M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Blackstone Oil Report on Break In Oil
      07-28-2016, 05:05 PM   #1
Chuck W.
Chuck W.'s Avatar
356
Drives: '95 Porsche 993 Cab
Being some what nutty about documentation on my cars.... I took a sample of the oil at the Drop Off in Munich after putting 1,242 miles on the car on our European Delivery. Knowing that they'll change the oil before I get it back I wanted to get the sample while I could.
When I got home I sent if off to Blackstone Laboratories and got the below report on it. I'll change the oil every 5,000 miles and keep the oil reports on each one. Nothing special here.... but that is a good thing.
2022 X5 40I - Ours
2016 BMW M2 LBB 6 Sp / ED Pick Up on 07/12/2016 - Her's
1995 Porsche 993 Cab - Mine
2001 Toyota Tundra SR5 Ext Cab - Hay Hauler
MTHRAR437.50
BAN_M2C4185.00
      07-28-2016, 06:13 PM   #2
MTHRAR
Drives: LBB M2
Awesome, thank you for the notes. By chance, did you have an e9x M3? I was looking at those (and all Oil analysis threads, lol) before I decided to switch gears and get the M2...
      07-29-2016, 04:16 PM   #3
Chuck W.
Chuck W.'s Avatar
356
You're welcome. Nope, never had an M3. Came damn close once but backed out.
2022 X5 40I - Ours
      09-10-2016, 05:10 PM   #4
HP Autosport
Drives: F80 M3
Assuming you are not going with the factory change interval it will be interesting to see the test results at at next oil change.
      09-11-2016, 10:26 AM   #5
Chuck W.
Chuck W.'s Avatar
356
I will change the oil in another 3,800 miles; when it hits 5,000 miles. Then every 5,000 miles or yearly, which ever comes first. And, I'll have it analized by BlackStone and post it here. I have a Porsche that I have done the same on for years. It is a good way to monitor the engine.
2022 X5 40I - Ours
      09-11-2016, 07:56 PM   #6
HP Autosport
Drives: F80 M3
It will be interesting to see the results at 5k miles. I think you will find enough additives still present to go a bit longer, but of course the number of track days you do will be a factor too.
