10-07-2016, 12:10 PM | #177 |
Rep 571
Mate, honestly, it's not that bad, I get on fine with it. It could be better when you go under the trees but it's not unreadable, and if your going fast then you wouldn't notice as you won't be looking at the cluster. Trust me, it's nit picking.
10-07-2016, 12:23 PM | #178 | |
Rep 1,681
Current: ///M2C
G01 X3 xDrive30i Past: ///M2 997.1 Turbo ///M3 E92 |
10-07-2016, 12:28 PM | #179 |
Rep 139
Agreed, I tried the sensor covering game too couldn't get it to turn on. It's not a real problem it just looks like it should be illuminated with the lcd displays below it in a nice illuminated bright white.
10-07-2016, 02:22 PM | #180 | |
Rep 203
I should (hopefully) see what it's like for myself in a month. |
10-07-2016, 09:38 PM | #181 | ||
Rep 2,560
Drives: Rapidly from A to B
DrKevM52276.00 |
10-07-2016, 11:30 PM | #182 |
Rep 113
10-07-2016, 11:41 PM | #183 |
Rep 7,312
Is it possible to get inside the gauge cluster? It would be easy to create a PCB that could drive some LEDs to illuminate the cluster and have it's own ambient light sensor inside the cluster area.
10-08-2016, 02:34 AM | #184 | ||
Rep 886
It would certainly be easier to code the back light as it already exists. |
10-08-2016, 12:40 PM | #185 |
Rep 229
This cluster is not a big issue to me at all. Definitely not a great design, but you can easily just turn on DIGITAL speedo if it's an issue- problem solved. I got used to it after a few days.
M2 speedo is a 100x better than the horrible one in 911. I can NEVER tell the speed looking at the analog readout as porsche decided to bunch tiny numbers (200mph) into 180 degrees and I only use the digital readout. Moral of this post, it could be much worse. |
10-08-2016, 04:54 PM | #186 |
Rep 3,069
Maybe this was asked before - any chance to code digital speed like in the F8x? Honestly, I look at the digital speed 80% ish vs. mechanical gauge
10-08-2016, 08:59 PM | #188 | |
Rep 3,069
10-08-2016, 09:03 PM | #189 |
Rep 1,514
10-08-2016, 09:22 PM | #190 |
Rep 3,069
10-10-2016, 10:17 AM | #195 |
Rep 365
For me, this is an issue. I had the car coded and asked if the orange dash lights could be programed to stay on all the time. The coder could not find the values to change it.
2022 X5 40I - Ours
2016 BMW M2 LBB 6 Sp / ED Pick Up on 07/12/2016 - Her's 1995 Porsche 993 Cab - Mine 2001 Toyota Tundra SR5 Ext Cab - Hay Hauler |
10-12-2016, 02:18 PM | #197 |
Rep 365
Good deal.... keep with it and keep us posted.
2022 X5 40I - Ours
10-12-2016, 03:29 PM | #198 |
Rep 381
Do you do local coding in Dallas?
'01 M Roadster, '24 BSM M2
