11-10-2020, 11:50 AM | #1 |
Rep 354
M Performance LED wheel install issues
I purchased a Mpeformace led wheel from a F80 owner he gave me all the harnessing and wiring needed. But shops are telling me they can't promise that the race display will work because it came from a M3 is there any truth to this? Why would bmw make the wheels different just doesn't make sense to me.
11-10-2020, 12:01 PM | #2 |
Rep 4,551
Drives: 2015 328d xDrive
Real OEM shows a different part number for the M2 and M3 so I have a suspicion that they're correct. There probably is some difference in the wiring between the two cars.
https://www.realoem.com/bmw/enUS/par...&q=32302413015 https://www.realoem.com/bmw/enUS/par...&q=32302344148 |
NYC Bimmer259.50 |
11-10-2020, 12:06 PM | #3 | |
Rep 354
That part number is also on the bmw instructions under F87 so it's saying it should fit but shops are telling me other wise. Not really sure what to do some people are telling me I'll have no issue so : |
11-10-2020, 12:09 PM | #4 |
Rep 4,551
Have you considered going to a bmw dealership for the install and seeing what they say?
NYC Bimmer259.50 |
11-10-2020, 12:12 PM | #5 | |
Rep 354
11-10-2020, 12:13 PM | #6 |
Rep 4,551
I would just try to get it installed somewhere and see what happens. If it doesn't work out you can resell it and look for another one that fits.
NYC Bimmer259.50 |
11-10-2020, 12:58 PM | #8 |
Rep 244
Drives: 2018 M2 Alpine White
My local dealership charged me around $300. It took him 3 hrs and he's master tech. He laughed at the instructions that said 1-1.5 hrs. It's not a common part to install tho so he had to trouble shoot. There are a shit load of wires and harnesses, including a radio style transponder plug that comes out near the glove box for automatic lap times (additional transponders to place at the track are required to actually use it).
The wheel has to connect into the ECU, which is why they say might not work. I would think it's based on engine not model. So that part may or may not be available through BMW because I have read where some of the wiring pieces are not available. Another member is trying to sell his wheel only and it is reported that some of the wiring is not available to buy. Sorry i can't confirm which pieces. And there is a lot of heresy on what works and doesn't on this part. I'd try the parts department at a dealership sponsoring this forum. Or call some bigger dealerships in San Fran and Houston where there are a lot of M2 owners. You'll eventually find a dealership that has installed a bunch. |
F87M2Melb19.50 |
11-10-2020, 03:45 PM | #9 | |
Rep 6,955
Drives: 2018 M2 AW DCT
11-10-2020, 07:16 PM | #10 |
Rep 660
I believe the wheel simply reads the messages from the CAN bus, so not strictly tied to engine type, but it will need to read the RPM and other information available on the display (which should be available to any modern BMW). That being said, it's possible the CAN bus between different models could be slightly different, but for the extremely common information I wouldn't really expect any change between models.
11-11-2020, 10:59 AM | #12 |
S0THPAW
8725
Rep 7,847
bngcruiser277.00 grl.racr382.50 |
11-20-2020, 04:46 PM | #13 |
382
Rep 731
I'm thinking of having this wheel installed as my OE M2 wheel is defective and Dealer agreed to replace it. I am considering paying for the difference between the two wheels and whatever diff in install cost. How do you like it? Is it worth the extra cost? Also did you do install or Dealer?
At a Point above 7,000 RPM.
12-19-2020, 01:28 AM | #14 |
Rep 2,208
Drives: G81 M3 Touring (Frozen Black)
Any chance you could show a picture of it fitted in your F87? I loved my digital OLED wheel on my F80 and would gladly get another for the CS if it turns out the original alcantara wheel is as unpleasantly wide as some reviewers say it is. (On this latter point I have to wait another few weeks to find out once it's delivered).
12-19-2020, 11:57 AM | #15 |
Rep 1,263
I had my wheel installed at the Port.
Its been great and other than it sometimes deciding not to show RPM's it has been great. Since I also have the AK Motion Display as well I probably should have gone with the non-electronic version to save $300.. https://www.fcpeuro.com/products/bmw...20group%20%231
12-19-2020, 12:12 PM | #16 | ||
20119
Rep 8,555
You're correct
12-19-2020, 01:14 PM | #17 | |
Rep 354
chief1richard382.00 |
12-19-2020, 01:24 PM | #18 | |
Rep 354
