brembo pads, dampens noise and minimizes vibrations. Additional noise dampening is handled by the backing plate which also acts as a heat shield to reduce heat transfer to the caliper. Developed for a wide range of applications, including premium imports and domestic models, Brembo Ceramic Brake Pads offer the performance, dust reductions, comfort, reliability and longevity drivers demand. Vehicle Fitment: F2X F3x F8X with BMW Sport Blue Calipers. ***NOT for M2C*** |
01-12-2023, 06:39 AM | #88 |
Rep 1,644
Is this the same material as the oem pads? Looking for new street pads soon but would like to get oem compound and not pay oem price lol. For whatever reason the oem compound plays nice with my hawk dtc pads when I swap back and forth.
