03-06-2017, 06:34 AM | #1 |
Rep 5
Battery tender hook up
What is the best method to hook up a battery tender?
Should I just close the trunk on the wire or can you utilize the cigarette charger? Any ideas are welcome. Thanks |
03-06-2017, 06:40 AM | #2 |
484
Rep 821
Drives: F87 M2<E92 M3<E46 M3
Garage List 2017 BMW M2 [0.00]
2016 BMW M235i [0.00] 2012 BMW 120d M Spo ... [0.00] 2010 BMW M3 - SOLD [10.00] 2002 BMW Z3 2.2i Sport [0.00] 2001 BMW M3 - SOLD [9.00] |
Use a gap in the bodywork and close it.
HawaiiShrimp76.00 |
03-06-2017, 07:04 AM | #3 |
Rep 790
I just hook it up under the hood, using the poles provided there, and secure the hood one click. Then there is enough room for the wire without being pinched or damaging any weatherstripping.
03-06-2017, 07:44 AM | #6 |
Rep 5
Thanks for all the help.
The photo makes it crystal clear. |
M3 Adjuster7905.50 |
03-06-2017, 07:49 AM | #7 |
7906
Rep 11,785
I actually usually use the rear because I back my car into my garage always. I close the trunk down on the wire but it doesn't need to latch!
I do have an outlet on the side wall and may use the front instead. |
03-06-2017, 09:14 AM | #8 |
Rep 3,953
Mine is hooked up under the hood also but I run the wires out behind the hood down the passenger side fender so I can close the hood.
JMon3y26.00 |
03-06-2017, 03:57 PM | #9 |
Rep 595
I just leave hood open till the next drive.
2017 M2 Coupe Black Sapphire Metallic
03-06-2017, 04:04 PM | #10 |
7906
Rep 11,785
Leaving the hood or decklid up definitely helps ensure that one doesn't drive off with the battery tender attached.
Stu Pedasho196.00 |
03-07-2017, 10:34 AM | #11 |
Rep 3,953
I almost did that once!
03-09-2017, 11:29 PM | #12 |
Rep 365
I hard wired my 535I and did the M2 the same way. I ran the wires out of the bottom right air scoop. The wires push up into the scoop when not in use. You will need to add some length to reach though. The charging nuts come off to reveal studs that the rings go right over.
And... I have a small plaque I set on the drivers windshield wiper to remind me to unplug it.
2022 X5 40I - Ours
2016 BMW M2 LBB 6 Sp / ED Pick Up on 07/12/2016 - Her's 1995 Porsche 993 Cab - Mine 2001 Toyota Tundra SR5 Ext Cab - Hay Hauler |
CanadianDriver98.50 Stu Pedasho196.00 |
03-10-2017, 06:57 AM | #13 | |
Rep 258
03-10-2017, 07:10 AM | #14 |
Rep 790
Though not as visually obvious, if you close it just one click there is an angry red warning light on your dash that the hood is open. I prefer the hood partially closed as I also put a cover on my car. If you drive off with a red warning light glaring at you, you deserve whatever happens
03-10-2017, 02:43 PM | #16 | ||
7906
Rep 11,785
08-11-2019, 08:23 AM | #17 |
Rep 936
Reviving an old thread... does anyone know what is needed to do the hardwire like Chuck W. did in his post? Total newb in the area. I have the BMW tender which I believe is a rebranded CTEK.
It comes with clips and cables. I'm assuming I use the round eyelet cables but then need some type of extension to get it to run to the bottom of the grill... where so I get that? Thanks |
08-11-2019, 04:08 PM | #18 |
Rep 430
08-11-2019, 05:44 PM | #19 |
Rep 47
Same here. I think this is the best way.
Current Vehicles: 2017 BMW M2 6MT
Future Vehicles: 2016 Porsche Cayman GT4, 2011 911 GT3RS |
08-15-2019, 07:15 AM | #20 |
Rep 936
I'm trying to hardwire a battery tender under the hood. Found a extension that will let me connect the tender by running the wire out the grill or by the wiper area. I'm trying to avoid opening the hood each time I want to use the tender.
My problem is I don't know how to loosen and remove the two bolts that the tender connects too. It looks like a six sided star. |
08-16-2019, 12:21 PM | #21 |
Rep 146
Drives: '76 2002 / '17 F87 M2
I have mine wired up in the trunk (pics in other winter hibernation / battery thread). Theoretically the posts are after the battery management device the car has so it should be the same as connecting temporarily under the hood. Someone recently asked me to take better pictures, but haven't remembered to do so each time I drive the car.
https://f87.bimmerpost.com/forums/sh...7&postcount=14
2017 M2 - LBB, 6MT, Exec, ED (April 2017), PCD (July 2017)
Instagram - @LongBeachBlueM2 My M2 European Delivery Adventure - April 2017 / Part II - Performance Center Re-Delivery - July 2017 |
06-20-2020, 05:27 PM | #22 |
Rep 21
I installed my Noco Genius battery maintainer the following way:
Installation notes: 1. I have an extension for the terminal connectors. 2. The nuts holding the terminal connectors are T50. 3. I added the plastic tubing to make it more cosmetic. 4. Charging is done from the hood cowling area without the need to lift the hood. |
