M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > 6MT fluid change
      06-08-2021, 11:27 PM   #23
edycol
Drives: 2011 328i xDrive
Originally Posted by F87source View Post
Originally Posted by edycol View Post
I would do Redline every 30k.
What about time interval? Like 4 years?
That is different. I would probably check after 4yrs. Do UOA and order TAN to see where oxidation is. Considering how many km you make each year, it's not worth it to do too early. You might not get right data.
F87source7253.50
      06-08-2021, 11:46 PM   #24
F87source
F87source's Avatar
Drives: Bmw M2
Ok copy that, I will look into redline dctf next time around. Hopefully the feel is even further improved.
      06-10-2021, 10:16 AM   #25
sharpmoney
Drives: NA
would redline DCTF have warranty implications? being that i'm on my second gearbox....and the first one went bad for no reason (i did NOT abuse the car or track it, 8k miles in LA traffic).
      06-10-2021, 11:51 AM   #26
jkoral
Drives: 2017 M2 LBB 6MT
I typically change the transmission (and differential) fluids every 30K.
On my OG M2, I did both at 15K and will probably do 15K intervals. It's cheap, it doesn't hurt anything and it makes me feel good. I'll probably drive 15K miles every 3 years and I plan to keep the car forever (unless some idiot runs into me and totals it, like my last BMW).
I always do UOA on the engine oil, but I don't bother with the transmission or differential fluid because I know my schedule is overkill.
      06-10-2021, 01:21 PM   #27
F87source
F87source's Avatar
Drives: Bmw M2
I would think it does, because bmw specifies MTF lt5 (as the only suitable replacement, unlike oil where you have a choice if it's LL01 approved. Dctf is also suitable for MTF lt5 applications as per redline but it's not bmw approved. I actually haven't been able to find a bmw approved MTF through ista either so I don't think bmw wants you using anything except MTF lt5, even the pentosin equivalent isn't approved and bmw MTF is a rebranded pentosin fluid.
      06-10-2021, 04:50 PM   #28
edycol
If under warranty, strictly BMW fluid for gearbox.
      06-11-2021, 02:54 AM   #29
sharpmoney
Drives: NA
alright done, will change my fluid in new gearbox myself with BMW fluid at around 1500miles. 3 years left of warranty, not gonna mess that up.
      06-11-2021, 03:10 AM   #30
F87source
F87source's Avatar
Drives: Bmw M2
Yeah it's an easy job just be careful, I stripped my drain plug (got it fixed and seaked in a valve so future fluid changes will be really easy) for some reason and another forum member here rounded the hex on his fill port. So yeah be very careful.
      08-19-2021, 09:55 AM   #31
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
325
Drives: 2018 BMW M2 LCI
has anyone posted how to do this? Change the transmission fluid.... and gear oil?
      08-19-2021, 01:25 PM   #32
F87source
F87source's Avatar
Drives: Bmw M2
Look at the m4 diy same trans and diff as the m2.....
      08-19-2021, 09:09 PM   #33
Mark2016MG
Mark2016MG's Avatar
Drives: 2016 M2, 6 speed, Mineral Grey
There is a video here...
Changed mine at 50K / 5 years, it was noriceably darker than what I put back in, which was BMW MTF LT5
      08-19-2021, 09:28 PM   #34
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
325
Thank you for the video link.
      09-10-2021, 08:28 PM   #35
-Eidos
@lbb_kev
491
Drives: 2018 BMW M2 (LBB)
Switch to Redline DCTF today. Thought my car shifted well after the Auto Solutions kit and Rogue Engineering transmission mounts but this was a nice cherry on top - shift action is even smoother. Had about 2-3k miles on the old fluid so safe to say the change in feeling was due to the Redline.
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage
      09-10-2021, 08:46 PM   #36
F87source
F87source's Avatar
Drives: Bmw M2
Yup I noticed the same and that was with stock fluid at around 9k km. I could only imagine how much better dctf feels. I'll be getting that for my next transmission fluid flush too.
      09-10-2021, 09:45 PM   #37
chris719
Drives: '08 M Roadster
Are we sure the DCTF is good for the gearbox long term?
I would probably wait till it's out of warranty personally, although I guess an SSK would make a warranty claim very tough also...
      09-10-2021, 11:00 PM   #38
F87source
F87source's Avatar
Drives: Bmw M2
Yes DCTF is suitable for the MTF LT5 requirement, redline specifies so in their description of the fluid while all their regular MTF oils do not meet bmw mtf lt5 requirements.
The reason for this is because MTF LT5 is a really low viscosity oil exactly like dctf is.
If you are on warranty you should use factory fluids - obviously lol.
chris7197334.00
      09-10-2021, 11:18 PM   #39
chris719
Yeah, I know Redline specifies it, but that doesn't necessarily mean it's been tested over long intervals.
I guess it's fine if MTF-LT-5 is really equivalent to Pentosin FFL-3.
F87source7253.50
      09-10-2021, 11:36 PM   #40
F87source
F87source's Avatar
Drives: Bmw M2
Yes absolutely correct, it meets mtf lt5 specs likely in terms of minimum viscosity required and not being too too thick, and having the proper additives. But since it is likely a high PAO and Ester content oil it will oxidize faster than MTF LT5. So you will likely have to change it out faster - how much faster will depend on your use case and a use oil analysis. But compared to bmw's life time recommendation on their MTF LT5 fluid, I would suspect DCTF to last about as long as MTF LT5 should be changed out - and for me that is about every 4 years or 40k km (but I don't reach that mileage so I go by time). If a UOA says it is too oxidized for 4 years I would have to drop down to 3 years and so on so forth.
MTF LT5 should be rebranded pentosin FFL3, pentosin does make it for bmw and they share the exact same container too (if you get the genuine German bottles, I believe the stuff in the states is made in the US so you also get different bottles and different oil). But either way yeah it should be the same oil as pentosin.
chris7197334.00
      09-11-2021, 08:08 AM   #41
ZL9M2
Drives: '17 M2 ZL9-'20 M2CS-'68 1600
I did mine along with the break-in service and then will continue to do so every 20k to 30k miles. I consider it cheap insurance.
blkonblk195.00
      09-11-2021, 12:02 PM   #42
PackPride85
Changed my mtf and diff fluid this morning at 38k miles 5 years. MTF was a little darker. Diff fluid looked a lot cleaner. Pretty easy job to do both at the same time, just make sure your jack stands are secure. Used saf-Xj for the diff and mtf-lt-5 for the trans.
      10-06-2021, 12:34 AM   #43
sharpmoney
Drives: NA
did mine at 1700mi after getting transmission replaced, used OEM fluid, shift action for sure smoother, rented a lift for $40/hr and did both engine oil and tranny oil in that time...super easy job, worth it for cheap insurance.
      10-06-2021, 05:46 AM   #44
cncmastr
cncmastr's Avatar
Drives: E30 M3 Cecotto, F85, G05, G07,
2018 X5 M  [0.00]
2020 M2 CS  [10.00]
2005 BMW X5 4.8is  [0.00]
2006 BMW M3  [10.00]
I had mine done at break-in, cost me $200 or so, why not. They used to do it when it was part of the better maintenance program.
