M2 Technical Topics > Cosmetic Modifications > Installed the BMW M Performance brake and throttle pedals / covers
      10-24-2020, 02:49 PM   #45
HMDriven.F87
HMDriven.F87's Avatar
Germany
368
Drives: 2021 BMW M2 Competition
The install is stupid simple. Just did mine.
How to install M Performance Pedals on a 2021 BMW M2 Competition
Garage:
2023 M3 Competition xDrive
2022 X7 xDrive 40i M Sport
2021 M2 Competition (sold)
      10-25-2020, 10:34 AM   #46
CTSean
Drives: LCI BSM MT M2
Originally Posted by boss2k View Post
Thanks for the detailed steps? So for point 9 gas pedal you dont have to take off any existing rubber or screw new SS gas pedal over it like the brake and clutch ones?
How do you distinguish which SS pedal is for clutch and brake? Can they fit either way?
Gas pedal cover sticks directly to the existing pedal without removing anything. The cover has double sided tape on the back, along with the 3 visible screws tat you need to drill for (buy new drill bits - your life will be easier)
Clutch and brake do fit either way so make sure you get them right (there's a million pictures showing what's right). The brake pedal rubber is also different (on both the stock and performance cover) There is an extended piece of rubber perpendicular to the pedal face on the gas pedal side. This prevents you from getting your foot stuck under the brake pedal. As long as this pedal rubber is in the right place, it's impossible to mix up which stainless cover goes where.
edit for pic. stock brake pedal on the right. Performance pedal rubber has the same extension.
      10-30-2020, 06:19 AM   #47
JustDrifting
JustDrifting's Avatar
232
Drives: BMW M2C
AC Schnitzer set - thoughts?
Wondering if anyone has installed these/ if there's any owner consensus?
https://www.ac-schnitzer.de/en/ac-sc...ers-12558.html
      11-02-2020, 05:49 AM   #48
JustDrifting
232
Drives: BMW M2C
Forged ahead with the AC pedals...
Install was pretty straight forward, tricky bit was drilling the brake pedal top holes but overall a great result and lovely pedal. Stickier rubber than the OEM rubber covers on the brake/ clutch, and love the more motorsport look to them
      12-28-2020, 08:04 AM   #49
raymondlo84
Drives: BMW M2 2017 6MT, M4 2016 6MT
I got mine installed for the M2 2017 Manual. Definitely spend some time to ensure the rubbers are fully wrapped around.
Also, you should put on some heavy-duty double-sided tape to ensure the new parts won't' move around!
