M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Coolant vacuum fill system
      01-13-2024, 09:58 PM   #1
ghstm2
Drives: F87 M2/F97 X3M COMP
Anyone done their coolant flush and fill on their M2 and use the OEM tools 24444 system? I wanted to see what would be a good suction range due to all the plastic pieces on our vehicles.. would -25 bar be too much?
Also once you have done this coolant refill and bleed, did you also bleed using the built in electric bleeder in the car? Thanks!
      01-13-2024, 10:44 PM   #2
F87source
F87source's Avatar
Drives: Bmw M2
I'm planning to use a vaccum bleeder this summer so I can't tell you too much about the procedure yet. But you absolutely need to run the built in bleeder afterwards to ensure the heater core is fully bled and any air pockets are removed. It's also specified in ISTA to do so.
ghstm274.50
jefe2000740.50
      01-13-2024, 10:45 PM   #3
TheHaze
Drives: '18 M2
I can't comment on the vacuum system as I just drained, filled, and used the in-car bleeding procedure when I flushed my coolant. I haven't noticed any issues doing it this way. Here's a thread I started before I did the service, it has some info as well as a DIY video that was pretty helpful: https://f87.bimmerpost.com/forums/sh....php?t=2021203
jefe2000740.50
      01-13-2024, 11:24 PM   #4
ghstm2
Someone mentioned to leave the car on accessory mode turn the fan speed to low, heat on high to open up the heater core to allow the system to expel the coolant trapped in there?
      01-14-2024, 12:00 AM   #5
F87source
F87source's Avatar
Drives: Bmw M2
I've never seen people do it that way and ISTA doesn't outline that as the procedure to follow so I am unsure if that's the best way to do it - because I am now worried about the heater core and all those lines being subjected to the large vacuum induced by the vacuum bleeder. But If those components are ok with the vaccum then I don't see why not.
      01-14-2024, 09:35 AM   #6
jefe2000
jefe2000's Avatar
Drives: 2018 M2 6MT
2018 BMW M2  [10.00]
I’m not due to perform a coolant flush for another couple years — I’m halfway through the four year cycle — but this is also how I’m planning to go about it.
I'm planning to use a vacuum bleeder this summer so I can't tell you too much about the procedure yet.
Excellent. I’ll definitely keep an eye out for your report on using a vacuum bleeder. There’s always more for me to learn!
      01-14-2024, 11:41 AM   #7
tux2005
234
Drives: 2017 M2
Is there any reason to really consider not doing the built-in bleed procedure? It makes sense to me to try to use the vacuum system anyway to make things easier for the built-in procedure but it doesn't require any sort of scan tool or ISTA etc to run, is battery draw likely to be that bad?
      01-14-2024, 12:32 PM   #8
ghstm2
I don’t have ISTA so I can’t really say. But according to some people on here ISTA states to do the vacuum fill procedure as well as doing the built-in procedure from the car. Since the built in procedure could take up to 15mins, I will plug mine into a trickle charger while doing the built in bleed procedure.
tux2005234.00
      01-14-2024, 01:13 PM   #9
F87source
F87source's Avatar
Drives: Bmw M2
That's correct, ISTA specifies to do both, vaccum first then built in bleed after.
No need for ISTA or anything to trigger it. Just turn the car to accessory mode, heater to high, fan speed 1, low beams on, press gas pedal all the way down till the water pump runs. It will go for about 10 mins.
In 2020 when I did my coolant bleed I used my ctek in supply mode and bleed the system 10-15 times consecutively till the coolant didn't drop anymore. Then i let the car charge, and the next day I did another 10-15 bleeds just to make sure there were absolutely no bubbles left.
ghstm274.50
tux2005234.00
CSBM52722.50
      02-06-2024, 07:41 PM   #10
ggggbmw
Drives: 2017 M2 Manual
When changing any fluid, I like to collect everything that came out, and measure it. Then I know if what I put in roughly matches what came out, and I have a high likelihood that it's properly filled.
I've done coolant twice on my M235, which essentially the same N55 as the M2. Only used the electronic bleed process. Both times the volumes were within 100ml of each other.
So, I'm thinking the electronic bleed alone is fine. I'm sure the full vacuum has advantages, but some of those advantages might just be faster cleaner fills in a production shop environment. No carefully pouring fluid into a tippy funnel at a slow rate. Just one big simple whoosh and it's done. Could also just be a BMW habit thing given their history of needing it.
ghstm274.50
      02-06-2024, 08:43 PM   #11
F87source
F87source's Avatar
Drives: Bmw M2
Vaccum bleeder is required for the s55 or any other car withh a mechanical pump. I've talked to a bmw shop foreman and he told me they use the built in procedure for electronic water pump cars and the vacuum bleeder for mechanical pump cars.
jefe2000740.50
      02-07-2024, 11:45 AM   #12
David1
David1's Avatar
Drives: 09 E92 09 X5
When it comes time to change my coolant, I’ll just have the dealer do it with the vacuum system. I can do it myself, but there’s nowhere for me to take the used coolant, and I refuse to dump it on the ground and harm the environment.
ghstm274.50
jefe2000740.50
      02-11-2024, 03:51 PM   #13
jefe2000
jefe2000's Avatar
Drives: 2018 M2 6MT
2018 BMW M2  [10.00]
Props for not dumping it on the ground!
Out here in CA, the county household hazardous waste facility takes it. I drive up, show my Driver’s License, pop the trunk, they grab the bottle and shut the trunk, and I drive off. Done and dusted.
F87source7253.50
      02-11-2024, 04:14 PM   #14
F87source
F87source's Avatar
Drives: Bmw M2
I bring it to the fire station, that's where they take it in Canada.
But yeah it's best not to just dump it into the environment
